> How can I get rid of this?
post Jun 28, 2011 - 12:39 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
How can I smooth this out? The 16-year-old glue from the emblems is killer.
June '12 COTM
'95 AT200
Replies (1 - 19)
post Jun 28, 2011 - 1:03 PM
Panic
Joined May 8, '11
From England
post Jun 28, 2011 - 1:17 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Try using some Goo-gone.
Although I'm not sure if that would effet the paint or not, but the label should say.
My Celica!
post Jun 28, 2011 - 1:31 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Polishing compound, wash the area or use a quick detailer first though.
post Jun 28, 2011 - 1:44 PM
HectortheRican
Joined Dec 26, '09
QUOTE (jordisonjr @ Jun 28, 2011 - 1:17 PM) *
Goo-Gone is what I used to get the glue off. I was scrubbing for almost 40 minutes. I think those scuffed edges are the frayed edges of the clearcoat that was pretty much fused to the glue.
QUOTE (808celica @ Jun 28, 2011 - 1:31 PM) *
You think maybe those clay bars, Jon? I've been meaning to buy one to try and make my hood prettier. It's got blemishes all over it.
June '12 COTM
'95 AT200
post Jun 28, 2011 - 7:55 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
use rubbing compound (i just did mine a month ago) polishing compound you want to use after the rubbing compound of course. just alot easier then using solvents that you dont know if they will harm clearcoat or not, hell the rubbing compound works faster then solvents anyways. and just a fyi most clay bars remove contaminants in the paint, if you want to fix blemishes best to use a buffer and a few different chemicals. i suggest a porter cable 7424xp or any random orbital polisher(not the crappy walmart ones) dont be scared of a random orbital. circular buffers are what burn paint up if you dont know what your doing, random orbital is very simple to use and get the hang of!..oh yeah id still get a claybar and use it before a good waxing, to tell if you need to use the clay run the back of your hand over the paint after a wash, if it feels gritty/sandpapery it needs a claybar.good luck..
This post has been edited by opie_7afe: Jun 28, 2011 - 7:57 PM
post Jun 28, 2011 - 10:14 PM
celica-s
Joined May 9, '11
From Manila, Philippines
clay bar
post Jun 29, 2011 - 2:00 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
use some tinner and/or polish it. definitely do not use anything sharp unless you want to see scratches on the paint...
post Jun 29, 2011 - 5:15 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (celica-s @ Jun 28, 2011 - 5:14 PM) *
clay bar
think of claybar as 2000grit sandpaper
QUOTE (opie_7afe @ Jun 28, 2011 - 2:55 PM) *
claybar would be if you have bee crap stains all over your car
Hector, coming from me a person who lives for the color Black on 6's DO polishing compound first! laugh.gif not just because its the lightest out of all compounds or I dont have trust in you using highly abbrasive stuff............i'd rather keep using chemicals that take off as little as possible than..........using something that high in abbrasive-ness and you going pass the clear.
post Jun 29, 2011 - 12:43 PM
yellowchinaman
Joined Aug 11, '08
From London
Simple. Use a scotch pad and scrub it with soapy water. But you'll be left with a dull patch in which just just use a medium grit compound rub or polish to bring it back.
Thinner will remove your lacker and maybe even paint.
Clay bar will do nothing to glue and you'll be wasting money.
Sanding will destroy the paint work if yo go too deep.
This post has been edited by yellowchinaman: Jun 29, 2011 - 12:44 PM
post Jun 29, 2011 - 1:59 PM
manphibian
Joined Oct 13, '06
From UK
I think you need a machine polisher to get that looking good. Maybe go to a local paint shop, they shouldn't charge much to machine polish that little bit... You'll get much better results than trying to do it by hand.
post Jun 30, 2011 - 10:24 AM
HectortheRican
Joined Dec 26, '09
QUOTE (manphibian @ Jun 29, 2011 - 1:59 PM) *
Depending on the price, I may just do that. I have to re paint my driver side door handle because the first owner of my Celica was a very old man and apparently had a very hand time getting the key into the key hole. I'm just glad the scratches were miraculously contained to the door handle.
June '12 COTM
'95 AT200
post Jun 30, 2011 - 10:32 AM
yellowchinaman
Joined Aug 11, '08
From London
I dont think any lacquer's come off. Even if it has, you can just rub it down with 1200 grit wet n dry after, then spray about 3 layers of lacquer from a rattle can, and then flatten it when it drys with 2000 grit wet n dry and finally polish it with a compound rub. Its such a small patch you dont need a machine polish. Just elbow greese.
post Jun 30, 2011 - 11:47 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (HectortheRican @ Jun 30, 2011 - 11:24 AM) *
[Depending on the price, I may just do that. I have to re paint my driver side door handle because the first owner of my Celica was a very old man and apparently had a very hard time getting the key into the key hole. I'm just glad the scratches were miraculously contained to the door handle.
lol
My Celica!
post Jun 30, 2011 - 12:46 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Rubbing compound, and an armwrestlers forearm.
Or a palm buffer if you are lazy like me. 30 bucks at any autostore.
Yours looks pretty easy to clean up, some asshat put mine back on with liquidnails...
post Jun 30, 2011 - 8:33 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
and im not sure of any claybar thats like 2000grit sandpaper, even the not so mild clay is not as harsh as 2000grit which i wouldnt use unless the clear did come off, normal turtle wax rubbing compound and not using a electric buffer you will not go through the clear coat, unless you sit there for hours on one spot, i just had the same issue as the OP hence why i suggested rubbing compound as i tried the least aggressive methods first as anyone should do with paint correction.and should only take 5 mins with rubbing compound to remove the left over dried on adhesive. and dont use solvents as chinaman said unless its something like pure d-limonine. was gonna say for the key scratches use some polishing compound to remove the graying to make scratches less noticeable, but i forgot you have a dark colored car and not white..white paint is a biatch to keep clean
This post has been edited by opie_7afe: Jun 30, 2011 - 8:36 PM
post Jun 30, 2011 - 11:25 PM
celica-s
Joined May 9, '11
that's not lacquer came off, that's how clean your original paint was when they stuck the badge there, the surrounding paint show how fealty your paint is now. sorry for the term is used but that's what it is. the white thing surrounding the badge before you remove it are hard water deposits, detergents, rainwater / acid etc. a good rub down is what your car needs. Atleast that's how we call it here the the Philippines.
hth
post Jun 30, 2011 - 11:37 PM
azn87
Joined Aug 2, '06
From bay area
i used 50% RUBBING alcohol. make sure to wax after
post Jul 1, 2011 - 11:09 AM
HectortheRican
Joined Dec 26, '09
QUOTE (celica-s @ Jun 30, 2011 - 11:25 PM) *
hth
What would you recommend using? Rubbing compound?
June '12 COTM
'95 AT200
post Jul 2, 2011 - 5:15 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
celica-s has a good point under your emblem is that pretty paint that was not exposed to UV to fix your fading you would basicly need to get a good machine polishing done on it, if you want you can just take it to get a exterior detail(cheaper then a full detail) and ask if they will buff out all the oxidation,swirls,micro-marring and take care of where the emblem is, hell if you got other ones on the car they will remove those also usualy at no cost. just ask to speak to the detailer directly instead of the office people as they wont be the ones on your car and makes the detailers job easier because he knows exactly what you need and a nice tip helps with a good job also wink.gif.
This post has been edited by opie_7afe: Jul 2, 2011 - 5:17 PM
Lo-Fi Version Time is now: September 14th, 2026 - 4:47 AM
