Apr 22, 2017 - 10:26 AM
Enthusiast ![]() Joined Jun 2, '16 From Toronto, ON Currently Offline Reputation: 0 (0%) |
I'm trying to fix this now, but just wondering if anyones had a similar problem? it will shift into gears just fine, but when I'm trying to shift right to left it doesn't want to move. anyone have a similar problem? last year i changed the clutch, flywheel, pressure plate, shifter bushings, base bushings and everything has been working fine since.
This post has been edited by Constantine: Apr 22, 2017 - 2:00 PM |
Update:
There was corrosion around the shifter bushing causing it to not shift easily right and left. sanded off the corrosion and problem solved |
| Lo-Fi Version | Time is now: May 19th, 2026 - 8:53 AM |
