> Engine swapping, From a 7th gen. GT to a 6th Gen GT...possible?
post Aug 5, 2009 - 4:00 PM
wilc4
Joined Apr 14, '09
From Moreno Valley, CA
I was at a Toyota Salvage yard puchasing new rear control arms for my 1996 Celica GT-S Vert. and the guy there was trying to sell me on a low mileage engine from a 7th gen. (I think it was a 2002) that he had on hand. Now, I don't need a new engine but I am thinking he might have let me have it for cheap enough to make it worth my while, since it has 190 HP as opposed to the 135 mine does...
He swore up and down that it would go on my car with fairly little modification. Doesn't sound right to me...anyone here done this swap or know how possible it is?
Replies (1 - 9)
post Aug 5, 2009 - 4:04 PM
I'm pretty sure there'll be a conflict with the wiring and ECU.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Aug 5, 2009 - 4:29 PM
DEATH
Joined Dec 19, '07
From tx
1. A 7Th Gen GT [2000-2005] uses a 1ZZ-GE Engine which only makes 140HP [5 more than your 5S-FE] and surrenders a few ft/lbs of torque. So this isn't an upgrade really at all. The GT-S model 7Th Gen uses the 2ZZ-GE engine which makes 180HP [On USDM ECU - More in other markets] so this would be an upgrade in power [Again I think it losses a bit of torque versus the 5S tho] except:
2. The 7Th Gen motors are all 1.8L motors that do not have the same mounting dimensions as the 2.0L+ S series engines like your 5S-FE. This means that this motor will not bolt up to the remainder of your drive train.
3. SwissFerdi is correct - you would need to have a wiring harness made up, swap to the 2000+ ECU as well as a whole host of sensors and other items the new engine would require to run.
Long story short - No. You can't swap to that motor
This post has been edited by DEATH: Aug 5, 2009 - 4:30 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Aug 5, 2009 - 4:43 PM
trdproven
Joined Aug 2, '05
From Guam
tranny axles is another thing not determined.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Aug 5, 2009 - 4:56 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Basically to sum up for you - Yes it can be done, no it won't be cheap, nor easy. You'll need EVERYTHING from under the hood of the 7th gen. You'll need custom motor mounts made as well.
So no it won't work with minor modifications. The man is just trying to make money off of you.
**** Photobucket
post Aug 6, 2009 - 11:59 PM
wilc4
Joined Apr 14, '09
Thanks! That is a big help. For what it is worth the motor was GT-S - which he was telling me I had to have for it to work since mine is a GT-S. This was part of the reason why it didn't sound right to me since my cars engine is no different than a GT...it is all suspension stuff...
post Aug 7, 2009 - 10:42 AM
how much did he want for it, im always looking for another good condition 2ZZ. i build 2ZZ engines for Lotus and Celica owners.
post Aug 7, 2009 - 11:23 AM
wilc4
Joined Apr 14, '09
$900 but I sense there was some room for negotiation.
post Aug 7, 2009 - 1:32 PM
homeboy
Joined Sep 29, '08
From Ky
not worth it. i've been searching months for a motor and going to OK from KY to pick up a 96gt motor was a better idea.
post Aug 13, 2009 - 6:42 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
why not just get a v6, more power, cheaper and easier to install
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
Lo-Fi Version Time is now: August 26th, 2026 - 10:33 PM
