Feb 23, 2005 - 2:25 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
I did submit this to the how to article section, however because of several ppl asking me for the how to directly i have decided to put it up as a thread and when ever it gets reviewed as a "how to" it gets reviewed.
"Usual disclamer" GT CAI How To (this also works for the ST celica as well) Tools and parts: Metric socket/ratchet set Screw driver Hack saw Dremel ¾ inch hole saw Permanent marker 90-93 Honda accord CAI system (2 piece 2¾ in. pipe) The Concept Design: ![]() Step 1: Prep Take out the stock air-box. This is done by disconnecting it from the throttle body, Unbolting the air box as well as taking out the resignation from the front fender (note; this is where the air filter will go). When taking out the air-box you will have to disconnect a breather tube as well as a temperature sensor. The temp. sensor can simply be puledl/wiggled free from the rubber flange that holds it on. After pulling the temp sensor out remove and save the rubber flange. ![]() Step 2: More prep Next thing on the list is to take out or rather detach the fuse box from the car. To do this there are three bolts. Two are under the cover, one is in the back and one is on the side. The third bolt holding the fuse box down is in the front and at the bottom. At this point take note of the bottom of the fuse box as it will be attacked by the friendly dremel. Step 3: Modify “S” pipe Now with the engine bay free of the stock air-box its time take a look at how the piping from a 90-93 accord CAI system will be used to route a CAI system for our GT’s. There are two pieces of pipe in the accords CAI package. The first piece has an “S” type shape as well as a small pipe for a breather tube. The second piece is shaped more like an “L” and this is the pipe that will be routed through the fender where the filter element will be mounted. ![]() ![]() Test mount the S pipe to the throttle body using the supplied couplers. Next take the L pipe and stick the short end down and into the hole that’s in the fender. If you care about scraping the finish make sure you’re careful when navigating the pipe around the fuse box and into the hole as well as placing cloth anywhere needed. With both pipe soft mounted you will see that the second bend from the throttle body routes the pipe on a tighter angled vector then is needed to mount up to the L pipe properly. Luckily the L pipes length is just perfect and it reaches all the way out to the second bend on the S pipe and ends just exactly where the cut in the second bend needs to be made. Use the permanent marker to mark off where the cut on the second bend of the S pipe needs to be made and take Mr. Hacksaw to it. Clean off the edge as well as any stray derby and or saw dust. ![]() ![]() ![]() Step 4: Modify “L” pipe At this point the only piece of pipe that should be cut is the second bend on the S pipe. The L pipe should be untouched, but not for long. After cutting the second bend on the S pipe a coupler should be able to link the S pipe to the L pipe, which should be routed through the hole and down into the front fender area. With the front left-hand splash guard off the filter element should be able to be mounted on to the shorter end of the L pipe that’s sticking through the hole. You might note that there is more pipe then needed sticking though the hole. Test mount the filter element to see how much of the pipe needs to be taken off. If the pipe is too far into the filter element it probably will lead to airflow restrictions but it will be louder because of this. If your planing on fitting a bypass valve as i have done a section of pipe is going to have to cut to allow the fittment of the bpv. It is