> whats the best turbo
post Jan 31, 2004 - 2:39 AM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
what woudl be the best turbo in your guy's opinion for the 5sfe
Replies (1 - 9)
post Feb 1, 2004 - 1:24 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
cant say, depends on your power goals and how much, if any, internal work you plan to do.
low boost/power ct26
mid range t3
higher range t3/t4 hybrid
stock internals wont handle enough to get into the peak efficiency of a t3.
This post has been edited by 97sccelica: Feb 1, 2004 - 1:25 AM
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Feb 2, 2004 - 1:04 AM
pxcr440
Joined Sep 6, '03
From hudson ,iowa
in the future when i turbo i plan on port and polish , lower compression forged pistons and stronger rods
post Feb 3, 2004 - 12:25 AM
FallenHero
Joined Dec 26, '02
From Alabama
anything ball-bearing.
post Feb 3, 2004 - 6:01 PM
BlackSTX
Joined May 17, '03
From Florence, KY
Garrett T25 ball-bearing turbo. Up to 225 hp. Plenty good for a 5sfe.
post Feb 4, 2004 - 7:35 AM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
what about Garrett GT28 for the 3sgte??? fensport makes a kit using that turbo... is it anygood... how would 22psi from that turbo compare to the ct20b. how does it compare to the T3 in spool time and max psi...
Mina
This post has been edited by XXX_Mina: Feb 4, 2004 - 7:36 AM
post Feb 4, 2004 - 9:58 AM
FallenHero
Joined Dec 26, '02
From Alabama
Is the GT-28 the
"Disco Potato?"
lol
post Feb 5, 2004 - 6:47 PM
BlackSTX
Joined May 17, '03
From Florence, KY
QUOTE (FallenHero @ Feb 4, 2004 - 7:58 AM)
Is the GT-28 the
"Disco Potato?"
lol
I don't get it... Definitely get ball-bearing. It's supposed to spool faster and be more reliable. Doesn't it also eliminate the need for oil return lines? Correct me if I'm wrong on that. I may be repeating wrong info.
post Feb 5, 2004 - 7:48 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
I think the disco potato was the 240 in scc, but, I could be wrong, but I think it was a car in scc
I cant remember why they called it the disco potato
post Feb 7, 2004 - 2:46 AM
FallenHero
Joined Dec 26, '02
From Alabama
yea, the car was nasty and brown, so the guy called it his 'disco potato'.
Anyway, they put the new turbo on and it made MAD gains, so they called the turbo 'the disco potato'
Or something,and yes, I think the ball bearing turbos are self-contained to some point.
Lo-Fi Version Time is now: May 18th, 2026 - 11:29 AM
