Jun 16, 2008 - 1:51 AM
well its about time to change spark plugs on my car.........
so why not do spark wires also...... any recommendations on good brands for the ol' 5sfe............ also anything i could do while im in there........ Much Alohas for any input, Jon -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 16, 2008 - 2:22 AM
Enthusiast ![]() ![]() ![]() Joined Sep 28, '07 From Toronto, ON Currently Offline Reputation: 5 (100%) |
TRD but too bad they're discontinued but stock ftw!
But if u decide to want to upgrade then just go with the Nology hotwires. |
Jun 16, 2008 - 2:55 AM
coool....nology wires and stock plugs???
i might as well upgrade like that tampon commercial -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 16, 2008 - 6:55 AM
Toyotas do not like aftermarket ignition wires. Stick with OEM wires and get some nice NGK spark plugs, Iridiums or V-Powers.
Jun 16, 2008 - 2:50 PM
i said stock plug wires, not stock plugs.
Sorry if you misunderstood me. As far as I know, there are no such thing as TRD spark plugs. But i'm using NGK Iridium IX. |
Jun 16, 2008 - 4:43 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
TRD but too bad they're discontinued but stock ftw! But if u decide to want to upgrade then just go with the Nology hotwires. That isn't stock. And your reply is confusing. If stock is best [FTW!], then why would you recommend Nology as an "upgrade" [which it isn't IMO]. -------------------- ![]() |
Jun 16, 2008 - 9:03 PM
I was saying just with stock spark plug wires but IF he wanted to upgrade then i guess go with nology hotwires.
Jun 16, 2008 - 9:24 PM
HAhah no fighting in this thread please
okay. say if i were to upgrade my ignition stuff like plugs and wires what would you recommend..... or what do we as 6gc owners have to choose from....being limited in support for the 5sfe mikE you said nology hotwires........ -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 16, 2008 - 9:27 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
i've always heard ngk's are good.
Jun 17, 2008 - 4:13 PM
Fighting? nahhh...clarifying.
But I was never sure if we had NGK wires for our 5s motors, because I usually saw them for the 7A. Anyhoo, so you're all done the exterior now correct? Instead, why not just swap your motor to a 3s. Do it....do it now. |
Jun 17, 2008 - 4:23 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
aren't they just spark plug wires?...do they really do anything.
i use bosch platinum plugs |
Jun 17, 2008 - 4:56 PM
Jun 17, 2008 - 6:35 PM
Enthusiast Joined Jun 11, '08 From Seattle Currently Offline Reputation: 0 (0%) |
I ran the 5mm NGK's on my 5SFE and they were really nice. Everything fit so perfectly!! And they look so nice! If you are llooking for thicker racing 8mm wires...Magnecores makes them for the 5SFE also. Ebay it. It is as much if not more then the Nology's. I have heard, haven't experience, Nology's Hotwires. I heard that the built in capictators don't respond well to Toyota's like in Hondas. But check around. 5mm great if you are not running external coils. Anything other then that will be 8mm or you will risk melting your wires. You can buy a do it yourself set from Accel, but it won't have the square boot. Hope that helps.
OH BTW D Sport Mag has some info on spark plugs this month. Stating that copper is most conductive...but needs a bigger conduct point (bigger electrode) then platnium or iredium (which can be amde thinner and use less energy). I run coppers...if they have gold...I would run gold. Anybody who has worked with electrical...knows that copper conducts energy very well. You just have to replace them more often...which is ok...because they are cheap and it forces you to check on the condition of your engine. This post has been edited by mspired13: Jun 17, 2008 - 6:38 PM |
Jun 18, 2008 - 3:42 AM
coool and mikeE i am not done with my exterior mods
well..........im thinkin on going stock wire route and upgrade on the plugs. what does the 5mm relate to??? on the plugs........i have an idea but im not 100% sure. mahalos for the info mspired13 and everyone else -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
| Lo-Fi Version | Time is now: September 15th, 2026 - 8:11 PM |
