> O/D on or off?, a few questions about it
post Feb 28, 2007 - 8:53 PM
LeonStryfe
Joined Mar 28, '06
From Brooklyn, New York
What does overdrive do?
What's the advantage of openning it? I always wondered what that damn button does.
This post has been edited by LeonStryfe: Feb 28, 2007 - 8:55 PM
Replies (1 - 11)
post Feb 28, 2007 - 8:59 PM
I3arruka
Joined Feb 20, '07
From The Chi, Illinois
Overdrive allows you car to go into 4th gear. If you turn it off then you are only allowing your car to reach 1st, 2nd, and 3rd gear. With it on you allowing your car to go to1st, 2nd, 3rd, and 4rd gear.
The user manual says for better gas mileage leave it on. You also wanna leave it on when your on the expressway smile.gif
"Pain is weakness leaving the body of the strong"
post Feb 28, 2007 - 9:02 PM
celicaST
Joined Jun 23, '05
OD is just the 4th gear. turning it off makes your car a 3 speed. it just disables 4th gear, thats all. leave it on. only reason they let you turn it off is if say for example you are on a curvy road and you car keeps going from 4th to 3rd and back. you would turn od off to avoid the excessive shifting.
This post has been edited by celicaST: Feb 28, 2007 - 9:03 PM
post Feb 28, 2007 - 9:49 PM
cnelson
Joined Dec 11, '06
From New Jersey
wow, never knew that. Now whenever i'm on the parkway maybe my car won't be at 4,700 rpms going 80... because its always in 3rd! I always thought OD was worse on gas... **goes off to kick himself**
"Drive Well...
...Drift Better"
post Feb 28, 2007 - 10:23 PM
LeonStryfe
Joined Mar 28, '06
Wow >_> i too didnt know that, I thought that thing locks it to third gear.
post Mar 1, 2007 - 11:51 AM
cnelson
Joined Dec 11, '06
From New Jersey
Overdrive sounds like it would take up more gas... frown.gif lol.
"Drive Well...
...Drift Better"
post Mar 1, 2007 - 12:18 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
having it on n off has its advantages n disadvantages...leaving it off will leave u with more power.....lets say ur in traffic n u have od on when u want a more punch to the brakes push it off so that it "downshifts" for engine to slwo down hence teh name "engine braking"..leaving it on will let u have more mileage to the tank...ive tried both ways on one tank...
od on: 283 miles local plus highway
od off: 250 miles local plus highway
post Mar 1, 2007 - 12:28 PM
DSToyo
Joined Dec 16, '06
From Maryland
*more gas mileage because you wont be in high rpms in third gear
srry to jack the thread, but don't manuals get better gas mileage than autos because they have that fith gear? ive heard mixed opinons
post Mar 1, 2007 - 12:41 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Not on our cars. the manual's 5th gear leaves you at 4K RPMs @ 80MPH whereas the Auto's 4th Ratio [not gear technically] leaves you at roughly 3K RPM @ 80MPH [IIRC from my 95 GT Auto]. This is also why having your O/D on gives you better gas mileage at freeway speed than with it off [it does I promise - that's really the point of it].
Also if you take off from a stop with the O/D off the tranny will hold the shifts longer allowing you to reach higher engine speeds depending on throttle position sort of simulating what you would do with the manual. It's basically an attempt at making the autos more peppy like the manuals. There is a big diff between GT Manual and GT Auto. I've had both and that's the only reason I sold my 95 Auto - too damn slow.
This post has been edited by Negative: Mar 1, 2007 - 12:45 PM
post Mar 1, 2007 - 1:36 PM
http://en.wikipedia.org/wiki/Overdrive_%28mechanics%29
post Mar 2, 2007 - 8:37 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(DSToyo @ Mar 1, 2007 - 12:28 PM) [snapback]531719[/snapback]
QUOTE(Negative @ Mar 1, 2007 - 12:41 PM) [snapback]531727[/snapback]
thats the first thing I noticed about highway driving after the tranny swap. you still get almost twice as much gas mileage with a manual. it just isn't because of the gear ratios.
my guess was that the auto tranny is so much heavier, has the torque converter, and uses a lot more electricity and brainpower from the ECU.
I <3 Dustin---07/16/06
post Mar 2, 2007 - 9:48 AM
I3arruka
Joined Feb 20, '07
QUOTE(DSToyo @ Mar 1, 2007 - 5:28 PM) [snapback]531719[/snapback]
ALSO depends on your driving habits. If your "speed racer" (which im sure no one here has ever speed before biggrin.gif ) your obviously gunna use more gas up than a "granny" would
Lo-Fi Version Time is now: September 12th, 2026 - 8:30 AM
