> check engine light on but wont show codes
post Mar 22, 2012 - 11:45 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
So im trying to check the codes on my hatch an cant seem to get anything to work
is there a fuse the can stop anything from showing if blown
is there a diffrent way to check codes on a swapped car
I have both the obd1 an obd2 ports
i was told the obd1 would work an the obd2 was 50/50 chance
Any ideas guys i know i should have atleast one code since one of my o2 sensors is layin on the hood lol
94 st hatch my daily driver
n
post Mar 22, 2012 - 12:17 PM
rave2n
Joined May 29, '09
From Gainesville, FL
I may be wrong, but from what I understand with OBD1, you check by the flashes the check engine light produces by jumping 2 pins on the dianostic port. Are you using a reader, or that method?
post Mar 22, 2012 - 12:33 PM
Box
Joined Feb 23, '12
From Warrior, AL
Yep, OBD1 you jump between two terminals on the port and count the CEL flashes. Can't remember which two terminals, it's on here somewhere...
2001 Miata LS 5-speed
post Mar 22, 2012 - 12:34 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Both lol i get nothing eather way
Its te1 an e1
n
post Mar 22, 2012 - 1:01 PM
Box
Joined Feb 23, '12
From Warrior, AL
That's odd. Wonder if something isn't wired or connected right... I hate electrical, for reasons like this. Have you cleared the ECU? Sometimes it might hold onto old codes. But being unplugged should've cleared it. Is the engine originally OBDII? Maybe that could cause issues? Where's an experienced technician when we need one?
post Mar 22, 2012 - 1:06 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Yea its a obd2 motor an ecu but neather ports gives any info lol
n
post Mar 22, 2012 - 1:09 PM
richee3
Joined Jun 29, '08
From Denver
Seems like I read that jumping the ports doesn't work on OBDII. Could be worth looking into.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 22, 2012 - 1:21 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
For obd2 you need to plug in a scanner I believe.
post Mar 22, 2012 - 1:24 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I used a scanner on the obd2 an jumped the plugs on the obd1
Is there any kind of trick for a swapped car that idk about
n
post Mar 22, 2012 - 1:36 PM
blackceclia0823
Joined Mar 22, '12
From rhode island
I would either plug the os sensor back in or replace it. Some celica in 95 were obd1 or 2. There is a fuse for the ECU check to see if that is bad.
Curious though how many flasshes are you getting when you jump the terminals on te1 an e1?
post Mar 22, 2012 - 1:43 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Theres nowhere to plug the o2 sensor in untill the exhaust is done
im getting zero flashs when i pin te1 an e1
My kight never changes
n
Box
Joined Feb 23, '12
From Warrior, AL
OBDII have to use a scanner I believe, at least with every OBDII car I know of. That's part of the joy of OBDI. This is confusing. Maybe once everything is done it'll be code free, hopefully. Still, leaves the issue of not being able to read codes if you need to. ECU is gathering the info, and sending the alarm to the CEL. Would think it's something between the ECU and port causing the problem then. Sounds silly, could the scanner be bugging out maybe? Can't really think of anything else it'd be...
post Mar 22, 2012 - 1:51 PM
blackceclia0823
Joined Mar 22, '12
From rhode island
On newer toyota with obd2 they have Toyota code which can't be read by a normal scanner. Don't think Toyota came out with this back in 95 though. Then you have either a ECU problem or a blown fuse that goes to the ECU. Did you unplug the negative side of the batter to reset the memory? If you did then you have to run the car which is impossible as you are doing the exhaust.
like Box said get everything done first and go from there. In the meantime look at all your wires and make sure none are broken.
post Mar 22, 2012 - 1:52 PM
hhmmm, im not sure whats going on, if the CEL is on but your reader is not showing codes? is your reader actually connecting to the ECU and its saying pass? if so then perhaps something from your old wiring is tripping the CEL
post Mar 22, 2012 - 1:58 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I know the scanner works fine
I might try resting the ecu afer i get the exhaust done
n
post Mar 22, 2012 - 3:22 PM
Box
Joined Feb 23, '12
From Warrior, AL
Hopefully once exhaust is done will be good to go.
post Mar 22, 2012 - 3:28 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Its seems ti run good so im assuming the codes cant be anything major
n
post Mar 22, 2012 - 3:31 PM
so the scanner does say pass?
that leads me to believe that another wire is grounding out causing the CEL to come on.
i cant wait to get mine going, oh by the way, my 3MZ came in today.
post Mar 22, 2012 - 3:36 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (Smaay @ Mar 22, 2012 - 4:31 PM) *
The scanner comrs. Up error. Canyt connect to ecu
n
post Mar 22, 2012 - 4:02 PM
blackceclia0823
Joined Mar 22, '12
From rhode island
Did you do anything right before the light came on? Repairs or take anything appart?
Lo-Fi Version Time is now: September 11th, 2026 - 9:40 AM
