Aug 12, 2005 - 12:52 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
well since my motor is going in as we speak i was looking into getting a water injection system
i looked around but does anyone know a good reliable system? And is anyone running one? -------------------- yea your 3sgte is cool but ill stick to my 7agte
Aug 12, 2005 - 1:25 PM
double post
This post has been edited by jgreening: Aug 12, 2005 - 1:28 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
I have heard good things about Aquamist. There is a guy on the MR2 boards that makes ones with better pumps and lines that aquamist. His name and system are known as the "Joe O." water injection kit. He made it for the 3sgte. I am not sure if it has any components that are specific to that engine. His kit has gotten rave reviews on the MR2 board.
I am not going to run water injection because I do not plan to push my engine to its limits. I do think its a good idea when you do though. The one thing you should remember is that if you tune for water injection and then have a clogged line, pump failure, or empty resavoir, you could induce detonation. Bottom line: if you get water injection, check regularly that your system is working properly. This post has been edited by jgreening: Aug 12, 2005 - 1:29 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Aug 12, 2005 - 1:40 PM
QUOTE(jgreening @ Aug 12, 2005 - 11:28 AM) I have heard good things about Aquamist. There is a guy on the MR2 boards that makes ones with better pumps and lines that aquamist. His name and system are known as the "Joe O." water injection kit. He made it for the 3sgte. I am not sure if it has any components that are specific to that engine. His kit has gotten rave reviews on the MR2 board. I am not going to run water injection because I do not plan to push my engine to its limits. I do think its a good idea when you do though. The one thing you should remember is that if you tune for water injection and then have a clogged line, pump failure, or empty resavoir, you could induce detonation. Bottom line: if you get water injection, check regularly that your system is working properly. [right][snapback]323444[/snapback][/right] thanks for the input -------------------- yea your 3sgte is cool but ill stick to my 7agte
Aug 12, 2005 - 2:11 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Aquamist are certainly up there with the best - they make the systems for most of the WRC cars.
I've had their kits on a couple of cars now and plan on fitting one to my GT-FOUR and my Rover rally car. You can buy parts now which will reduce boost etc when the water runs out so you virtually eliminate the chances of detonating the engine if it is relying on the H2O. Out of interest, why do you want to run WI? Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Aug 12, 2005 - 2:51 PM
QUOTE(GT4WRC @ Aug 12, 2005 - 12:11 PM) Aquamist are certainly up there with the best - they make the systems for most of the WRC cars. I've had their kits on a couple of cars now and plan on fitting one to my GT-FOUR and my Rover rally car. You can buy parts now which will reduce boost etc when the water runs out so you virtually eliminate the chances of detonating the engine if it is relying on the H2O. Out of interest, why do you want to run WI? Gary [right][snapback]323464[/snapback][/right] i just invested a large amount of money in my 7agte and i want an extra safty device i'm not going to tune the motor for WI just have it on there as insurance -------------------- yea your 3sgte is cool but ill stick to my 7agte
Aug 12, 2005 - 3:06 PM
Unless you're actually having detonation issues, then it would be a waste of money. WI is designed for in cylinder cooling allowing you to run higher boost levels with higher CRs or altering the ignition advance.
I'm putting a mappable system on my rally car as I'll be increasing the CR to around 9.0:1 with increased boost to improve low end power. Unless you're planning things klike that then I'd say you'de be better off spending your $ on something more worthwhile. Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Aug 12, 2005 - 4:33 PM
QUOTE(nik @ Aug 12, 2005 - 2:51 PM) QUOTE(GT4WRC @ Aug 12, 2005 - 12:11 PM) Aquamist are certainly up there with the best - they make the systems for most of the WRC cars. I've had their kits on a couple of cars now and plan on fitting one to my GT-FOUR and my Rover rally car. You can buy parts now which will reduce boost etc when the water runs out so you virtually eliminate the chances of detonating the engine if it is relying on the H2O. Out of interest, why do you want to run WI? Gary [right][snapback]323464[/snapback][/right] i just invested a large amount of money in my 7agte and i want an extra safty device i'm not going to tune the motor for WI just have it on there as insurance [right][snapback]323479[/snapback][/right] Also, if you don't intend to tune the car for water injection once its installed and operational, there is really no point of putting it on in the first place. I have also read that adding water injection to a car that is not having detonation issues and leaving the tune alone will actually lower power output at the same boost levels. This post has been edited by jgreening: Aug 12, 2005 - 4:33 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Aug 12, 2005 - 4:42 PM
QUOTE(jgreening @ Aug 12, 2005 - 4:33 PM) I have also read that adding water injection to a car that is not having detonation issues and leaving the tune alone will actually lower power output at the same boost levels. [right][snapback]323507[/snapback][/right] Yep. Same thing goes if you use too large a nozzle. Too much water injected into the system will effectively act as a fire supression system - reducing the in cylinder combustion burn which in turn reduces power output. Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Aug 12, 2005 - 4:43 PM
i agree with j about the joes kits, ive read the same over on the mr2 board.
i think WI is a good idea in your case, nik, especially once you start upping the boost. keep us informed! -------------------- Former Team 5SFTE pro member ;)
Aug 12, 2005 - 7:56 PM
QUOTE(presure2 @ Aug 12, 2005 - 2:43 PM) i agree with j about the joes kits, ive read the same over on the mr2 board. i think WI is a good idea in your case, nik, especially once you start upping the boost. keep us informed! [right][snapback]323513[/snapback][/right] well i talked to the shop i'm going to add it to my set up in a few months when i try and push for 400whp then i'll have tuned for it also -------------------- yea your 3sgte is cool but ill stick to my 7agte
Aug 13, 2005 - 10:02 PM
i have a cooling mist WI kit.
when i installed it(100psi pump, 2 gallon tank, and 3.9gph nozzle) my car would missfire when the system was turned on. it would missfire a lot. on the dyno, with a rich tune and little spark advance, i gained 20whp. since then i leaned the car out more and added as much as 7 deg timing advance all across the map. the car is a monster compared to what 91 octane limited me to prior to the water injection. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Aug 13, 2005 - 11:43 PM
NIK isnt this covered in the boost book
"WI is just a bandaid for an improperly designed system, and you should do it right the first time" (paraphrazed) |
Aug 15, 2005 - 10:14 AM
QUOTE(playr158 @ Aug 13, 2005 - 8:43 PM) NIK isnt this covered in the boost book "WI is just a bandaid for an improperly designed system, and you should do it right the first time" (paraphrazed) [right][snapback]323907[/snapback][/right] i wouldnt call it a bandaid lets just say its like shopping at a K mart clearance sale instead of shoping at a store on rodeo drive. if im gonna run race gas, the car damn well better be making 600+ hp to warrant the $75+ it would cost to fill up -------------------- 1994 Celica GT4 WRC Edition
Aug 15, 2005 - 3:38 PM
i dont want to run race gas at this time i want this to be a pump monster which up hear is 92 octane i think with a little tuning time and a little bigger turbo i can hit 400+whp right now its looking to be in the 320-350whp range at about 14-15 psi
| Lo-Fi Version | Time is now: July 29th, 2026 - 3:55 PM |
