> 3S-GTE from 7A-FE?
post Mar 23, 2004 - 9:26 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
i was just wondering if it is at all possible to swap a 7A-FE engine for a 3S-GTE engine? whats woul dbe the best way to upgrade a 7A-FE engine?
I <3 Dustin---07/16/06
post Mar 23, 2004 - 10:43 PM
ghostdog
From ny to philly
this topic has been covered. have you tried the search function?
post Mar 23, 2004 - 10:57 PM
3SGTE...is that some sort of futuristic space shuttle?
post Mar 24, 2004 - 1:18 AM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (hurley97 @ Mar 23, 2004 - 7:26 PM)
This post has been edited by kuya1284: Mar 24, 2004 - 1:18 AM
post Mar 24, 2004 - 1:20 PM
QUOTE (kuya1284 @ Mar 24, 2004 - 1:18 AM)
post Mar 24, 2004 - 8:54 PM
RedSunCelica
From San Diego CA
QUOTE (Supersprynt @ Mar 24, 2004 - 11:20 AM)
post Mar 25, 2004 - 2:06 AM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
QUOTE (RedSunCelica @ Mar 24, 2004 - 6:54 PM)
LMAO
post Mar 25, 2004 - 3:29 AM
macavely
Joined Nov 4, '02
ya'll people are wrong.. funny none the less but still wrong..lol...
give the guy a break.. you can tell he is new at this..and he might be new to computers also..
post Mar 25, 2004 - 4:31 AM
kuya1284
Joined Nov 15, '02
QUOTE (macavely @ Mar 25, 2004 - 1:29 AM)
How is it wrong... it's the best advice that one can give to an already saturated topic. biggrin.gif
post Mar 25, 2004 - 7:58 AM
macavely
Joined Nov 4, '02
QUOTE (kuya1284 @ Mar 25, 2004 - 4:31 AM)
not really wrong but think about this if we didn't have so many repost sooner or later we would have nothing left to talk about... all the new threads would only be on the OT...
post Mar 25, 2004 - 1:28 PM
I dont think there are THAT many reposts that the entire forum is dependant upon them.
Then again nobody really talks about what their doing or anything real ground breaking because its all hush hush.
post Mar 25, 2004 - 1:43 PM
kuya1284
Joined Nov 15, '02
QUOTE (Supersprynt @ Mar 25, 2004 - 11:28 AM)
I've been sharing my stuff... it's all documented in my project diary in the Completed Swaps sticky. I update that thing whenever I do something new to my car. wink.gif
post Mar 25, 2004 - 8:18 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
he should be able to help himself, and ask a more specific question once he used the search feature.
in short, yes u can go from a 7a to a 3s.
post Mar 26, 2004 - 2:48 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
QUOTE (zipstrips @ Mar 26, 2004 - 1:18 AM)
yes, you can.... but IMO it's not worth it.....
post Mar 26, 2004 - 3:42 AM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
Why isn't it worth it.
here is how to go from 7a to 3s
www.geocities.com/zegoat2000/HOMEPAGE.html
post Mar 26, 2004 - 11:33 AM
kuya1284
Joined Nov 15, '02
QUOTE (celica3sgte @ Mar 26, 2004 - 1:42 AM)
I agree! I think sphinx can also vouch for this swap, as can Qatar and a couple others. For me, the wait was totally worth it:
Before:
After:
post Mar 26, 2004 - 11:43 AM
ghostdog
From ny to philly
damnit ray, fix up your car and submit to some magazines or somethin. its way too beautiful (and potent) to be kept under covers.
post Mar 26, 2004 - 12:58 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
the reason i say it isn't worth it..... the 4a-gze will drop right into the stock motor mounts with a 7a-fe.... and if need be, you can even use the same c52 tranny (good up to about 200hp)..... but the ae101/late ae92 e51 tranny with lsd would suffice
now... for the price..... a 3s-gte (if you pick up a low mileage one) costs more for just the motor than i've seen for several map based 4agze HALF CUTS... which is everything you could need plus more (and when you get the body panels, just re-sell them and make some of the money back). Plus you don't have any worry of custom parts.
now yes... the 3s-gte is much more potent and a much stronger engine. but with that, it is heavier, and with more power (and just FWD) you're going to have a lot of wheel hop (unless you're driving on slicks all day) whenever you try to accelerate quickly. And with the light weight of these cars, it doesn't take much to get them going.
plus the gze is just about as versatile as the 3s-gte is for upgrades.... there are even several twincharged ones out there.....
so, IMO a 3s-gte from a 7a-fe isn't worth it....
post Mar 26, 2004 - 4:17 PM
kuya1284
Joined Nov 15, '02
QUOTE (toyotaspeed_90 @ Mar 26, 2004 - 10:58 AM)
1. You can use the mounts that come with the clip or GT mounts, depending on which tranny you use.
2. Trannies are relatively inexpensive. A better tranny is worth the expense for the extra power.
3. 2nd 3S-GTE "clips" are usually around $1000 to $1500, roughly $400 more than a 4A-GZE. If you're going to spend the time, money, and effort on a swap, why not save up a little extra for this better option.
4. Custom parts? Nothing was customized with my swap, unless you call mating MR2 inner half-shafts with 1990 V6 Camry outer half-shafts a custom job.
5. Wheel hop? Yes, you'll wheel hop when you punch on the gas in 1st and 2nd gear. However, if you half-throttle, and punch it in the upper RPM's, this is negligible. It's not someone is gonna say, "Hey, I'll race you to the finish line in first gear." If you race someone from a rolling start (i.e. on the freeway, which I do not condone), there is NO wheel hop. Simply put, it's not difficult to learn how to drive a high-powered FF vehicle.
6. Overall, the pros outweigh the cons. If you're looking for SERIOUS power, I'd recommend paying the extra money for a 3S swap. If you're looking for decent power just so you can *cough* beat all those Honda's that you all have trouble beating *cough*, then go with a 4A-GZE swap.
If you need someone to do your wiring, with have a respectable member on the boards that will do it for a great price. Mike (Qatar), the wiring master, will help you setup in no time.
I can see where you're coming from, toyotaspeed. But once you've actually driven a 3S-GTE power Celica, you really won't understand that this swap is worth every penny.
Just my $0.02.
post Mar 26, 2004 - 4:18 PM
kuya1284
Joined Nov 15, '02
QUOTE (gh0st_d0g @ Mar 26, 2004 - 9:43 AM)
It'll happen in due time... I have other top priority expenses that need to be handled first. To simply put things... I'm saving to buy a house. Thanks for the support bro.
Lo-Fi Version Time is now: August 26th, 2026 - 4:28 PM
