Nov 23, 2004 - 7:20 PM
Enthusiast ![]() Joined Nov 16, '04 From Coeur d'Alene, ID Currently Offline Reputation: 0 (0%) |
i get these power surges, my headlights get bright as well as my gauges, hvac, my stereo is affected, sub mis-hits? Its really starting to piss me off. I found a ground wire kit on ebay does anyone think it'll help? If not i open to any suggestions.
Nov 23, 2004 - 9:46 PM
alternator problem
maybe the power regulator inside the alternator -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Nov 23, 2004 - 10:01 PM
Enthusiast ![]() ![]() Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) |
sucking to much juice will cause this.... a lull in the amperage sucking will cause everything to get bright for a split second.... get this alot of your amps are drawing too much current.... get a higher rated alternator
Nov 24, 2004 - 5:36 AM
Enthusiast ![]() ![]() Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) |
Have you tried unhooking your stereo system and driving around for a few days like that. It might be your alternator like wind said. Sometimes instead of not charging enough they will start charging too much.
Nov 24, 2004 - 8:35 AM
before spending money on an alternator try getting a powercap.
Nov 24, 2004 - 12:57 PM
I know it has nothing to do with my system cause its done it since before i put my subs in.
Everything gets bright for up to like 10-20 seconds though it is usually just a quick sec. or 2. So probably my alt. huh. Would a ground wire kit help at all. |
Nov 24, 2004 - 4:14 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
go to les schwab or sears ( i've worked at both ) and get an electrical test. It test the alternator current and the charging amps while also checking the battery. its like $15 but if it solves the problem its well worth it.
-------------------- yea your 3sgte is cool but ill stick to my 7agte
| Lo-Fi Version | Time is now: September 1st, 2026 - 3:23 PM |
