Apr 5, 2005 - 7:43 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jun 21, '03 From Pennsylvania Currently Offline Reputation: 3 (100%) |
I am waiting to hear back from the few harness people that i have just done to confirm....... but i am pretty sure i figured out the problem.
If you dont have the ac working in your swapped car you can pm or aim me and i can walk you through how to fix the wiring to get it working. DG -------------------- ![]() |
Apr 5, 2005 - 7:45 PM
pm sent!
Apr 5, 2005 - 8:39 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Dave you are awesome !
-------------------- ![]() I will return one day. |
Apr 5, 2005 - 9:02 PM
I will just do this to mke my life easier....
3SGTE AC Fix Plug IM1(behind glove box) Im1 #1 goes to E8A # 21 Im1 #2 goes to E8A # 10 Im1 #3 goes to AC #3 Im1 #4 goes to AC # 1 Im1 #5 goes to AC # 2 Im1 #6 taps into II1 # 3 and to IG1 # 14 Im1 #7 goes to EA8 # 7 AC Plug (from the compressor) ac plug #1 goes to IM1 # 4 ac plug #2 goes to IM1 #5 ac plug #3 goes to IM1 # 3 ac plug #4 taps into EA1 # 10 -------------------- ![]() |
Apr 5, 2005 - 9:06 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 16, '03 Currently Offline Reputation: 1 (100%) |
DG performance. --- why dont u show up and show your car at HIN in Atlantic city? join me plyr , dro, jdogg.(who ever else is coming)
Apr 6, 2005 - 3:50 AM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
Im pretty sure when Doge got his swap done his A/C worked just fine coming from a alltrac clip.
DTE -------------------- I am a thief.
do not buy anything from me. |
Apr 6, 2005 - 12:15 PM
QUOTE(Clipsetuner @ Apr 6, 2005 - 3:50 AM) Im pretty sure when Doge got his swap done his A/C worked just fine coming from a alltrac clip. DTE [right][snapback]267236[/snapback][/right] thats because doge did his wiring differently then we did. he is using 2 harnesses and only rewired the basic stuff that had to be done and left everything else stock. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 6, 2005 - 3:10 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '03 From Appleton,WI Currently Offline Reputation: 0 (0%) |
QUOTE thats because doge did his wiring differently then we did. he is using 2 harnesses and only rewired the basic stuff that had to be done and left everything else stock. Is there something wrong with doing that? -------------------- ![]() A Jaws4God Creation... |
Apr 6, 2005 - 3:37 PM
nothing "wrong" with it, but you have 2 harnesses and 2 fuse boxes in your engine bay. this makes for a messy bay with lots of clutter.
Apr 6, 2005 - 3:55 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
I know Gee, DMC and Chrobis had AC swaps just fine
Apr 6, 2005 - 5:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
us Upper East Coasters do things differently
(though not me -------------------- ![]() |
Apr 6, 2005 - 9:21 PM
so, once we have the ac wiring done. does anyone know what needs to be done to recharge the ac system? does it need bleeding?
Apr 6, 2005 - 9:50 PM
You need to put your car on a vac pump for a hour or so and get the system completely pumped down..... then you test its ability to hold pressure,,,, if it is good then you recharge your ac system with new coolant
It is actually really easy to do but will cost you a bunch !!! DG -------------------- ![]() |
Apr 7, 2005 - 12:16 AM
QUOTE(SoundSlut_dotcom @ Apr 5, 2005 - 7:06 PM) DG performance. --- why dont u show up and show your car at HIN in Atlantic city? join me plyr , dro, jdogg.(who ever else is coming) [right][snapback]267087[/snapback][/right] when is the show, i have not been able to do anything celica related cause the house i just bought was taking up all my time. I can try to go if it is not real soon? -------------------- ![]() |
Apr 7, 2005 - 12:35 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
all the way in september bro, u got plenty of time.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 7, 2005 - 12:36 AM
while on the topic, does AC use refridgerant(forget real name)?
Apr 7, 2005 - 3:32 PM
QUOTE(Consynx @ Apr 6, 2005 - 10:36 PM) while on the topic, does AC use refridgerant(forget real name)? [right][snapback]267578[/snapback][/right] yep, new stuff used is called 134a -------------------- ![]() |
Apr 7, 2005 - 3:46 PM
yea, R-134a...
but here... i'll grab the "technical name" Tetrafluoroethane -------------------- ![]() |
Apr 7, 2005 - 3:52 PM
![]() Enthusiast ![]() ![]() Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
dont they use hfc-134a on cars now?
Apr 7, 2005 - 4:13 PM
134a is prob universal, i believe the R is just for refridgerator/-ant...
134a is prob the composure -------------------- ![]() |
| Lo-Fi Version | Time is now: May 19th, 2026 - 11:24 AM |
