The GT-Four Brake Upgrade, ST205 Brake Upgrade for 5x100 & 5x114 PCB |
Jan 12, 2014 - 9:37 PM |
More english prease?!
The rotor sits perfect and does not hit the ball joint. But is off center to the caliper is what i'm gathering. Does it sit too much towards the inside of the car or does it sit more towards the outside? and your previous post said it was 326mm diameter...isn't it 26mm too large for the caliper as well? This post has been edited by playr158: Jan 12, 2014 - 9:38 PM |
Jan 13, 2014 - 1:18 PM |
found this on ebay, bought the last set, what are the chances...
http://www.ebay.com/itm/SET-OF-4-ALUMINUM-...04e&vxp=mtr -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jan 13, 2014 - 1:21 PM |
Enthusiast Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
make sure they dont sit higher than the rotor face!!
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 13, 2014 - 1:22 PM |
More english prease?! The rotor sits perfect and does not hit the ball joint. But is off center to the caliper is what i'm gathering. Does it sit too much towards the inside of the car or does it sit more towards the outside? and your previous post said it was 326mm diameter...isn't it 26mm too large for the caliper as well? the rotor sits perfect, and the brake surface is excellent. however i would either have to grind up to 5 mm from the caliper bracket area to even have it centered. i cannot even measure how much that rotor has to be resized, however i will post a pic in a couple of hours. the rotor sits too much towards the outside, if we could find a caliper for this rotor, it woud be awesome.... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jan 13, 2014 - 2:31 PM |
pics...
but.... to keep caliper centered.... lots of grinding.. even trying to bolt caliper outside.. using a 20 mm spacer.. so just keep it simple, and get the supras, if you are able to find some that can be drilled and someone to do it... or you want this rotor, you need to find another caliper. lots of grinding.... that puts the rotor and wheel to far away from the center of rotation, and thats a no no... -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jan 14, 2014 - 8:58 AM |
Honestly, We could easily have an adaptor bracket made for this. (IE small block of aluminum cut and drilled) So that the caliper sits in the correct place and we have a bolt on rotor.
It looks like the caliper mounting holes are sitting right on top of the knuckle holes. This would be a pretty easy adaptor to fab up. Then I could get these: . |
Jan 14, 2014 - 9:21 AM |
well actually no, because the caliper is not all the way sitting down and grasping the rotor... it still needs to be pushed down at least 10 mm, and still the holes do not align.
i was looking also at a camry spindle, looks alot like our celicas, with the difference of the mounts spaced further, giving chance of a bracket, but then again, too much trouble when u can just drill supra rotors. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jan 16, 2014 - 12:43 PM |
Gotcha.
Well like all you other nuts, I picked up a "X" rotor today. We'll see how she fits and i'll report back, it should fit minus a 7mm offset. Which is an easy $25 spacer and that's it, much easier than drilling. PS njccmd2002 I saw your thread about brake rotors and the Subaru. I assume this was your research for the STI rotor. To add information CELICA GT OEM ROTOR _____________________ Outer Dia:.....275mm Height:.........49.3mm Nom Thick:....28mm Min Thick:......26mm Hub Reg:.......55mm Bolt Size:.......14.5mm Weight:.........15lb This post has been edited by playr158: Jan 16, 2014 - 2:11 PM |
Jan 16, 2014 - 12:57 PM |
yup sti rotor
Jan 16, 2014 - 6:04 PM |
sooooooo.........BOLT ON
Rotor: Part Number: Centric 121.47021 292MM FRONT DISC *I do believe there is a 295mm disc as well* (NOTE: This is with worn ST205 OEM pads, and unconnected calipers) |
Jan 16, 2014 - 7:32 PM |
Jan 16, 2014 - 8:14 PM |
Subaru rotor? Thats good. Looks like regular impreza. Hmmm that is awesome. Maybe 2 mm shim spacers each side and perfect!!!!!
Jan 16, 2014 - 8:44 PM |
Yup BRZ, Legacy, Impreza wrx and a few others share this rotor.
I'm getting DBA 5000 two piece |
Jan 17, 2014 - 11:31 AM |
Info added! Thanks Dan!
I will be adding more info over the next few days as to our new found added options! This post has been edited by Tigawoods: Jan 17, 2014 - 11:31 AM -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 25, 2014 - 8:02 PM |
Enthusiast Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
That's a nice find. Two questions:
You removed the dust shield for the rotors right? How did you compensate for the difference in height? -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Mar 25, 2014 - 9:16 PM |
I never had dust shields on this setup with the brz rotors.
There is no compensation, put everything on normally. |
Mar 27, 2014 - 12:40 PM |
So an update to this thread would be
Front: ST205 calipers bolted on and WRX front rotors bolted on Rear: ST205 Calipers shimmed 5mm away from the bracket towards thr rotor and ST205 rotors? Now we need to find an ST205 rotor replacement since I'm guessing they're gonna get hard to find and more expensive as time goes on. The only thing I dont like about the setup is that the front brake rotors are smaller than the rears, 20mm smaller, too. -------------------- 1993 Celica GT Coupe - sold
Mar 27, 2014 - 12:45 PM |
So an update to this thread would be Front: ST205 calipers bolted on and WRX front rotors bolted on Rear: ST205 Calipers shimmed 5mm away from the bracket towards thr rotor and ST205 rotors? Now we need to find an ST205 rotor replacement since I'm guessing they're gonna get hard to find and more expensive as time goes on. The only thing I dont like about the setup is that the front brake rotors are smaller than the rears, 20mm smaller, too. that stuff had been added to the OP already. St205 rotor replacement for what the rears? If so I have a site from the UK that sells EBC oem replacements. I doubt they will discontinue them for a while. My personal experience with the larger rear rotors is that the brake bias feels ALOT more even. Braking isnt as nose heavy and the car doesnt dive forward at all during heavy braking, which I find VERY helpful when I race. -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 27, 2014 - 1:06 PM |
So an update to this thread would be Front: ST205 calipers bolted on and WRX front rotors bolted on Rear: ST205 Calipers shimmed 5mm away from the bracket towards thr rotor and ST205 rotors? Now we need to find an ST205 rotor replacement since I'm guessing they're gonna get hard to find and more expensive as time goes on. The only thing I dont like about the setup is that the front brake rotors are smaller than the rears, 20mm smaller, too. that stuff had been added to the OP already. St205 rotor replacement for what the rears? If so I have a site from the UK that sells EBC oem replacements. I doubt they will discontinue them for a while. My personal experience with the larger rear rotors is that the brake bias feels ALOT more even. Braking isnt as nose heavy and the car doesnt dive forward at all during heavy braking, which I find VERY helpful when I race. That's interesting... Yeah I was suggesting a replacement for the rears that perhaps we could find local to us. -------------------- 1993 Celica GT Coupe - sold
Mar 27, 2014 - 1:18 PM |
That's interesting... Yeah I was suggesting a replacement for the rears that perhaps we could find local to us. Ah gotchya. I think the 205 rears are out best bet. The only downsides of that rotor are the spacing of the caliper and the ebrake shoe only has half contact on the inner drum. Those arent really terrible downsides in my eyes. the company in the UK that I have listed in the OP ships super fast with tracking too I will keep my eyes open for any rotors that look like a match to the 205 rears This post has been edited by Tigawoods: Mar 27, 2014 - 1:19 PM -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Lo-Fi Version | Time is now: May 8th, 2024 - 3:31 AM |
