Mar 22, 2009 - 6:14 PM
Enthusiast ![]() ![]() ![]() Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
How would I know 'for sure' that my mechanic correctly got my timing straight on my car? I mentioned before that he took like 2 hours to figure it out and now I am a bit concerned. There doesn't seem to be any issues but would there be??
Also, is our 5sfe cylinder head a non-interference head? This post has been edited by 6G96GT: Mar 22, 2009 - 6:19 PM |
Mar 23, 2009 - 12:08 PM
Anyone on that head question?
Mar 23, 2009 - 12:20 PM
it is an interferance engine. if timing is wrong, the valves will smack the pistons
Mar 23, 2009 - 12:40 PM
Just out of curiosity, how would you know is it was off?
Mar 23, 2009 - 12:56 PM
Enthusiast ![]() ![]() ![]() Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) |
Mar 23, 2009 - 3:48 PM
This seems to be a debatable subject. Personally I have no clue, that's why I am asking. I read on other posts to that it is and it isn't. I even called IRA Toyota and asked them and they couldn't help me because the service department was closed today. So...
Mar 23, 2009 - 4:02 PM
Enthusiast ![]() ![]() ![]() Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) |
everything i've read has said that the F head is non-interference
EDIT: doing a quick search I came up with this for your timing issue http://www.justanswer.com/questions/x99c-i...iming-91-toyota this guy is having timing issues and somebody is helping to walk him through using a timing light. I don't know if it'll help you out, but its there. Also this: http://www.toyotacelicaonline.com/timing.htm Edited for correctness This post has been edited by jimmykay: Mar 24, 2009 - 8:19 AM -------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Mar 23, 2009 - 5:43 PM
jimmykay, that second article is good. Thanks for your research. Both articles didn't solve my question however because I am definitely not mechanically inclined to do that myself. I can pretty much only install bolt on parts at this point. Thanks though, much appreciated!!
Mar 23, 2009 - 5:47 PM
all S series engines are non interference motors. (smayy, you thinking of the ZZ?)
the easiest way to tell would be to verify mechanical timing using the BGB method. we have a couple of the BGB's posted in the resource thread in GD, you can download the manuals there. what i like to do is pull the distributor cap off, verify the location of the #1 plug wire (its printed right on the cap if its an OEM cap and also on the wires too if they are OEM). turn the motor clockwise till the timing mark on the crank pully is @ 0 and check that the rotor attached to the distributor is pointing @ #1, or 180* from #1 -------------------- Former Team 5SFTE pro member ;)
Mar 23, 2009 - 9:09 PM
Good to know, I think I will try that tomorrow. I got to put in a new radiator anyway, I noticed mine had a couple leaking stress cracks on the top the other day.
| Lo-Fi Version | Time is now: August 24th, 2026 - 4:11 AM |
