Nov 27, 2004 - 2:04 AM
Enthusiast Joined Jun 23, '04 Currently Offline Reputation: 0 (0%) |
Remember when i said that my motor was knockin it wasn't spark knock, it was a warped connecting rod. It finally worked it's way out of the side of the block. So here is the ? 3sgte or 5sfte?
Nov 27, 2004 - 2:11 AM
Enthusiast ![]() ![]() ![]() Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
I would say go for the gusto and do the 3sgte swap man. That totally sucks about the engine though hopefully you get it all worked out for you.
Nov 27, 2004 - 2:00 PM
do the 5sfte... join us.. the ones that are starting and doing the turbo now..
Nov 28, 2004 - 1:53 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
stroked 3sgte
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Nov 28, 2004 - 9:14 AM
hey that was my idea!
Nov 28, 2004 - 9:56 AM
stroker kit close to 3G
Nov 28, 2004 - 12:46 PM
if your 5sfe is shot...got for a 3sgte. you get a newer, realiable turbo motor.
Nov 28, 2004 - 12:54 PM
in this case uh. why put in a 5sfe lol go for the 3sgte
Nov 30, 2004 - 5:25 AM
Thank yaw, can someone tell me if the gear ratios are the same in the 5s tranny, and the 3s. the only thing about my celica i didn't like was the low gearing. cause icould burn my cuzz's SI but i would be shifting in to 5th as he went into 3rd.
Nov 30, 2004 - 7:31 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Dont think gear ratios are exactly the same but they have to be close (g/f has a GT and i have a mr2T). The mr2turbos have very low gearing also. It feels very close to me.
Nov 30, 2004 - 9:27 AM
Enthusiast ![]() ![]() ![]() Joined Oct 24, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
No, gears are longer on the 3SGTE. The fifth especially.
Nov 30, 2004 - 9:42 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
Gearing has nothing to do with the engine that you have. If you want longer gears you need the solara tranny. That is the easiest way to go. I was thinking i wanted longer gearing too but i heard that the gearing was a little too much of a change. I cant confirm that cause i never rode in a solara or a car with the solara tran in it????
Its worth looking into, DG -------------------- ![]() |
| Lo-Fi Version | Time is now: September 21st, 2026 - 1:17 PM |
