> oil on spark plug, need help please!!!!!
post Oct 20, 2007 - 9:16 PM
Jeunesse
Joined Aug 21, '07
From Toronto
So I decided to change my spark plugs this morning after reading a thread regarding spark plugs and this is my concern... there's oil on the old spark plugs... what do you think causes this? Is it the Oil cam ring? if it is... is there a how to on how to fix those? is this a serious problem? would it affect the firing of the spark plugs
This post has been edited by Jeunesse: Oct 20, 2007 - 11:31 PM
-Derick
"In hoc signo vinces." In this sign thou shalt conquer."
Gone but never forgotten....
Replies (1 - 9)
post Oct 20, 2007 - 11:18 PM
Jeunesse
Joined Aug 21, '07
From Toronto
bump... anybody?
-Derick
post Oct 21, 2007 - 12:29 AM
oil cam ring?
you just need to replace your valve cover gasket. super easy job.
post Oct 21, 2007 - 7:57 AM
Jeunesse
Joined Aug 21, '07
From Toronto
The thing is I don't have any other oil leaks, just on the spark plugs. how easy is it to change the valve cover gasket? how much does this oil in the spark plugs affects the performance? thanks for your help guys...
-Derick
post Oct 21, 2007 - 9:38 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(lagos @ Oct 21, 2007 - 12:29 AM) [snapback]606886[/snapback]
oil cam ring?
he already answered your question, if you have or not other leaks that's another story, the leak you ask for ( oil on spark plugs ) will be fixed when you replace your cover gasket ( including the gaskets around teh sprak plugs holes )
This post has been edited by Culpable04: Oct 21, 2007 - 9:39 AM
post Oct 21, 2007 - 3:34 PM
Jeunesse
Joined Aug 21, '07
From Toronto
ah i see... thanks for the help guys. Im new at this that's why I ask a lot... just trying to learn and not be annoying as hell. Thanks again.
-Derick
post Oct 22, 2007 - 1:42 AM
thedrunkfish
Joined Jul 4, '07
Dont suggest changing the valve cover gasket yourself unless you know what your doing. Mucking it up could have dire consequences.
post Oct 22, 2007 - 9:33 AM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
QUOTE(thedrunkfish @ Oct 22, 2007 - 1:42 AM) [snapback]607184[/snapback]
if you need a hand bro, just ask.
Imo, change the spark plug tube seals. There are four of them, they sit right under the nuts that hold down the valve cover, they are like 2 bux a piece at the dealer and they could also be your problem. That was my source when I had the same problem.
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Oct 22, 2007 - 10:10 AM
Jeunesse
Joined Aug 21, '07
From Toronto
thanks night, That is just what I need... more options and opinions. I don't want to work on my baby and not be sure on what I am doing and just make the problem worst. I want to do it right the first time when it comes to my car that's why I ask a lot of questions and do a lot of ressearches and reading.
Again, Thanks for all the help... if anybody has any other opinions, I really really appreciate it if you could share it with me.
-Derick
post Oct 22, 2007 - 2:10 PM
QUOTE(Jeunesse @ Oct 22, 2007 - 11:10 AM) [snapback]607241[/snapback]
i paid 85 bucks. what tha hec* I was tired after changing the clutch... laugh.gif
Lo-Fi Version Time is now: September 20th, 2026 - 3:14 AM