best to make the cut on the L pipe rather then the s pipe. ![]() ![]() Step 5: Temperature sensor With the S pipe soft mounted to the L pipe, now would be a good time to figure out where you want to drill the hole that will mount the temp sensor. Chose a place and make sure that the sensor will reach it. Then use a ¾ inch hole saw to make a hole in the pipe. The hole should be the same size as that on the air box which held the rubber flange for the temp sensor. Slip the flange onto the hole and test fit the temp sensor. ![]() ![]() Step 6: Fuse box modification Now with the pipes cut and mounted you should be able to try to mount the fuse box back in its original location. When doing this you should be able to see what and how much of the fuse box needs to be taken off. The bottom of the fuse box can be taken off, this exposes the plug. All that needs to be shaved off is some of the sides and bottom of the fuse box as well as some of the plug. This step is best done with a steady hand and a dremel with a “cut off” blade. A slow yet steady approach is a good idea. If you don’t want to bust out the dremel then the fuse box can be left alone and either secured by zip ties or longer bolts can be used to hold the box in to place via stock mounting points. ![]() Step 7: All done Now that the pipes are cut, the hole for the temp sensor is made, and the fuse box is modified the pipes should be able to be mounted using the couplers and air filter that it came with. After getting everything back together start the car and enjoy the sound of cold air intake. ![]() Here are a few other member's setups as well ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() (another method) ![]() ![]() (the INJEN SRI) ![]() Notes: EBay has the cheapest 90-93 accord CAI systems, but make sure it is the two piece type like the one on Pro Car Parts. Some 90-93 accord CAI piping have two breather tubes rather then just one. From my experience with Pro Car Parts and EBay, the chrome set has two where as the powder coated one only has one. the use of a bypass valve. It is not needed to work properly however it is something you can ad on to protect against hydrolock. Keep in mind that inorder for hydro lock to take place almost the whole filter element needs to be submergered in to water. This would have to be avery deep puddle. I drove around with no bypass for a long while with no troble. I put it on when it started to rain heavily and because a shop i was checking out had one in stock. WARNING Must use 2.5 inch pipe if not moding the hole below the fuse box. If you use 2.75" pipe the sides of the hole will rub a cut into the pipe. If you use 2.75" cut the hole larger. This post has been edited by presure2: Jan 22, 2009 - 9:34 AM
Reason for edit: added pics to 6gc photobucket
urbandork CAI GT how to. Feb 23, 2005 - 2:25 AM
urbandork http://img.photobucket.com/albums/v510/urbandork/G... Feb 23, 2005 - 2:35 AM
Fietsbel *picss doens;t work* Feb 23, 2005 - 2:40 AM
urbandork grrr cant figure out how to get all pix to work so... Feb 23, 2005 - 3:01 AM
Fietsbel I placed youre photo;s on mine webspace: Feb 23, 2005 - 4:24 AM
wuhukf What do you do with the breather hose that comes w... Feb 23, 2005 - 10:59 AM
operative Thank you all, this is the first detailed instruct... Feb 23, 2005 - 11:03 AM
LewFX how is this 20-30 bucks? the bypass valve alone is... Feb 23, 2005 - 12:03 PM
Digndoug QUOTE(LewFX @ Feb 23, 2005 - 5:03 PM)how is t... Feb 23, 2005 - 12:08 PM
urbandork QUOTE(Digndoug @ Feb 23, 2005 - 5:08 PM)QUOTE... Feb 23, 2005 - 3:03 PM
LewFX not to be rude or anything, but for people who fol... Feb 23, 2005 - 12:18 PM
urbandork QUOTE(LewFX @ Feb 23, 2005 - 5:18 PM)not to b... Feb 23, 2005 - 2:56 PM
