> Ignition Coil on a 94 gt, can it be changed or do i need a whole dizzy..?
post Jul 15, 2010 - 6:09 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
title says it.
Also if i can change it will i need to remove the whole dizzy to do it?
is there a write up? Or even a quick how to would be much appreciated.
Thanks,
Paul
Replies (1 - 8)
post Jul 15, 2010 - 6:23 PM
stwin2
Joined Apr 9, '10
From raleigh n.c.
i think you have to replace the whole distributer
post Jul 15, 2010 - 7:03 PM
SleekCelica
Joined Mar 28, '10
From Columbia, South Carolina
You have to remove the dizzy, but you don't have to replace it. when you take the cap off, you'll see the ignition coil. There will be 2 nuts holding the wires on, and 4 phillips head screws on the bottom holding the coil to the distributor(you can't access those screws with the distributor on, that's why you need to take it off) and then boom, the ignition coil comes right out. I've got a spare coil if yours is fed speced.
1994 Celica GT, coupe, 5 speed.
Front strut brace, cherrybomb glasspack, intake.
post Jul 15, 2010 - 7:26 PM
PolliS_5S-FE
Joined Aug 29, '08
oh good. Really glad i dont need to get a whole new dizzy as i just replaced the cap and the rotor 3 days ago. Ill have to check what type is needed and see how much they are around here as im in Nz lol. Thanks Sleek, thats exactly what i was looking for tongue.gif one quick question, ive noticed alot of oil in the dizzy, on the bottom mainly.. when i take it off will i need to replace the engine oil?
post Jul 15, 2010 - 7:36 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
no, but replace the oil seal
post Jul 15, 2010 - 7:41 PM
PolliS_5S-FE
Joined Aug 29, '08
is that the distributor gasket?
post Jul 15, 2010 - 7:49 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
no. its probly called oil seal, or oring... diff from the gasket
post Jul 15, 2010 - 8:06 PM
PolliS_5S-FE
Joined Aug 29, '08
ok, thanks for all the help
post Jul 15, 2010 - 10:30 PM
SleekCelica
Joined Mar 28, '10
It's an O-ring on the distributor shaft(on the side that connects with the camshaft). You can't miss it.
Lo-Fi Version Time is now: July 28th, 2026 - 11:05 PM
