> Why Do Cars "bounce" in Low Gears?
post Dec 15, 2008 - 4:58 PM
mrgrape
Joined Jun 21, '07
From SoCal
I have a decent knowledge of how transmissions work, but I can't understand why a transmission would "bounce" or jerk when in low gears and not high gears.
What I mean by this is: When driving around in 1st, if you let go of the gas your car will bounce around and jerk like no other, but if you let go of the gas going 60 in 5th, it will slow down smoothly. Why is this?
Replies (1 - 14)
post Dec 15, 2008 - 5:02 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
silly mrgrape. those are hydraulics. no one in their right mind would hit the switches going 60, thats why you never bounce.
i see you posted/ copy&pasted this from clubrsx...
....i see what you did there.....
This post has been edited by 95CelicaST: Dec 15, 2008 - 5:13 PM
**** Photobucket
post Dec 15, 2008 - 5:09 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
QUOTE (mrgrape @ Dec 15, 2008 - 4:58 PM) *
shift gears your rpms are too high
BOOST GETS YOU LAID!!!!
post Dec 15, 2008 - 5:43 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
THIS THREAD IS AWESOME!!1!!1!
post Dec 15, 2008 - 6:07 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
torque. your "band" is smaller in lower gears. taller gears its spread out longer.
post Dec 15, 2008 - 6:51 PM
enderswift
Joined Jul 12, '08
do you mean your letting off the gas in first gear at 3000+ rpm?
thats the only thing i can think of that would cause what your describing...
if thats the case, SHIIIIIIIIIIIIIFT
post Dec 25, 2008 - 12:11 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i think he means when you're cruising at like 5-10 in 1st, cause idiots keep stoping and going in front of you and you don't feel like shifting 1-2-1-2-1-2-1 87495687x. i tap my gas and bounce, or jerk.. you know?
post Dec 25, 2008 - 12:24 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
...going 60 in 5th, it will...
you're auto tranny has a 5th gear ?
I <3 Dustin---07/16/06
post Dec 25, 2008 - 12:32 AM
bslik
Joined Oct 10, '07
From Sunrise Florida
i think i kno wat op is talking about
i thought it had something to do with the little springy things on the clutch disk... but that sounds stupid now that i think about it.
post Dec 25, 2008 - 3:21 AM
Hanyo
Joined Aug 16, '03
From Bay area
you have blown shocks
post Dec 25, 2008 - 12:31 PM
Rayme
Joined Feb 18, '06
From NB, Canada
physics behind the high gear ratio and..that's it. A blip of the throttle will send slot of torque in low gears vs high gear making it easy to "rock it back and forth".
-Rémy
02 SiR, 08 250R
post Dec 25, 2008 - 12:35 PM
yarik83
Joined Nov 22, '04
From FL
Well my question is.. with my 3rd gen swap.. I can be creeping in first gear but as soon as i step off the gas it goes on a jerkadee jerk fest. In my old celi I never had to use my clutch foot so often as I do with this car...
Captain Pessimist
post Dec 25, 2008 - 12:54 PM
QUOTE (yarik83 @ Dec 25, 2008 - 12:35 PM) *
torque and your clutch.
post Dec 25, 2008 - 1:17 PM
yarik83
Joined Nov 22, '04
From FL
My car is putting out waaaay too much torque I think. They gave me a dyno number at 261hp to the wheels but never gave me my torque number and of course they havent retained my numbers. I have not been to a dyno since.
At first I used to spin my wheels in every gear but a year later I can control the beast. She is now parked as im going on my vacation and she is broken. My drive belt broke and I think it was alternator that caused it. I can spin it while its cold but when it freezes up when I start the engine. New one is due to arrive January 1st or 2nd so I will be fixing it on the 4th when I come back from Caribbean.
Captain Pessimist
post Dec 25, 2008 - 1:48 PM
jcbass7
Joined Apr 20, '06
From Florida
i'm pretty sure he is talking about a situation that happens for example in stop and go traffic.. and i agree with Dustin and Itchy, its the torque and power band. don't forget once you let off the gas and leave it in gear the engine is slowing the car down instead of speeding it up and at such a slow speed going back and forth from that it will jerk like that. If you drive most cars at about 5-1-mph and let go of the gas and stay in first or even in second it will start to buck/jerk.. its about to stall, but in 5th gear the engine is still turning over so much more that it wont stall and doesnt buck/jerk around..
I could be right, or wrong but i feel like that explains some of it.
Its kinda like when you learn stick the first time, in first gear if you dont give it enough gas it bucks like crazy
Lo-Fi Version Time is now: September 15th, 2026 - 12:51 AM
