> oil leak from tranny... need your opinion., what do you think that should be???
post Apr 16, 2007 - 4:08 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
Folks look what I have found after lifting my car:
main leak point was place where is transition connected to half shaft (some joint or something):
for better orientation once again with comments:
here another picture from different angle:
what do you think it should be? I have some theories:
- bad balance gear (differential gearing) or it's bearing
- bad axle joint... it self or some part like some seal or ring cup... I don't know
- bad half shaft (half axle)
what do you thing? anyone seen this before? Wanna more pics?
thanks for any advice...
p.s.: sorry for multiple names of parts, I'm not sure which one is right (or better) for that... kindasad.gif
edit:
also may help if you tell me which part should be bad (just in case I will not know what is that or how it is called biggrin.gif)
RH drive shaft EPC pic:
front axle holding EPC pic:
This post has been edited by malpaso: Apr 16, 2007 - 6:53 AM
Replies (1 - 12)
post Apr 16, 2007 - 4:27 AM
Hanyo
Joined Aug 16, '03
From Bay area
seems like the snap ring inside the axel is missing.
That axel (or joint) should be locked into the transmission and should not beable to move in and out at all.
you might as well replace the seal while your in there.
If that doesn't fix it, it might be something wrong inside the transmission.
post Apr 16, 2007 - 11:26 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
QUOTE(Hanyo @ Apr 16, 2007 - 2:27 AM) [snapback]547188[/snapback]
Bingo. Might be that locking ring on the end of the axle is missing, and once the axle is loose - oil will leak like crazy. Once you take your axle out - be sure to check the seal in the tranny, and replace it.
<<<<<< DCw / JDMart >>>>>>>
post Apr 16, 2007 - 12:29 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
take a hole saw and grind down ther teeth and use that to press the rubber seal into place..works like magic when i did it. took me awhile to come up with a cheap solution.
post Apr 16, 2007 - 2:01 PM
malpaso
Joined Feb 3, '06
could you confirm which parts should I order?
- 43410N (ring, hole snap)
- 04438G (front drive shaft inboard joint boot kit)
post Apr 16, 2007 - 2:16 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
The passenger side axle doesn't have a snap ring on the FWD. The axle is held in place by the carrier bearing that is bolted to the bracket on the block.
Anytime the axle is pulled away from the seal it will leak. The carrier bearing should not allow the axle to move out of the transmision. If it's leaking while the axle is in place you should replace the axle seal... It's labeled 23247B in your EPC screenshot.
This post has been edited by WannabeGT4: Apr 16, 2007 - 2:17 PM
post Apr 17, 2007 - 12:04 AM
malpaso
Joined Feb 3, '06
QUOTE(WannabeGT4 @ Apr 16, 2007 - 9:16 PM) [snapback]547296[/snapback]
...If it's leaking while the axle is in place you should replace the axle seal... It's labeled 23247B in your EPC screenshot.
nope... no leak while the axle is in place. Only when is pulled out and is really easy to do it frown.gif.
post Apr 24, 2007 - 8:33 AM
malpaso
Joined Feb 3, '06
RESULTS:
only that part with number 43410N (ring, hole snap) in this picture was broken...
part price: 5$ biggrin.gif
oil price: 47$ kindasad.gif
price of work in Toyota: 300$ mad.gif
p.s.: they also told me there is some another oil leak from engine (probably from turbo or something... have not seen it, just info by the phone) frown.gif. Hope it's only stupid attempt to make more money...
post Apr 24, 2007 - 11:03 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
You showed pictures of the passenger side axle and said it was leaking from that side, yet you say a snap ring fixed the leak which the passenger side axle shouldn't have/need... Did it end up being the driver's side that was leaking?
post Apr 24, 2007 - 12:07 PM
malpaso
Joined Feb 3, '06
QUOTE(WannabeGT4 @ Apr 24, 2007 - 6:03 PM) [snapback]549991[/snapback]
Yes it was snap ring from passenger side. There really is also mandatory snap ring (you can find it in EPC as well)
post Dec 12, 2007 - 10:58 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
My car is leaking on the driver's side, so Just to make sure:
I have the seal already, waiting to be installed.
About the snap ring, I was kinda confused about which side had it.
Is the ring from inside the seal?
Do I want to go ahead and get a snap ring from toyota? Or just hope it isn't broken.
post Dec 13, 2007 - 3:40 AM
deliriouzgtfour
Joined May 15, '03
From So Cal,CA
mine keeps on leaking...seal was replaced, but not sure if it had a snap ring in it..when i got it, they said both sides(pass and driver) seals were the same...maybe the mechanic didnt know shat? let me know what u guys think.thanks
post Dec 14, 2007 - 4:33 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE(malpaso @ Apr 24, 2007 - 7:07 AM) [snapback]550040[/snapback]
hey do you know the number printed on the oil seal??
Lo-Fi Version Time is now: July 31st, 2026 - 12:08 PM
