Aug 16, 2005 - 8:09 AM
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
hey guys i cant take my oil filter off it wont budge have tried the oil cap thing and the clap now the filter has a hole in it so i cant even drive it any ideas?
This post has been edited by celicaboston1983: Aug 16, 2005 - 8:14 AM |
Aug 16, 2005 - 8:33 AM
oil filter wrench.
or a screwdriver punched thru it -------------------- Former Team 5SFTE pro member ;)
Aug 16, 2005 - 8:36 AM
oil filter wrench didnt work it just scrap the crap out of it.screwdrive punch the top middle? sorry my slowness
Aug 16, 2005 - 8:51 AM
thru the side. just be careful not to just rip it open like that.
Aug 16, 2005 - 8:54 AM
Enthusiast ![]() Joined Dec 2, '03 From Virginia Currently Offline Reputation: 0 (0%) |
Hope you know you are only supposed to hand tighten filters when you put them on so this doesn't happen
Aug 16, 2005 - 9:07 AM
Thanks for the info ill give it a try when i get home. I do hand tight it just dont know what happened this time this filter has been on my car for 6000 miles now cause I couldnt take it off the last oil change.
Aug 16, 2005 - 1:39 PM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
try hitting the thing a couple of time..at the buttom i mean..or go and get a cap that fits over the oil filter if the top part of it isn't busted yet...
Aug 16, 2005 - 2:43 PM
i had this problem my last oil change. the filter wouldnt come off cause the wrench attachment kept sliping off. i used one of those rubber pads between the oil filter and wrench (those rubber pads that kitchen stores have for helping you open jars and stuff) . ive also seen universal wrench attachments that get tighter as you unscrew them...that should work well.
Aug 16, 2005 - 2:48 PM
QUOTE(lagos @ Aug 16, 2005 - 7:43 PM) i had this problem my last oil change. the filter wouldnt come off cause the wrench attachment kept sliping off. [right][snapback]324823[/snapback][/right] yea i hate that i had two slightly deep cuts because they wrench would slip off and my hand scrap the metal around the oil filter area my bro called and told me he took it off thanks for the help guys im sure Ill need this info again. |
Aug 16, 2005 - 4:38 PM
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
![]() I also have that, plus my chain oil wrench, and an oil filter sockets.. One of the WILL get it off. The filter just won't be usable.. Heh heh. But it's a used filter. so eh. =) Good thing you got it off. Heh. |
Aug 16, 2005 - 4:47 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Not to be a d!k, but make sure you are trying to turn it the right way.
lefty loosey righty tighty DEF -------------------- ![]() I will return one day. |
| Lo-Fi Version | Time is now: July 29th, 2026 - 8:37 PM |
