Oct 6, 2005 - 7:57 AM
Here are some links to some of the most frequently asked questions here, most of these links are still open and postable in, lots with pictures, ect.
enjoy! Completed Engine Swaps - Once youve completed your swap POST HERE!! The big 5sfte post - Bunches on info on Turboing your 5SFE, old and new The 7AFTE bible - How to Turbo your 7AFE 7AFTE dont's, by OOBE - A great collection of 7AFTE donts, by the 7AFTE guru, OOBE How to read compressor maps - How to read Compressor maps and pick the right Turbo for your 5SFTE project 5sfe & 2nd gen 3sgte wiring diagrams in full - Wiring diagrams for the 5s and 2nd gen 3s ST-205 and 3SGTE repair tips and info - Great info for ST-205/3SGTE Owners everywhere The 2nd Gen 3SGTE swap - How to swap a 2nd Gen 3SGTE RC into a 97 ST MR2 Tranny Axles - The "Short" Axel solution thread for the MR2 Tranny in a Celica How to make a Diagnostics switch for your OBDI 3SGTE, 7AFE, 5SFE - How to make a Diagnostics Switch for your OBDI 3SGTE, 7AFE, 5SFE, ect. Traction issues and how to cure them - A Good discussion about traction issues, boost control and traction bars with a 3sgte swap, or high power 5sfte How to get your A/C to work with your swap - A great thread about how to properly wire your A/C to work with your 2nd Gen swap How to wire up your Turbo Timer with your Alarm - Another great thread by Lagos on how to install a Turbo Timer with your alarm CT-26 wastegate actuator bracket relocation how to - How to fabricate and mount your wastegate actuator when clocking your CT-26, By Dr. Tweek DIY knock detect system - DIY knock detection system for the 3SGTE Getting the right walbro fuel pump - Info on choosing the right fuel pump for your swap or turbo setup. A/C Compressor removal - Part numbers for belt and pully to properly remove the AC compressor on the 3SGTE 3SGTE Cold Weather hesitation fixes - How to fix cold weather hesitation issues on the 2nd Gen 3sgte Gen 2(ST-185) Vs Gen 3 (ST-205)3SGTE diffrences - Diffrences between the 2nd and 3rd Gen 3SGTE engine How to reset your idle screw on your 3sgte AFM back to its factory position - How to return your idle bypass screw on the 3sgte AFM back to its factory position How to add a helper spring to your ct series turbo wastegate - How to add a helper spring to your CT series turbo wastgate actuator Have somthing to add??? PM a mod, we'll add it in!!! -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: September 11th, 2026 - 3:45 PM |
