> CEL light just came on, What do you guys recommend???
post Dec 29, 2007 - 11:32 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
Ok so I just got home and picked up my fiance to drive to the movie store to take back a dvd, no problems then and none in the past. After returning the DVD I start my car and my CEL is on. I drove all the way home (about 3-4 miles) no problems. Car does not feel ANY different. It bothers my though knowing SOMETHING is possibly wrong with my car. So I got to thinking...
I can take my car to the dealer (or a local shop) and have the car looked at. I'm estimating that this will be about $60-100 depending on where I go. I have the funds to have the car looked at, but depending on the problem, I might not have the funds to fix it. So I got to thinking some more and realized that Kragen sells the CEL code reader for $99.99 (cheapest one). So I was just wondering if anyone has used one from Kragen (probably not the greatest) and if anyone has, how has it worked?
I would also like to get some more opinions on this, see what one of you guys would do if you were in the same situation. Also, can anyone recommend anything for me to check? Would rebooting the computer (unplugging the battery for about 10 mins) help? Any input is appreciated, thanks in advance guys...
Current engine mods:
96 Celcia GT
CAI
Header (cat delete)
NGK Plugs
CatBack Exhaust (2.25")
Replies (1 - 21)
post Dec 29, 2007 - 11:39 PM
autozone reads codes for free
post Dec 29, 2007 - 11:43 PM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
Yep I'd go to autozone first and see what code shows up.
There is also the paperclip method... I can't remember how exactly you do it, but Lagos posted a how to a long time ago and I couldn't find it in my quick search. Once you figure out two pins to connect you can look here and see if the code shows up and go from there.
http://www.toyotacelicaonline.com/error.htm
-Brad
01 a4: daily
post Dec 29, 2007 - 11:50 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
wow, i had no idea that autozone did that, ima have to check that out. If that doesn't work (dont see why it wouldn't) i'll probably try that paper clip method. Thanks guys...
post Dec 29, 2007 - 11:53 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
The reader from Autozone is more accurate than the pin trick. The data reader under the hood doesn't tell as much as the one in the dash that Autozone reads.
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Dec 29, 2007 - 11:55 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
there is a way to read the CEL code w/o buying or using an actual code reader.
how to:
jump TE1 & E1 on the diagnostics plug in the engine bay between the strut mount and the firewall on the drivers side. turn the key on, but do not start the car, and watch the CEL. it will either blink at a steady pace, indicating no error or blink x times. take note of how many times it blinks.
post Dec 30, 2007 - 12:15 AM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUOTE(stephen_lee @ Dec 30, 2007 - 4:55 AM) [snapback]626598[/snapback]
how to:
.....and then go buy a $140 toyota technicians manual to tell you what the number of blinks means.
Pass. Go to Autozone.
"What?"
"Just do it."
"No problem."
post Dec 30, 2007 - 12:16 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i have one lol
post Dec 30, 2007 - 12:20 AM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUOTE(stephen_lee @ Dec 30, 2007 - 5:16 AM) [snapback]626601[/snapback]
i have one lol
Griffgirl gave it to me.
God I love that woman.
This post has been edited by thespacepanda: Dec 30, 2007 - 12:21 AM
"What?"
"Just do it."
"No problem."
post Dec 30, 2007 - 12:27 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i have the actual book.
post Dec 30, 2007 - 12:34 AM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUOTE(stephen_lee @ Dec 30, 2007 - 5:27 AM) [snapback]626605[/snapback]
Do you know how long that would take? 30MB of pdf files. I could ftp them....
"What?"
"Just do it."
"No problem."
post Dec 30, 2007 - 12:39 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
do you have dial up?
i have cable.. so not long on my part
post Dec 30, 2007 - 4:20 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(stephen_lee @ Dec 29, 2007 - 11:55 PM) [snapback]626598[/snapback]
how to:
that does not work for OBDII vehicles. he has a '96 which is OBDII
go to AutoZone, get the code, post what code it is and we can help you from there
This post has been edited by hurley97: Dec 30, 2007 - 4:21 PM
I <3 Dustin---07/16/06
post Dec 30, 2007 - 5:21 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
we need to get that tech manual.... can you send it to me and i can post it for the entire site to use
Breaking Axles...
post Dec 30, 2007 - 6:12 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUOTE(pittfirefighter @ Dec 30, 2007 - 10:21 PM) [snapback]626758[/snapback]
I'll send it to you, just gonna take a little while.
This post has been edited by thespacepanda: Dec 30, 2007 - 6:15 PM
"What?"
"Just do it."
"No problem."
post Dec 30, 2007 - 11:29 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
Ok, so i went to autozone and rented out the tool. Plugged it in and the error code was P0420. The device that I rented actually told me what the problem was. It said something along the lines of my catalyst not functioning properly. I am assuming that it is referring to my cat, which because of my header I no longer have, Even though the header I purchased has the spot for the sensor...So I just erased the code, CEL no longer on. I also stopped by pepboys for a fuse holder (planning on getting some neon) and it turns out they are going out of business in my area. Lucky me smile.gif. They just so happened to have the code reader on sale for 39.99. Its not the top of the line but it will get the job done. It also came with a book and CD that has all the codes with the definition.
So as far as I know, the car is fixed (not that there was anything really wrong in the first place). Thanks everyone for posting, you guys saved me alot of $$$.
post Dec 30, 2007 - 11:45 PM
the code will come back
post Dec 31, 2007 - 12:28 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
you should have 2 cats. I assume you have had the header for a while before the CEL came on. Most likely the second cat is just not filtering as efficiently anymore since there is more fuel going through it than normal. Eventually too much fuel will burn out the cat completely. at that point you need to either trick the second o2 sensor or get a new cat
post Dec 31, 2007 - 12:33 AM
thespacepanda
Joined Apr 12, '07
From Houston, TX
We have 2 cats?!?!?
"What?"
"Just do it."
"No problem."
post Dec 31, 2007 - 12:40 AM
QUOTE(thespacepanda @ Dec 31, 2007 - 12:33 AM) [snapback]626860[/snapback]
We have 2 cats?!?!?
yes
post Dec 31, 2007 - 12:46 AM
k-weaver
Joined Jun 5, '07
From Santa Maria
I assumed that the light would eventually come on again with the same error code, that is why I purchased the code reader. As far as the second cat burning out, If I were to purchase a high flow cat, would that take care of it? Or would the same thing happen again? Also, how would I trick the sensor?
post Jan 1, 2008 - 4:04 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
removing one of your two cats reduces the exhaust gas filtering which is why the CEL is coming on. getting a high flow cat is a step in the wrong direction.
to trick the O2 sensor you could try something to pull the O2 sensor further from the exhaust gases. I am planning on doing this trick with my exhaust after I turbo since I will be removing the cat and going straight pipe. I am not sure if it will work but it's worth a try.
this example is from the Subaru guys [I think]. They used spark plug non-foulers from the Help! section at Autozone. I can't find the original post from it but I did save the picture...
Lo-Fi Version Time is now: September 11th, 2026 - 1:59 PM
