Apr 11, 2009 - 8:02 PM
Enthusiast ![]() Joined Jan 31, '03 From SoCal Currently Offline Reputation: 54 (100%) |
Check Out Parts Here
PLEASE READ CAREFULLY: STILL AVAILABLE: The other parts are backing plates, rotors, and calipers. This means that you provide the hubs from your ST, and pads. Also one of the e-brake lines was severed. I did not cut the line, some nutsack with scissor hands must have got his kicks under the car in the yard long before I got to it. $110 shipped within U.S.. SoCal pick-up reduced cost. If you are not familiar with the disc swap process read up on it here. First come first serve This post has been edited by WORK4POOP: May 15, 2009 - 1:41 PM |
Apr 12, 2009 - 5:01 PM
Enthusiast Joined Mar 11, '08 From eugene, or Currently Offline Reputation: 1 (100%) |
dibs... pm sent
Check Out Parts Here PLEASE READ CAREFULLY: One set includes the entire rear disc setup off of a 97' GT. This means that all the parts down to the knuckle. Parts included: rotors, calipers, backing plates, hubs, e-brake lines and shoes, knuckle, brake lines. If you plan on putting on new performance rotors I can remove these and reduce the price by $10. Otherwise the entire package is $300 shipped within the U.S.. These parts are in great condition and I will not barter on the price. If you live in SoCal I will gladly meet halfway for pick-up and give a decent price drop. The other parts are backing plates and calipers. This means that you provide the hubs from your ST, new rotors, and pads. Also one of the e-brake lines was severed. I did not cut the line, some nutsack with scissor hands must have got his kicks under the car in the yard long before I got to it. $190 shipped within U.S.. Same deal with SoCal pick-up. If you are not familiar with the disc swap process read up on it here. First come first serve |
Apr 15, 2009 - 9:30 PM
BUMP... Disc conversion parts. New reduced cost!
Apr 21, 2009 - 6:00 PM
BUMP... Backing plates, rotors, calipers.-- $130 Shipped!!!
Apr 29, 2009 - 9:13 PM
BUMP Buck ten...can't find these parts cheaper.
May 6, 2009 - 12:57 AM
Enthusiast ![]() ![]() Joined Jan 5, '05 From Upper Darby, PA(5 min away from Philly) Currently Offline Reputation: 3 (100%) |
PM Sent
| Lo-Fi Version | Time is now: August 31st, 2026 - 6:29 AM |
