> 200 flywheel hp on a 5s-fe??, suggestions?
post Jan 28, 2004 - 4:53 PM
integra_killer
Joined Jan 7, '04
From Toronto
I was thinking about making my 5s-fe engine 200hp (all motor) at the flywheel.
I can't add a turbo because insurance will skyrocket, and a 3s-gte swap is kinda too expensive and once again the insurance will skyrocket frown.gif
Anyway, I want to make my current 5s-fe 200hp, and I was thinking about things like a cat back exhaust, headers, fuel rail, injectors, plugs, all that good stuff..
What do you guys think will get me to 200hp without a turbo or Nitrous?
and would it be worth it?
thnx!
Replies (1 - 19)
post Jan 28, 2004 - 5:02 PM
R-03
Joined Oct 30, '03
From TEXAS-1
you can try to port and polish the head, and upgrade the ecu. i think 200 is a reachable goal, i just don't know how much it will cost. i suggest you buy a used 5sfe head and have it worked on when it's done, drop it into you car. it cuts the down time, then you can sell your old one to help pay for the cost of the head gasket set.
post Jan 28, 2004 - 5:28 PM
Jabberwock
Joined Sep 22, '03
Shhhh....don't tell insurance about the swap or turbo..hehe
Well, catback, headers will give you some power but it won't help you reach the 200 by that much.
Fuel rail, injectors, and plugs won't help that much either
However it would all add up if you do the port and polish.
While doing all of that with a new ecu, you can add pulleys, cold air intake, porting the throttle body, I would say gut your cats but you wanted a cat back....
With all of that I think you would be able to reach 200+.
But I think that can lead to cost more than a turbo or swap and it would kind of become a ....race engine, so wouldn't insurance still sky rocket.
I am not really sure but that would be my opinion
post Jan 28, 2004 - 5:34 PM
integra_killer
Joined Jan 7, '04
From Toronto
yea, i would plan to add all those together...
the way insurance works in ontario is you have to declare if you ADD something to your engine (ie turbo)... with exhaust and intakes and stuff i can jsut say i "replaced" my old ones with ebtter ones, and my insurance wont go up... so this is mainly why i want to make my engine all motor 200hp (so my rates stay the same)
what do you guys mean by port and polishing the throttlebody?.. =sorry if its a newbie question, but i dont know half as much as some of you guys about all this stuff! frown.gif
This post has been edited by integra_killer: Jan 28, 2004 - 5:35 PM
post Jan 28, 2004 - 5:38 PM
ghostdog
From ny to philly
just stick with a turbo man. insurance doesn't have to know. besides you can always remove it if you have to.
to reach 200 hp n/a your gonna need a lot more than bolt ons. you're messing with the internals of the engine and that costs $$$.
post Jan 28, 2004 - 5:52 PM
SpedToe169
From Dallas, Tx
Ghost Dog is exactly right. Theres no way you're getting 200hp n/a without spinning the engine faster. That means new internals and that means $$$.
Also, you're driveability and idle will really suffer at that power level. It'll run like a banshee when you're all over it, but it'll suck ass in traffic and at low (below 5.5k) rpm.
post Jan 29, 2004 - 12:00 PM
Junior
Joined May 5, '03
From Toronto
be prepared to spend $$ to get up to 200hp all motor. New high compression pistons will be needed. connecting fods. Lightened fly wheel. New clutch to handle the power. Balanced crank, flywheel, and clutch. Port and polish head. Custom intake manifold, bigger throttle body. Underdrive pulley..... As you can see, there is a lot you can do, but money is needed. You'll have to raise compression. What part of Toronto you from?? I'm in the DonMills and Finch area.
post Jan 30, 2004 - 1:41 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
get a compression/leakdown test, if things are good, procede with:
get a new fuel pump and performanc FPR
then run a 50-75 shot of nitrous, along with basic bolt ons.
