> 3sgte intercooler fluid flush
post Sep 1, 2014 - 12:30 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
hey guys, just wondering if i need to have the engine running for the intercooler/heat exchanger pump to work or will the key in the 'on' position work?
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
Replies (1 - 5)
post Sep 1, 2014 - 12:44 PM
enderswift
Joined Jul 12, '08
No need to run the engine, the drain on the heat exchanger is the lowest point on the system. Only a glass of coolant gets left behind
post Sep 1, 2014 - 1:11 PM
4-eyed-freek
Joined Apr 17, '10
will it need to be bled? i dont want a code 54 lol
post Sep 1, 2014 - 1:27 PM
enderswift
Joined Jul 12, '08
QUOTE (4-eyed-freek @ Sep 1, 2014 - 1:11 PM) *
Not really, the fill port is the highest point
post Sep 1, 2014 - 2:01 PM
cardshark525
Joined Jan 12, '09
From State College, PA
Empty it at the bottom, engine off.
Refill at top, engine off.
Now... The pump will suck the level down a little when you start the car and hit the gas to make the pump run.
So once you have topped it off with the engine off, I've found the best way to "finish it off" is to have the fill cap off, start the engine, and then top it off after the level gets sucked down a bit. If you don't have the pump wired to run continually it might help if you have a 2nd person just barely be on the gas, which will run the pump. Don't need to kill it, but have them holding steady just above idle.
After it's filled to the fill line with the engine running, cap it, and call it a day.
This post has been edited by cardshark525: Sep 1, 2014 - 2:04 PM
post Sep 1, 2014 - 6:42 PM
4-eyed-freek
Joined Apr 17, '10
Lo-Fi Version Time is now: May 18th, 2026 - 10:08 AM