operative What is better, diameter 2 1/2" or 2 3/4... Feb 23, 2005 - 2:05 PM
urbandork In responce.
First off the price of jsut the CAI... Feb 23, 2005 - 2:50 PM
Bigmeanbulldog55 Some one please make this into a "HOW TO.... Feb 23, 2005 - 9:30 PM
Redline_Racer Awesome bro here is mine, I made it out of Mandrel... Feb 24, 2005 - 12:12 AM
snowbunny QUOTE(Redline_Racer @ Feb 24, 2005 - 12:12 AM... Oct 15, 2005 - 11:13 PM
LewFX okay so which version is better!!! and... Feb 24, 2005 - 12:42 AM
urbandork QUOTE(LewFX @ Feb 24, 2005 - 5:42 AM)okay so ... Feb 24, 2005 - 2:42 AM
Redline_Racer I'll be honest, I like Urban Dorks set up bett... Feb 24, 2005 - 2:44 AM
urbandork QUOTE(Redline_Racer @ Feb 24, 2005 - 7:44 AM)... Feb 24, 2005 - 2:51 AM
Redline_Racer Either way Urban our cars sound beastly and better... Feb 24, 2005 - 2:54 AM
urbandork QUOTE(Redline_Racer @ Feb 24, 2005 - 7:54 AM)... Feb 24, 2005 - 2:59 AM
LewFX http://www.lewfx.com/celica/DSCF0001.JPG
if you w... Feb 24, 2005 - 9:49 PM
urbandork how big is the pipe. looks like 2.25 or 2.5 inch. ... Feb 24, 2005 - 10:56 PM
duga10 there are many sizes being quoted of the pipe that... Feb 25, 2005 - 2:28 AM
urbandork if memory servs its 2.25 Feb 25, 2005 - 2:47 AM
LewFX the injen is 2.5 inches Feb 25, 2005 - 11:17 PM
soltrain This really really needs to be put into the how-to... Apr 3, 2005 - 10:16 PM
urbandork lol i already fowarded it in the how to section. i... Apr 4, 2005 - 12:46 AM
operative I just installed an Accord CAI into my celica yest... Apr 7, 2005 - 10:56 AM
LewFX QUOTE(operative @ Apr 7, 2005 - 10:56 AM)I ju... Apr 22, 2005 - 1:52 PM
urbandork yes as its posted in the parts list the pipe shoul... Apr 7, 2005 - 11:04 PM
urbandork bump for that guy Apr 22, 2005 - 12:53 PM
LewFX bout the 90 accord version as well, took about an ... Apr 22, 2005 - 1:50 PM
operative aite guys, I've loaded a pic to my profile of ... Apr 23, 2005 - 10:03 PM
king_wsk QUOTE(operative @ Apr 23, 2005 - 10:03 PM)ait... Apr 25, 2005 - 1:12 AM
king_wsk I lied, I was so excited to get my CAI, I just ins... Apr 26, 2005 - 2:08 AM
urbandork QUOTE(king_wsk @ Apr 26, 2005 - 7:08 AM)I lie... Apr 26, 2005 - 2:36 AM
LewFX ill try to post pics of mine as well when i get my... Apr 26, 2005 - 1:15 PM
blu94gt Not to bring back a thread from the dead, but I ju... May 5, 2005 - 11:29 PM
dahoman9 bump Jun 29, 2005 - 8:45 AM
DmVinny Obviously this should work for the ST (7afe) as we... Jul 23, 2005 - 7:03 PM
urbandork depends on the placement of the intake manifold is... Jul 25, 2005 - 3:52 AM
DmVinny I'll give it a shot after my car comes back fr... Aug 5, 2005 - 3:58 PM
Akimbo urban give me a link of the right intake to buy Aug 5, 2005 - 6:04 PM
LewFX ebay...90-93 accord cai...2 piece Aug 5, 2005 - 6:18 PM
dabbill I bought a CAI for my car ST off ebay for like 30... Aug 7, 2005 - 10:03 PM
LewFX My new re-routed cai, works nicely Aug 14, 2005 - 12:40 AM
Akimbo Hmm...so you sure as hell should have a bypass val... Aug 14, 2005 - 10:17 AM
LewFX i covered it back up with the plastic shield, just... Aug 14, 2005 - 10:20 AM
chicklover345 I found a ton of bypass valves all diff sizes too ... Aug 14, 2005 - 12:35 PM
urbandork WARNING Must use 2.5 inch pipe if not moding the h... Aug 18, 2005 - 11:55 PM
Jaws4God Well I finally got my cold air intake done...well.... Sep 11, 2005 - 12:49 AM
Akimbo easy? Sep 11, 2005 - 1:14 AM
Jaws4God not completely easy.. but it wasn't anything d... Sep 11, 2005 - 1:20 AM
urbandork right on man. im glad to c the how to did someone ... Sep 11, 2005 - 3:03 AM
Jaws4God only problem is the filter is pushing into the fen... Sep 11, 2005 - 2:36 PM
king_wsk QUOTE(Jaws4God @ Sep 11, 2005 - 2:36... Jan 9, 2007 - 7:05 PM
Boss-Celica Got bored so I decided to do this.
