Jul 19, 2005 - 2:05 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
First of all, Nik, i recived them FINALLY
Second - GZE pistons are full floating, wrist pin is floating in pin insert on GZE rods. I thought doing this the same on 7A rods, and making GZE pistons full floating on 7A rods.. But.. 7A pistons wrist pins are pressure fit to the rod, this means there is NO WRIST pin insert in rod, NO oil drain for wrist pin. If you wanna make GZE pistons full floating you have to rework 7A rod top end. This means you have to put the wrist pin insert and make oil drain on the of the rod. For making 7a rods with inserts, you would need to mashine the top end hole about 2 mm, then put the insert in and get it polished till the right diameter (i know im using not the right word with "polishing" but some guys will know what im talking about So the only chance is left go pressure fit with the GZE pistons, and forget about reworking the 7A rods... you will have stronger pistons, but only one chance if detonation will apear, cuz only one place would float fully. -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Jul 19, 2005 - 11:01 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
sorry thats all i had to send it in at the time next time just a plain box
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Jul 19, 2005 - 3:04 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
At least the rods are solid...the 7A-FE pistons really suck...they are porous as hell and very light. I cannot believe they are so crappy. You can look at the the wrong way and they'll crack like chalk.
| Lo-Fi Version | Time is now: August 28th, 2026 - 1:41 AM |
