Sep 3, 2007 - 8:54 PM
![]() Enthusiast ![]() Joined Nov 20, '03 From Derry, NH Currently Offline Reputation: 2 (100%) |
ok so my car has recently started eating oil . and today the car started smoking only at idle with a very burnt oil smelll. then during driving there is no smoke .i popped out the spark plugs and there dosent appear to be any residue on the plugs. it also idle almost perfectly when it smokes .so im going to rule out the head gasket but could it be vavle seals?
Sep 5, 2007 - 3:14 AM
Enthusiast ![]() ![]() Joined Mar 22, '07 From Greenville NC Currently Offline Reputation: 0 (0%) |
sounds like my car. i was told it was the valve seals.
Sep 13, 2007 - 10:11 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) |
Same with mine but I puffed smoke in between gears...my car is gone til saturday but I am replacing my timing belt,accessory belts,head gasket,valve seals and my water pump...I figure I am at 172,000 and just replaced my transmission at 150,000 that I should be able now to hit that 300,000 run that a toyota can go
My uncle who is my mechanic said that Toyotas are FAMOUS for their valve seals going...but,that's really the only "problem" with them. -------------------- |
Sep 14, 2007 - 10:13 AM
yes. smoke at idle is bad valve seals
smoke while driving is bad piston rings -------------------- |
Sep 15, 2007 - 4:57 PM
Enthusiast ![]() ![]() Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
Blue or black smoke at any time is oil burning, white smoke at any time is coolant burning. Blue smoke only at startup is valve seals and during running or acceleration is usually rings.
Sep 15, 2007 - 7:48 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
i just replaced my valve seals last week... expensive as hell... i had the problem of some smoke @ startup even tho car still ran beautifully...
Sep 16, 2007 - 11:08 PM
Yeah, the Yelli Celi is having this issue. Its running rich and burning oil through the valve seals. If I'm sitting at a stop and I take off I leave a nice ploom of smoke...
AE111 coming soon... -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Sep 17, 2007 - 9:32 AM
Enthusiast ![]() Joined Nov 29, '06 From Newnan, Ga. Currently Offline Reputation: 3 (100%) |
I replaced the valve stem seals on our 7AFE, requires several specialized tools to do the job and took about 4hrs. Here's one tool;
[url= http://cgi.ebay.com/ebaymotors/Valve-Stem-...sspagenameZWDVW] [/url] And another; [url= http://cgi.ebay.com/ebaymotors/Valve-Sprin...1QQcmdZViewItem] [/url] This tooling allows seal replacement with out removing the head. The PITA is the stem keepers. If you drop one down into the crankcase!!!! Seals are about $40. |
Sep 19, 2007 - 8:50 PM
Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
i think i've got the same problem, except there is oil on my spark plugs...
-------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
Sep 19, 2007 - 9:09 PM
QUOTE i think i've got the same problem, except there is oil on my spark plugs... That could just be your valve cover gasket. Change that. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Sep 20, 2007 - 9:27 PM
Enthusiast ![]() Joined Aug 26, '07 From Norfolk, VA Currently Offline Reputation: 0 (0%) |
ouch.. so my smoking on my 7afe above 4800rpm is rings?
-------------------- Dan
AIM: Oldsyota My Cardomain |
Sep 22, 2007 - 3:58 PM
Enthusiast ![]() ![]() ![]() Joined May 19, '06 From North NJ Currently Offline Reputation: 16 (100%) |
my car has blue smoke come out of the muffler whenever i start my car in the morning or if it sits for long periods of time. my cars at 182,xxx miles right now. what will happen if i dont do any of the fixing how long will it last? how much does it cost to get valve seals done and all that stuff? i just changed my spark plugs and got a oil change. my uncle told me to get spark plug seals and change the valve cover and get a new valve gasket. any other things i can do to maintain it well?
| Lo-Fi Version | Time is now: August 9th, 2026 - 12:58 PM |