Works pr... Oct 12, 2005 - 10:38 PM
Bigmeanbulldog55 Is that a 96 engine in your car Boss-Celica? I ha... Oct 13, 2005 - 9:13 AM
urbandork QUOTE(Bigmeanbulldog55 @ Oct 13, 2005 - 2:13 ... Oct 14, 2005 - 3:35 AM
Boss-Celica QUOTE(Bigmeanbulldog55 @ Oct 13, 2005 - 10:13... Oct 13, 2005 - 5:22 PM
blu94gt QUOTE(Boss-Celica @ Oct 13, 2005 - 5:22 ... Oct 14, 2005 - 1:02 AM
Bigmeanbulldog55 QUOTE(urbandork @ Oct 14, 2005 - 4:35 AM)QUOT... Oct 14, 2005 - 10:45 AM
urbandork valve cover to TB and there was another from the b... Oct 15, 2005 - 8:46 PM
urbandork Its been discovered that this cai also works for s... Mar 15, 2006 - 7:47 AM
j0e_p3t hey cool... i'm a part of the sticky. Mar 15, 2006 - 5:12 PM
pimpstarr690 Im just putting this out there....Saves you time a... Mar 15, 2006 - 9:22 PM
bojangles_8686 Yay I put mine in today... there are some adjustme... May 8, 2006 - 9:18 PM
brianforster looks good chucks, hows it sound? i know youve had... May 8, 2006 - 9:48 PM
j0e_p3t good job. where's your battery? May 9, 2006 - 1:07 AM
bojangles_8686 QUOTE(j0e_p3t @ May 9, 2006 - 2:07 A... May 9, 2006 - 10:19 AM
j0e_p3t oic. now get a bypass filter.... just in case. May 9, 2006 - 5:51 PM
6gsillyca where is a good place to get a by-pass filter? May 26, 2006 - 1:07 PM
bojangles_8686 ebizzle May 26, 2006 - 1:59 PM
Negative I just noticed that the hole between the stock air... Jun 6, 2006 - 10:37 AM
j0e_p3t i'm pretty sure a bypass valve prevents hydrol... Jun 8, 2006 - 10:22 PM
vozizm HOLD UP!!!
All i have to nuy is a Acco... Sep 21, 2006 - 8:56 PM
vozizm I take it this one will work with this mod? Sep 22, 2006 - 8:07 PM
LewFX if you get the accord cai, most the time the 2 pip... Sep 22, 2006 - 8:19 PM
vozizm aem is not cheap!!!
aem does not sh... Sep 22, 2006 - 8:35 PM
LewFX its carb legal! and not cheapy piping Sep 22, 2006 - 8:35 PM
vozizm but i found an ijen Sep 22, 2006 - 8:36 PM
LewFX injens for our car are SRI. Sep 22, 2006 - 8:37 PM
vozizm excuse my dumbness what is SRI?
I could not find... Sep 22, 2006 - 8:57 PM
6strngs QUOTE(vozizm @ Sep 22, 2006 - 6:57 P... Sep 22, 2006 - 9:53 PM
vozizm 10-4
IM NOT TOOO BRIGHT SOMETIMES!!
... Sep 22, 2006 - 10:04 PM
Bitter any idea if this works with the ST or possibly a 7... Mar 2, 2007 - 10:58 PM
99GT Just wondering what is that thing under the stock ... Oct 1, 2007 - 8:21 AM
twitchh17 does anyone know a reputable seller on eBay that s... Oct 5, 2007 - 8:23 PM
Daftboy it would bog down Nov 7, 2007 - 3:24 AM
njccmd2002 after a while. i finally decided
hope i get 100... Apr 22, 2008 - 1:40 PM
j0e_p3t it helps to put a trd sticker on the piping. Apr 22, 2008 - 2:52 PM
njccmd2002 cannot believe all this junk came from a tiny spac... May 4, 2008 - 5:53 PM
6GenCelicaST yeah it does have a vacuum cleaner sound to it bec... May 4, 2008 - 6:28 PM
njccmd2002 With the brackets i used, i can even manipulate th... May 5, 2008 - 7:37 AM
njccmd2002 my car has a cold with a deep raspy voice......
... May 6, 2008 - 11:27 AM
Sinyk I removed my CAI in favor of an SRI. I like the so... May 6, 2008 - 11:31 AM
97celiman http://www.diynetwork.com/diy/ab_engine/ar...48889... Jul 4, 2008 - 11:17 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 9:55 AM |
