Oct 18, 2007 - 9:54 AM
Enthusiast ![]() Joined Sep 21, '07 From FL Currently Offline Reputation: 0 (0%) |
The below engine may be in the near future. I have a 94 GT with the 5s. What else will I need? Will the stock cooling system be sufficient? I believe the 5s tranny bolts up correct? I would upgrade the clutch obviously. Also a new exhaust? Love the celi and just looking for a reliable engine with the great sound of a bov!! comments welcome
Donor Vehicle: JDM 90-93 Toyota Celica Mileage: 30k-45k miles Displacement: 1998cc Valve train: DOHC 4 Cylinder, 16 Valve, 2.0L TURBO Horsepower: 225 HP @ 6000 RPM Torque: 200 LBS-FT @ 3200 RPM Compression: 8.5:1 INCLUDED PARTS: 100% COMPLETE ENGINE - Complete Motor - Block - Head - Intake Manifold - Exhaust Manifold - Sensors - Fuel Rail - Injectors - Cam Angle Sensor - Throttle Body - Alternator - Starter - Ignition Wires - Pulleys - Turbo manifold - Turbocharger • 5-Speed AWD Transmission • Computer(ECU) • Intercooler • Complete Wiring Harness(Un-Cut) |
Oct 18, 2007 - 10:23 AM
Im not even sure, but does anyone know if the MR2 version will work without adding a radiator when converting it to FWD?
Anways does the awd tranny even bolt up to stock mounts>? Sorry to hijack your thread. |
Oct 18, 2007 - 10:32 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
5S tranny would fit.
Donor car? If its a car you should have everything you need. Front clip should have everything you need. Just buying a motor, you be missing a lot of parts. |
Oct 18, 2007 - 10:43 AM
it's not a clip, just the motor and all the accesories listed above (sensors, injectors, ECU, etc.) also, do the motor mounts line up correctly or is there some modification involved? I'm pretty sure it drops right in to the GT correct?
Oct 18, 2007 - 11:18 AM
OK, next BIG question... is it possible to keep the A/C when doing the swap??!! very important in FL as a dd.... do JDM 3s have A/C? (sorry, maybe a stupid question)
Oct 18, 2007 - 11:20 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
AFM, MAP sensor,...
http://www.6gc.net/forums/index.php?showtopic=29705 This post has been edited by Gary: Oct 18, 2007 - 11:23 AM -------------------- _Gary
Oct 18, 2007 - 12:03 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
QUOTE(cv7713 @ Oct 19, 2007 - 12:18 AM) [snapback]606155[/snapback] OK, next BIG question... is it possible to keep the A/C when doing the swap??!! very important in FL as a dd.... do JDM 3s have A/C? (sorry, maybe a stupid question) possible, just use ur old 5s AC and you should be fine... -------------------- ![]() 98% completion --- aaRon |
Oct 18, 2007 - 1:39 PM
even better
Oct 18, 2007 - 2:07 PM
QUOTE(cv7713 @ Oct 18, 2007 - 11:43 AM) [snapback]606139[/snapback] it's not a clip, just the motor and all the accesories listed above (sensors, injectors, ECU, etc.) also, do the motor mounts line up correctly or is there some modification involved? I'm pretty sure it drops right in to the GT correct? buy a clip. just looking at that list of parts, i can see a bunch of stuff missing. and read the stickies. we went over this stuff a billion times already. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Oct 18, 2007 - 2:13 PM
Oct 18, 2007 - 6:11 PM
QUOTE(lagos @ Oct 18, 2007 - 7:07 PM) [snapback]606206[/snapback] Read the stickies. we went over this stuff a billion times already. Literally. |
Oct 19, 2007 - 7:42 AM
Enthusiast ![]() Joined Sep 21, '06 From New York City Currently Offline Reputation: 0 (0%) |
I am doing a swap as we speak. I have been doing it a little at a time. I took pictures of most parts that are needed for the swap.
