> Radiator Fan?, Help - it cut out, just curious
post Aug 2, 2004 - 5:08 PM
speedracer_2020
Joined Jun 22, '03
From Toronto, Ontario, Canada
So suprisingly my radiator burst! I had no clue, why, but it did. Turns out it was due to the radiator fans not spinning.
Aside from the fan motor, and fan relay..... any other reasons why it woudn't kick in?
It's frustrating, almost blew another rad!
Someone said thermostat? I have no clue how much that would cost? Is that an easy fix? Would that even relate to the fan not kicking in. I'm baffled when it comes to this part of the car. lol
Thanks,
Shaun
Replies (1 - 6)
post Aug 2, 2004 - 5:50 PM
Fingaz
Joined Jun 15, '04
From new york
lol that happened to my friends civic. something in there bent and it wouldnt turn on. eventually his engine caught on fire at a party. funniest thing i've ever seen. but i think its fixable.
good luck
post Aug 2, 2004 - 7:07 PM
Anub1s
Joined Nov 27, '03
If its the thermostat its a really easy fix. Takes the experienced mechanic like 5-10 minutes. Just look at a instruction manual. The radiator might have burst becuase the thermostat was stuck closed which would cause a lot of pressure in the cooling system, causing the said result. The thermostat should be replaced while you are in there anyways, they cost like $5-10 and like I said are relatively easy to install. Just make sure the engine is cool when you do it wink.gif. Hope that helps.
post Aug 2, 2004 - 7:56 PM
speedracer_2020
Joined Jun 22, '03
Thanks for the input guys! I've left the car with a mechanic (not mine, because it wasa holiday here in Canada, and I scrounged around to find someone closeby and open)
So hopefully tomorrow they'll have found out -- he said he's thinking it's the thermostat .. otherwise the actually fan itself. Who knows.
I hope it can be fixed, or I'm just getting a new car
(grrrr.. everyone has that I WANT A NEW CAR mood when something goes wrong.. lol)
post Aug 2, 2004 - 10:10 PM
Junior
Joined May 5, '03
From Toronto
hey, where in toronto are you? I'm at DonMills and Finch. Anywayz, if its your thermostat, get a failsafe one as a replacement. If it goes, it'll stay open and your fan will be on 24/7. This way your motor won't blow.
post Aug 3, 2004 - 12:02 PM
speedracer_2020
Joined Jun 22, '03
QUOTE (Junior @ Aug 2, 2004 - 8:10 PM)
Awesome.. I'll make sure I look into that! Thanks for the heads up!
And, I'm actually just west in Mississauga! Near Square One, but I'm always meeting clients out east for work (mostly Markham, damn Tech sector)
lol .. Where do you get parts when you need stuff? I always have a hel of a time with pricing (too high) and availability (never in stock) from Toyota directly.
I've had to be ultra resourceful..
post Aug 7, 2004 - 1:48 AM
Junior
Joined May 5, '03
From Toronto
I have really needed any parts. But the few things I needed I got the shop my friend used to work at to order everything. I was only charge wholesale price. In some case I barely saved anything.
Lo-Fi Version Time is now: August 9th, 2026 - 9:05 AM
