> IC water pump in Open loop, Need all the info I can get
post Jul 22, 2012 - 11:28 AM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
Im considering running my Intercooler water pump in open Loop(always on while car is running) Along with that I will be running two electric air pulling fans also in open loop. Is there a how do on doing this process and also what is the pros and cons to doing this?
One more thing, if there is already a thread on this pleas post the link so I can have this thread closed. Thanks guys.
This post has been edited by Lil-Joe101: Jul 22, 2012 - 11:29 AM
Replies (1 - 5)
post Jul 22, 2012 - 11:44 AM
Lil-Joe101
Joined Dec 7, '07
*BUMP*
post Jul 22, 2012 - 11:58 AM
joe, check out my build thread, im pretty sure i put in some info about having the pump run constantly.
you will have to bypass the factory wiring where it goes into the pump, and install a couple of resistors, (i think there may be a sticky about it, called how to fix the code 54 or somthing like that) because the ecu controls the pump going on and off, and it needs to think the pump is operating as it should or it sets a code 54.
once you do that, you just wire the pump to a switched power source (a power source that comes on when the key is in the "on" position) and your good to go.
thats how mine is set up.
post Jul 22, 2012 - 12:00 PM
Lil-Joe101
Joined Dec 7, '07
Thanks Manny, I will check right now. U wouldnt happen to have a link to the thread would you?
This post has been edited by Lil-Joe101: Jul 22, 2012 - 12:08 PM
post Jul 22, 2012 - 1:46 PM
Lil-Joe101
Joined Dec 7, '07
*BUMP*
post Jul 22, 2012 - 6:34 PM
heres a code 54 fix thread with info
http://www.6gc.net/forums/index.php?showto...cooler+code+fix
another with a kinda blury pic of what the wiring should kinda look like:
Lo-Fi Version Time is now: August 28th, 2026 - 9:23 AM