I am also keeping the gt ac. check it out http://www.6gc.net/forums/index.php?showtopic=52205&hl= -------------------- ![]() |
Oct 19, 2007 - 8:53 AM
Thanks komar. looks good so far, I will be following the post. After some research, now I'm not sure if I want to do the 5SFTE??? Although it seems it would be more reliable, upgradable, (and a little easier on my pocket) to do the 3S swap.... I'm going to think long and hard..... ok thought about, 3SGTE here I come!!!! I'm looking forward to seeing yours complete. good luck
This post has been edited by cv7713: Oct 19, 2007 - 10:48 AM |
Oct 19, 2007 - 11:05 AM
OK, here's what I am seeing:
Complete Engine, Harness, ECU, Trans, Intercooler, Sensors, Injectors, Etc... 86-89 3SGTE = $1,000-$1,350 90-93 3SGTE = $1,350-$1,800 94+ 3SGTE = $2,300+/- Do these prices seem accurate or a bit high? I've decided to go with the 90-93 which I belive is 225hp+/- (which is plenty to satisfy my immediate needs). Stock ECU, stock intercooler, blah blah blah. I definately want to break to 300whp eventually but no time soon, I'm sure it will take time to gather the parts. I've read the stickies and ALOT of other posts. Any words of advice before I embark? I enjoy wiring and am willing to take the time but I don't want to regret anything. Should I just fork over the $500 to have the wiring done? looking forward to this fun project... This post has been edited by cv7713: Oct 19, 2007 - 11:17 AM |
Oct 19, 2007 - 11:18 AM
QUOTE but I don't want to regret anything. for the 10th time, buy a clip. not an engine set! mail the harness out. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Oct 19, 2007 - 11:52 AM
ok heard ya... just don't really have the space for a front or rear clip and would like to avoid the extra charge if possible . if not, I will get the clip...
komar, did the injector resistor pack and fuel pump resistor come with the engine or did you find them seperate? anyone else have any experiences buying a complete engine with or without the clip??? also if you had a good purchase experience, who you used? This post has been edited by cv7713: Oct 19, 2007 - 12:16 PM |
QUOTE(cv7713 @ Oct 20, 2007 - 12:52 AM) [snapback]606541[/snapback] ok heard ya... but please explain how that will benefit and justify the addional $$$$ for a clip? if the engine I buy includes the MAP, AFM, coil, fuse boxes, uncut harness, etc what else will I need? excuse the ignorance, never done this before and I can't find anywhere where it explains the pros and cons of getting a clip. also, I really don't have the space for a front or rear clip and would like to avoid the charge if I could. anyone else have any experiences buying a complete engine with or without the clip??? chances are you will wont get enough parts, lagos is right the clip always have what you need and what you dont so you can sell whatever remains to recoupe some money...it is also easier to do the compression test (pretty important) on a clip. You might also get radiators, fans, gauges, calipers (if ur lucky)...etc... Trust us...we have been down that road before!! -------------------- ![]() 98% completion --- aaRon |
Oct 19, 2007 - 12:22 PM
ok, makes sense. thanks for the explanation. wasn't thinking about radiators or anything like that. I was just thinking about getting the engine in!!
Oct 19, 2007 - 1:28 PM
y2komar got lucky and got most of his parts. But I think he is missing the 3rd ecu plug iirc.
Oct 19, 2007 - 2:04 PM
QUOTE(99GT @ Oct 19, 2007 - 2:28 PM) [snapback]606581[/snapback] y2komar got lucky and got most of his parts. But I think he is missing the 3rd ecu plug iirc. yeah, thats always missing with ever engine set, because its part of the body harness not the engine one. so they never include that. QUOTE ok, makes sense. thanks for the explanation. wasn't thinking about radiators or anything like that. I was just thinking about getting the engine in!! getting the engine in is the easy part. getting it to run is the hard part. most people who get these engine sets end up swapping for a year or more while they hunt down parts, and try to figure out what vac lines go where. with a clip, you have everything, and can label everything before taking it out. -------------------- 15PSI - 30MPG - Megasquirt Tuned
| Lo-Fi Version | Time is now: September 1st, 2026 - 1:47 PM |
