> 7AFE radiator
post Apr 3, 2004 - 5:20 PM
edo17982
Joined Dec 21, '02
From Italy
Is the 5SFE and 7AFE radiator size the same?????
Cause I'd like to buy an aluminium one on Ebay and it's marked for GT.....
Let me know!!!!!1
post Apr 5, 2004 - 10:28 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
same chasis... should share the lower & upper mounting points (or can change the upper ones... i had to, but there should already be a hole in the core support if they're different so it's easy to do).... just find a picture of the GT rad and see if the hose positions are the same.....
post Apr 6, 2004 - 1:37 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
QUOTE (edo17982 @ Apr 3, 2004 - 3:20 PM)
Let me know!!!!!1
Nope its not the same, it wount fit, it is bad for your engine, you dont need this.... biggrin.gif biggrin.gif biggrin.gif Just joking Bro. I think it is the same thing, and if it is not, then you always have a chance to go custom on mounting wink.gif
<<<<<< DCw / JDMart >>>>>>>
post Apr 6, 2004 - 1:53 AM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
mounting really isn't an issue since how it's mounted (other than forward) doesn't affect it..... at worst you might need to find some radiator hoses that need some custom "making" to fit....
the hoses all the shops for a GTS were bringing to me (in my 4a-fe to 4a-ge swap, and using a gts radiator) were all about 1" too short... so i had to go to the back & find one similar with the bends i needed, then just cut it down....
Lo-Fi Version Time is now: August 25th, 2026 - 11:12 AM
