> JDM Tails Help, I've got jdm tails =]
post Jul 20, 2005 - 11:28 PM
DSRT-FX
Joined Sep 13, '04
From Sydney/Australia
Hey guys!
Just need help with my JDM tails, do both the red parts in the tails turn on when the light is on? i've seen it on pics and mine isnt the same. I know they are 4 light bulbs 1 - Turn signal 1 - Reverse 2 - Red Parts. Im thinking it may be just my light bulbs or my wiring, what do you guys think? -R
ROM-23L 67 + 76 = 143
"I wasn't pursuing Sephiroth, I was being summoned by him." - Cloud Strife
post Jul 20, 2005 - 11:59 PM
you are in AU, the wiring is different. The inner reds do not light up for you correct ? That is normal, the inner on the driver's side is for the standard euro rear fog.
post Jul 21, 2005 - 12:00 AM
Chanh55
Joined Jun 29, '03
Here's what mine looks like...
When your lights are turned on, you should see total of 4 red strips, 2 on each side.
Hope that helps.
post Jul 21, 2005 - 8:43 AM
DSRT-FX
Joined Sep 13, '04
hey 6gc'rz
thanks for the replies, yes i am from AU, i do have the original wiring with me, although they are cut at the end. how hard is it to wire them up i really want the look of chanh55 jdm tails. thanks a bunch =] -R
post Jul 21, 2005 - 10:21 AM
dahoman9
Joined Mar 1, '04
From Louisville, KY
QUOTE(Sthen @ Oct 25, 2004 - 3:49 AM)
you have to connect the white/green wire(stop light) to the black/red wire(rear for) using a diod, do you also put a diod between relais and rear fog light
[right][snapback]198791[/snapback][/right]
taken from the new custom look for JDM. I asked about it long ago before I got my JDM's but then I found out that my tails already does it when I got it in.
post Jul 21, 2005 - 11:01 AM
Kadett
Joined Mar 17, '05
From The Netherlands
Well if you ordered the complete wiring harness with the lights then you would have the 4 lights. I have it anyways. Replaced the old one. But fog light does not work anymore. Whos complaining smile.gif
post Jul 23, 2005 - 12:22 AM
hey read this...
http://www.6gc.net/forums/index.php?showtopic=25974&hl=fogs
post Jul 23, 2005 - 2:27 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
ive just updated that thread, with pics of what mine look like now. but yeah, our aus. celicas dont have both the red parts lighting up when headlights are on or braking, usually.
post Jul 23, 2005 - 3:55 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I don't know about the rest of you, but I have 3 lights light up on my taillights when I turn my lights on. I thought that was normal. Most of the time I just see people running 2 back there, I just thought they had 2 burnt out.
Live Free, Be Happy
post Jul 23, 2005 - 4:14 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
yeah, apparently its a thing with australian cars.
post Jul 23, 2005 - 6:48 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
My one lights up all four
6GC 4 Life Baby!!!
post Jul 23, 2005 - 8:59 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
haha.. good thing i put 'apparently'. i guess its only some. weird.
post Jul 23, 2005 - 9:58 AM
shin
Joined Aug 21, '04
From New York City
both of mine lights up.. here's pics
~*MuH NeW RiDe*~
post Jul 23, 2005 - 10:34 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
weird. that doesnt look like mine at all. only half of each red section lights up.
post Jul 23, 2005 - 11:51 AM
DSRT-FX
Joined Sep 13, '04
- thats because he has the JDM Tail Lights. Thats what i want mine to look like when i turn on my headlights, hmm might just go to an electrician unless someone can make a how-to on re-wiring the brake lights using a diode or whateva tongue.gif
post Jul 23, 2005 - 11:55 AM
CoSo
Joined Jun 8, '04
From Perth, Australia
Shadow, your comparing the aussie taillights to the late spec JDMs, they're not the same in design. The difference between the aussie ones (which I think they might be the early spec JDMs) and the USDM ones is that:
a. Aussie tails don't have the red corners.
b. The inner half section doesn't light up as its not wired.
I believe in regards to the late spec JDM tails, either the 2 outer block section things lights up (as Fietsbel had before he rewired IIRC) or both light up.
This post has been edited by CoSo: Jul 23, 2005 - 8:44 PM
post Jul 23, 2005 - 11:56 AM
Kadett
Joined Mar 17, '05
Didn't your JDM ligths come with wiring attached.
post Aug 3, 2005 - 6:25 AM
DSRT-FX
Joined Sep 13, '04
hey 6gc'rz,
i've fixed the problem with the inner rear red bulbs. i simply hardwired the existing light bulb with the one thats working, since my jdm tails wiring harness was **** thanks for the help guys tongue.gif -R
post Aug 3, 2005 - 7:21 PM
QUOTE(DSRT-FX @ Aug 3, 2005 - 6:25 AM)
hey 6gc'rz,
[right][snapback]319869[/snapback][/right]
that would be the best and easiest way.
Lo-Fi Version Time is now: August 22nd, 2026 - 6:09 PM
