Aug 10, 2004 - 1:38 PM
So I've got two gauges; Oil pressure and oil temperature. They each have their own sending units that need to be mounted to an oil supply. Since it's bad to use a T-fitting or something on the block, as the engine vibrations can easily damage the T-fitting and cause an oil leak and engine damage, here is what I'm thinking.
I'll have a stainless steel 1/8" BSPT male to 1/8" NPT male adapter. This will screw into the block where the stock oil sensor goes. From the adapter, I'll have a 1/8" braided stainless steel line with NPT fittings on each end. This line will have plenty of slack and will go to the driver's side wall of the engine bay near the fuse box. The end of the line will hook up to an oil distribution block that will be bolted to the car. On the oil distribution block, all three sending units will be mounted. All of the connections will be sealed with Teflon tape. Does this sound like a good setup for my oil sensors? Any suggestions before I go ahead and buy the parts to do this? -------------------- New Toyota project coming soon...
Aug 10, 2004 - 1:58 PM
should work just fine
-------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
| Lo-Fi Version | Time is now: July 30th, 2026 - 6:38 PM |
