> big turbo problem, help me out
post Sep 11, 2005 - 1:47 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
alright my car is smoking like crazy.....its the white turbo smoke..what do you guys think is the problem....im so stressed out about my babe!!!!well let me know if anybody has a clue.. thanks
post Sep 11, 2005 - 1:54 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
White = Water. Check compression for a bad head gasket.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Sep 11, 2005 - 4:55 AM
Hanyo
Joined Aug 16, '03
From Bay area
where is the white smoke coming from? exhaust or engine bay?
post Sep 11, 2005 - 7:54 AM
if your SURE its white, its coolant from somewhere.
post Sep 11, 2005 - 11:44 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well its coming form the engine, right underneath the turbo..and alot of it goes out the exhaust..its seems like the turbo leaking oil too..man im going crazy...
post Sep 11, 2005 - 12:04 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
ya it kinda sounds like a head gasket to me. take off your radiator cap and see if it bubbles with the engine on.
This post has been edited by rjbibeau: Sep 11, 2005 - 12:05 PM
post Sep 11, 2005 - 12:27 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
yeah ill try doing that..thanks man..hey you still selling your kit...but yeah let me check out the problem first..
post Sep 11, 2005 - 3:28 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
i bet u blew the turbo seals.
post Sep 11, 2005 - 8:05 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE(RUNNIN-LOW @ Sep 11, 2005 - 5:27 PM)
[right][snapback]333064[/snapback][/right]
ya i think i'm still selling it i just have to gather all of my stuff together. it's a shame that i have to let it go. i shoulda just dropped in a 3sgte. but eghh too late.
post Sep 11, 2005 - 8:31 PM
Dr_Tweak
Joined Mar 31, '04
Could be a leaky connection under the turbo for the coolant and it's evaporating off the hot exhaust. Get in there and check it out.
post Sep 11, 2005 - 8:57 PM
run, what ru running for a turbo?
if its a ct-26, the coolant lines should be right there on the top side of the turbo.
what size are your oil feed and return lines?
post Sep 12, 2005 - 10:41 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well i running the stock mr2 oil lines...i think its a 5 an for the return and a 3 an for the feed..i dont think i blew a seal..but that could be a good idea just to check it out. ill do that today at work and see the problem is
post Sep 12, 2005 - 1:34 PM
what exactly do you mean by "stock mr2 lines"? do you have a -3an line attached to the feed side, and using the stock return?(the stock return line is like 10an) wink.gif
post Sep 12, 2005 - 1:46 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
yeah thats what i mean pressure..10an return and 3 an line inlet..well heres my finds about the white smoke..my heads not leaking. i just found out that my head gasket was metal and that nothing coming out of the head. i guess they change it..so now im thinking i busted a turbo seal..man that totally suck even more.....
thanks pressure ill try to figure out more about what the problem is till then thanks for helping me out bro...
This post has been edited by RUNNIN-LOW: Sep 12, 2005 - 1:53 PM
post Sep 15, 2005 - 11:39 PM
ice23q
Joined Jan 16, '04
From sydney australia
Run i have the same prob ....white smoke outta the exhaust and losts of
oil outta the turbo and bleed valves on the rocker cover....
if thats whats happening to you i hate to bring you the bad news but its a broken piston......"i hope its not"
Im having to rebuild mine with forged pistons and rods.....
312whp with more to come....
post Sep 23, 2005 - 10:33 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
i dont want to come off to sound like an idiot... but the only dumb question is the one you dont ask...(im still curious about doing a 3sgte swap) thats not a 3s you have in there is it runnin low?
post Sep 23, 2005 - 10:42 AM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
QUOTE(easternpiro1 @ Sep 23, 2005 - 10:33 AM)
[right][snapback]337617[/snapback][/right]
no, he has a turbocharged 5sfe, which is a 5sfte....check out his profile
post Sep 23, 2005 - 11:55 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
this problem could be alot more simple than you guys are making it out to be. Just out of curiousity how are you running your pcv, RUNNIN-LOW? are you venting it to atmosphere or are you recirculating it? Do you have anything else recircing to the intake?
post Sep 27, 2005 - 1:47 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
Doge Posted Sep 23, 2005 - 11:55 AM
[/QUOTE]
yeah doge im recicing the air back i to the bov. is that what your talking about. i found out the problem already. its like what pressure was telling me too much oil going into the turbo. bought the fittings and bam!! stop smoking..checkd out the head change that in to the trd head gasket. check the turbo in leaks.. figure it was a oil probem so i limited the oil to the turbo and yeah there you go. it stop smoking white stuff.....
post Sep 27, 2005 - 1:51 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
iam having the same problem, white smoke coming out of my exhaust on my 7afte. its not the turbo seals because i just got my turbo rebuilt less then a month ago
Lo-Fi Version Time is now: August 11th, 2026 - 9:41 PM
