> turbo manifold pics
post Apr 3, 2007 - 9:45 PM
angrymike
Joined Mar 19, '07
From savannah
just finished up welding a turbo manifold for a budy of mine. he mocked it up, i just did the welding. came out pretty well.
i could make somthing similar for you guys.
enjoy!
This post has been edited by angrymike: Apr 3, 2007 - 9:47 PM
Replies (1 - 16)
post Apr 4, 2007 - 5:18 AM
nice welds.
post Apr 4, 2007 - 9:47 AM
94celicadude
Joined Mar 28, '04
From St.Louis
looks great. I have taken a tig welding course myself...i was just curious do you run an inert gas through the pipes as you weld them or is it mild steel and you dont need to?
This post has been edited by 94celicadude: Apr 4, 2007 - 9:47 AM
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
post Apr 4, 2007 - 1:03 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
can we get prices please? smile.gif btw, nice job on it...came out good
post Apr 4, 2007 - 1:12 PM
very nice work.
post Apr 4, 2007 - 1:15 PM
ihaveacelica2
Joined Nov 5, '06
From Central IL
QUOTE(94celicadude @ Apr 4, 2007 - 9:47 AM) [snapback]543056[/snapback]
all tig uses an inert gas thus the name tig or tungsten inert gas
the most common used is argon but i used to used a mix of 75% argon and 25% helium for penetration and cleanliness
edit: damn i cant read. gas through the pipes isnt really nessesary but it does add to the cleanliness of the weld
also btw nice mani
This post has been edited by ihaveacelica2: Apr 4, 2007 - 1:20 PM
post Apr 4, 2007 - 7:14 PM
angrymike
Joined Mar 19, '07
From savannah
QUOTE(94celicadude @ Apr 4, 2007 - 2:47 PM) [snapback]543056[/snapback]
what your referring too is back purging. that particular manifold was not. i typically don't, but I'm working on getting a system set up. the more extras i do the more expensive it gets though.
you get whats called "sugaring" if you don't backpurge with full penetration of the metal. that stuff is a little over an 1/8" thick, so i don't usually fully penetrate to try to avoid that condition. i get a tinny bit usually, but nothing thats going to cause restriction.
not sure about pricing, but that would particular manifold would go for $900. if anyone is interested a manifold, exhaust or just need some info, please feel free to pm me.
thanks for the compliments. i'm new here, so i thought i would show you guys i'm not a bench racer.
This post has been edited by angrymike: Apr 4, 2007 - 7:16 PM
post Apr 4, 2007 - 11:15 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
im interested in an exhaust manifold if you could pm me a quote
post Apr 15, 2007 - 8:26 AM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Apr 15, 2007 - 12:13 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
how about a t25/t28 flange for on a 3s manifold like that... would like to run the disco someday
post Apr 17, 2007 - 6:34 PM
tangcla
Joined Jan 22, '06
Has your friend fitted the manifold, and did he get any gains out of it?
post Apr 17, 2007 - 6:45 PM
QUOTE(zipstrips @ Apr 15, 2007 - 1:13 PM) [snapback]546924[/snapback]
zipper, supossedly the T3 exhaust housing setup that ATP and now garrett sells is a MUCH better match for the 3s.
if your thinking bout going that route, search mr2oc for a members posts named "bruceh"
the guy is a walking encyclopedia on the disco potato on the 3s, and his posts are AWESOME.
post Apr 19, 2007 - 10:51 PM
angrymike
Joined Mar 19, '07
From savannah
the manifold pictured at the top is for a saturn. i flew that out to my friends shop in LA last week to fit it up, weld in a wastegate and build a down pipe. that particular manifold is for a gt28rs turbo with a t3 turbine housing. it will be a couple weeks before i get any feed back, but i'm sure it will make good power.
most of my manifolds make pretty good numbers. i havn't had any full-on race cars use them, however i've had a handful of individuals in the high 300whp to low 400whp on pump gas in hondas and saturns.
i built a kit for a 02 automatic celica gt about a year ago that made 280whp on 8psi. t3/t4 50 trim and emanage.
heres another project i'm trying to finish tomarrow
This post has been edited by angrymike: Apr 19, 2007 - 10:55 PM
post Apr 19, 2007 - 10:53 PM
tangcla
Joined Jan 22, '06
geez that wheel looks monstrous!
Are there any earlier spool gains from the manifold?
post Apr 19, 2007 - 10:59 PM
angrymike
Joined Mar 19, '07
From savannah
QUOTE(tangcla @ Apr 20, 2007 - 3:53 AM) [snapback]548713[/snapback]
turbo is a t3/t4 50 trim, stage 3 turbine .63a/r. its good for about 450whp. you would probably see full boost on a 3s by 3500 rpm or a little later on 20psi.
thats the smallest turbo that i sell with my kits. that particular turbo is my favorite. good for low and high boost on pump gas for your average driver.
post Apr 19, 2007 - 11:09 PM
post Apr 19, 2007 - 11:18 PM
angrymike
Joined Mar 19, '07
From savannah
QUOTE(playr158 @ Apr 20, 2007 - 4:09 AM) [snapback]548725[/snapback]
mmm...... the manifold isn't finished and if your refering to the turbine housing, there isn't.
the turbine housing has 3 full passes on it with nickle rod. the imperfections in the casting bring all sorts of crap out in the weld making it look like it has pits or holes.
i assure you, its about as solid as it gets.
Lo-Fi Version Time is now: May 24th, 2026 - 4:45 PM
