May 31, 2005 - 2:09 PM
Enthusiast Joined May 19, '05 From tampa,FL Currently Offline Reputation: 0 (0%) |
does anyone know where i would be able to find a turbo kit for the 2.2l celicas?...
May 31, 2005 - 2:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
buy: a CT26 turbo and a ST185 manifold. go to johnnyracecar.com and get a intercooler of appropriate size, get on E-bay and buy a BOV and a 12:1FPR and then buy associated oil and vaccume lines.
BAM, you have a basic turbo kit i just made in like...30 seconds. NOW, go through and search for each of these parts here and on http://celicatech.com/ for more info. Read all you can about the associated parts and what to look for. You will then have the basis for the knowledge needed to 'attempt' this upgrade. INFO, I am feeling generous, so here. I did most of the searching for you. http://www.celicatech.com/forums/showthread.php?t=4951 http://www.celicatech.com/forums/showthread.php?t=98 http://www.6gc.net/forums/index.php?showtopic=5574 This post has been edited by FallenHero: May 31, 2005 - 3:01 PM |
May 31, 2005 - 3:09 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(FallenHero @ May 31, 2005 - 12:58 PM) buy: a CT26 turbo and a ST185 manifold. go to johnnyracecar.com and get a intercooler of appropriate size, get on E-bay and buy a BOV and a 12:1FPR and then buy associated oil and vaccume lines. BAM, you have a basic turbo kit i just made in like...30 seconds. NOW, go through and search for each of these parts here and on http://celicatech.com/ for more info. Read all you can about the associated parts and what to look for. You will then have the basis for the knowledge needed to 'attempt' this upgrade. INFO, I am feeling generous, so here. I did most of the searching for you. http://www.celicatech.com/forums/showthread.php?t=4951 http://www.celicatech.com/forums/showthread.php?t=98 http://www.6gc.net/forums/index.php?showtopic=5574 [right][snapback]293650[/snapback][/right] man fallen we need to get that tech section up -------------------- yea your 3sgte is cool but ill stick to my 7agte
May 31, 2005 - 3:10 PM
May 31, 2005 - 3:19 PM
QUOTE buy: a CT26 turbo and a ST185 manifold. go to johnnyracecar.com and get a intercooler of appropriate size, get on E-bay and buy a BOV and a 12:1FPR and then buy associated oil and vaccume lines. BAM, you have a basic turbo kit i just made in like...30 seconds. sounds like a recepie for a blown motor right there. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 31, 2005 - 3:41 PM
hey thanks fallen....so the manifolds from the st185 will fit on the 2.2 oi'm gussing....i'm new to the toyota world i dont know **** about them so thanks all
This post has been edited by 94flgt: May 31, 2005 - 3:44 PM |
May 31, 2005 - 3:48 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
ya wanna know how to turbocharge your 5sfe. presure2's the man. read his thread.
May 31, 2005 - 3:53 PM
QUOTE(presure2 @ May 31, 2005 - 1:10 PM) http://www.6gc.net/forums/index.php?showtopic=23187 my .02$ [right][snapback]293662[/snapback][/right] yeah the GT one is up there but no st we should put up a turboing your celica and have the 5sfe and 7afe in the sub title but still people dont see it for some reason but we have 6 stickys in the section alone i think we could do with out one or two of them since the 2jz celica sticky went in we have had less question about the 3sgte quited down alittle too but the turbo questions are always being asked i get like 2 or so every day about 7afte question because no one sees the 7afte how to thats just my.02 cents -------------------- yea your 3sgte is cool but ill stick to my 7agte
May 31, 2005 - 5:21 PM
QUOTE(lagos @ May 31, 2005 - 1:19 PM) QUOTE buy: a CT26 turbo and a ST185 manifold. go to johnnyracecar.com and get a intercooler of appropriate size, get on E-bay and buy a BOV and a 12:1FPR and then buy associated oil and vaccume lines. BAM, you have a basic turbo kit i just made in like...30 seconds. sounds like a recepie for a blown motor right there. [right][snapback]293667[/snapback][/right] You didn't include the research area. I was just laying the basis for understanding. and yes, we need a tech section up ASAP. |
May 31, 2005 - 10:48 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
my set up/parts list so far
3sgte exhaust manifold, down pipe, oil pan, ct26, 2 bar map sensor. coolant and oil lines apexi safc2, msd btm ngk bkr7es11 sprak plugs, 315cc injectors, 255lph fuel pump intercooler pipe, front mount intercooler, ssqv blow off valve needed gaskets and other odds and ends. This post has been edited by urbandork: May 31, 2005 - 10:50 PM |
| Lo-Fi Version | Time is now: August 25th, 2026 - 5:59 PM |