135hp stock, + 10hp for intake and exhaust, plus 50-75 shot
that puts your around 195-220 hp at the flywheel, get a remote bottle opener and turn the nitrous off to maintain good drivability and conserve the nitrous.
its a lot better than all the money it will cost to get to 200hp all NA.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jan 30, 2004 - 7:40 AM
macavely
Joined Nov 4, '02
yea i would go with what 97sccelica said... you will get to the 200hp make real easy.. plus insurence won't go up cause you can remove the bottle in a few seconds..
post Jan 30, 2004 - 11:13 AM
subsolo_21
Joined Nov 26, '03
From McKenzie, TN
What is a performance FPR?
post Jan 30, 2004 - 11:33 AM
ghostdog
From ny to philly
QUOTE (subsolo_21 @ Jan 30, 2004 - 11:13 AM)
post Jan 30, 2004 - 8:19 PM
Junior
Joined May 5, '03
From Toronto
Too bad the original question asked specified all motor.
post Jan 30, 2004 - 9:47 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Junior @ Jan 30, 2004 - 5:19 PM)
too bad its not possible to get 200hp@crank with a 5sfe staying all motor with out spending enough to do a turbo setup or swap.
post Feb 2, 2004 - 12:10 AM
Junior
Joined May 5, '03
From Toronto
i disagree, i think if compression is raised to about 11 or 12 to 1, and full head work is done... ie. cams, port and polish. it can be done.
post Feb 2, 2004 - 1:14 AM
1bwilson
Joined Aug 30, '02
From Maryland
High comp pistons
New or shot peened rods with ARP studs
Ballanced and knife edged crank
ARP head studs
Metal HG
Intake and exhaust cams regrinded by WEB cams
SS 1mm oversized feera valves
Custom valve springs also by feera
Very clean P&P on the head
Have the dome (I think thats what that is) reworked in the head for higher flow
Custom IM with a larger TB
This setup should get you in the ball field but will cost near 4k if your doing the work yourself.
While at it get a clutch, flywheel and an LSD also.
Member of Team 5sfTe
post Feb 2, 2004 - 1:44 AM
boosted_K2
Joined Aug 30, '02
From Michigan
wilson, are you talking about getting the head extrudahoned? cuz you should do that as well
No but I don't buy it
Cause I'm...
post Feb 2, 2004 - 1:56 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Junior @ Feb 2, 2004 - 5:10 AM)
Headwork alone will cost more than enough to build a turbo set-up...i know, cause i've done it... and raising the compression alone isn't gonna dramatically increase horsepower, either way, I doubt you can even break the 11's with the stock 5s pistons... lucky if you can get 11:1 comp with a shaved head... but all's not certain until done.
The hardest part I see about building a reliable all-motor 5sfe is the stroke. It has a very tall stroke, which hurts the engine's ability to revv. If not properly built, it won't last long. Revving is the how an n/a motor makes its power, and the 5sfe is limited most by that... even with all of the mods listed by 1bwilson, costing over 4k to do, the 5s still isn't a rev happy block...
post Feb 2, 2004 - 5:48 PM
Junior
Joined May 5, '03
From Toronto
i should have mentioned, raise compression with high compression pistons. Sorry 'bout that guys. I agree it cost more to do all motor then doing a turbo set up. but, the question asked all motor. how the guy wants to blow his wad is his choice. Personally, i would love to see it done and if i had money to waste, i would go all motor. Probably not all 5sfe motor, but all motor 3sge.
post Feb 2, 2004 - 10:50 PM
PlanetFuzz
Joined Mar 9, '03
From Knoxville,TN
what is port and polish?
post Feb 3, 2004 - 11:11 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (PlanetFuzz @ Feb 2, 2004 - 7:50 PM)
enlarging and smoothing out the intake and exhaust ports
they do it to the head to, around the valves, it removes hot spots and helps prevent detonation.
thats is a very very simplified description
Lo-Fi Version Time is now: May 18th, 2026 - 3:45 AM
