> Manual Trans Fluid, How do you check it?
post Sep 26, 2005 - 7:17 PM
jess_i_74
Joined Sep 19, '05
'Scuse my ignorance, but I don't know where/how to check my manual trans fluid. Can someone enlighten me?
I know some cars have unusual procedures for this. Unfortunately, all I have is a '94 Celica manual, and they don't even tell you how to change the oil. I can imagine an arrow pointing at the fuel fill cap: We recommend the filling of the gas tank be done by your authorized Toyota dealer.
post Sep 26, 2005 - 7:38 PM
What you want to do is have the car on flat ground. Then remove the upper fill bolt, which is a 24mm bolt. If you can stick your finger in pretty much horizontal and feel oil then your level is good. If you need to fill it, just put in oil until it begins to drip out of the fill hole. Again, make sure you're parked on a flat surface.
post Sep 26, 2005 - 10:00 PM
http://www.6gc.net/forums/index.php?showtopic=28245
the procedure, bolt sizes, ect. are the same with the 7a and the 5s
post Sep 26, 2005 - 11:26 PM
macavely
Joined Nov 4, '02
or if you have some time and 40 bucks u can take it a shop and just have them change the oil for you ... not a bad idead to change your tranny fluid after ever 3rd oil change.. it will extend the life of the tranny .... but that if you drive hard most of the time ...
Lo-Fi Version Time is now: August 24th, 2026 - 5:26 AM
