Feb 14, 2005 - 11:50 PM
Enthusiast ![]() ![]() ![]() Joined Jan 1, '03 From LB gizzie, cali Currently Offline Reputation: 0 (0%) |
Ok so i bought a Hks ssqv blow off valve to replace my blitz dd... but there's a problem, for some reason my valve will not open or will not blow off... i tried everything (using different vac line and loosening and tightening the bolt in the back).. still... the purple valve will not blow off.... any help will be appreciated
-Ryu -------------------- [color=#FF0000] I MISS MY RED BABY =(
Feb 15, 2005 - 12:02 AM
it wont let air out at all?
-------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Feb 15, 2005 - 12:14 AM
Feb 15, 2005 - 12:17 AM
stick your finger in the opening and see if u can push the valve open
have you tried driving with it? -------------------- 1994 Celica GT4 WRC Edition
Feb 15, 2005 - 1:47 AM
i can push it in...yeah but its a little hard even after it was loosen... driving it is like driving without a bov...sigh
Feb 15, 2005 - 2:06 AM
got any pictures of it?
Feb 15, 2005 - 8:17 AM
Did u buy new or used? Looks like you need to take it apart.
Feb 15, 2005 - 9:40 AM
oh i bought it used.. i took it apart and I honestly did not know what i was looking for... all i found was a spring, a little gold plate, and the purple valve... is there a possibility that the bov is messed up or my connection is wrong somewhere.. keep in my mind that my blitz was working fine when using the same line
thanks -Ryu -------------------- [color=#FF0000] I MISS MY RED BABY =(
Feb 15, 2005 - 10:28 AM
there are realy only 2 things that would cause it not to open. 1 is a bad vac source and 2, is a broken bov.
goto hksusa.com they have a little diagram that explains how the bov works inside. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 15, 2005 - 11:10 AM
Where are you connecting it? Try the back of the manifold theres a blocked off nipple ( or so there is on the 2nd gen) and connect it there.
| Lo-Fi Version | Time is now: September 13th, 2026 - 1:30 AM |
