> st205 side feed intake manifold, what gen 3sge can i take a manifold from
post Nov 14, 2005 - 7:16 PM
afroman
Joined Feb 9, '03
From Sioux falls, South Dakota
I searched and couldn't find what i was looking for. I also searched mr20c.com but most topics were about the 2nd gen 3s. i would like to go to a side feed intake manifold when i start to do my swap. I plan on going front mount and would like to simplify the intercooler piping and not having to run it close to the exhaust mani. so my question is what year 3sge. can i take a manifold from. also i if can some how find a beams mani would it be worth the money. if you think this is a stupid idea let me know im just trying to get my research done.
-Aaron-
Replies (1 - 17)
post Nov 14, 2005 - 7:19 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
They make aftermarket side feed manifolds for the 3sgte. It will be a little bit more money, but very nice under the hood.
DEF
I will return one day.
post Nov 14, 2005 - 9:15 PM
BLADDER_MASTER
Joined Dec 8, '04
Either go aftermarket or find a BEAMS manifold. The ECU of the 3rd gen 3S-GTE wouldn't be able to control the T-VIS/ACIS of the 1st, 2nd, and 3rd gen 3S-GE's intake manifolds.
post Nov 14, 2005 - 9:49 PM
The 2nd gen 3sgte has Tvis. The 3sge in the 2nd Gen doesnt, that had the acoustic control.
This post has been edited by Supersprynt: Nov 14, 2005 - 9:53 PM
post Nov 15, 2005 - 1:51 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(afroman @ Nov 14, 2005 - 6:16 PM) [snapback]355573[/snapback]
-Aaron-
Its the wrong reason to consider one. There is a guy on mr2oc.com with the screen name boostd4 that is doing one. The primary reason to consider it is to maintain even airflow across all 4 cylinders. Quite frankly, the whole "no intercooler piping over the exhaust manifold" rule is very over blown. The only time it would affect you (assuming you have an adequate FMIC) is when you are stopped idling for a period of time - like sitting at a traffic light. Then, all you do is don't boost high for the first 1-2 seconds of your launch and the issue is over. Also, going to a different intake manifold is not a simple bolt in affair - especially if you do it on a 3rd gen without an AFM. It will almost definitely require a stand alone computer and you will be blazing fairly untested ground with airflow and other issues. Unless your goals are in excess of 350whp, I wouldn't even consider it.
post Nov 15, 2005 - 2:25 AM
the ic piping over hot manifold is a super easy fix. all you need to do is wrap your ic piping in exhaust heat wrap. it does an amazing job at keeping the piping cool.
post Nov 15, 2005 - 6:31 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Or just don't run it over the exhaust manifold...
Click here to see my swaps
drtweak@phoenixtuning.com
post Nov 15, 2005 - 10:37 AM
afroman
Joined Feb 9, '03
thanks for all the input guys. well that was also one of the things i was also wondering about. i read that some places say the intake mani is the problem with cylinder 3 going some say its the fuel rail. i have no personal experience so who do i trust. do i go stand alone and just give #3 more fuel or try the mani and see what happens. i may sound like a retard and i dont post much but i figured i better try to read and learn before i ask dumb questions. if im going to go through with the swap i figured do it right the first time.i have a beater car so the celica can be down for as long as i need to gather money and parts.replies are appreciated.
-Aaron-
post Nov 15, 2005 - 10:51 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(afroman @ Nov 15, 2005 - 9:37 AM) [snapback]355806[/snapback]
-Aaron-
The uneven flow to the cylinders is because of both the intake manifold and the gen2 fuel rail (on an upgraded pump). However, you don't need to worry about it unless you are planning modifications beyond stock, intake, exhaust, and boost controller. If you go standalone, the safety issue with one or more cylinders going lean can be adjusted without a different intake manifold.
The important questions are "what are your goals?" and "what is your budget?"
post Nov 15, 2005 - 3:38 PM
scothaniel
Joined May 1, '03
From Michigan
3rd gen 3SGE is a side fed manifold which will bolt right up. You would need to weld a bung on for the manifold temp sensor.
The butterfly system on the 3rd gen runs off of vacuum (closes the ports around 2500 rpm) and has no controlled VSV's, so the ECU wont know (or care) that its there - I'm was running the ST205 ECU on a 3rd gen 3SGE without problems.
I have both turbo and non-turbo manifolds at a performance shop now - should have them flow tested shortly.
Scott
West Michigan
post Nov 15, 2005 - 4:25 PM
going lean to cyl #3 is not the type of thing a normal 3s will have a problem with. if anything, the motor runs crazy rich all around. i think the issues you read about are things that guys noticed when pushing the motor in the 300-400hp range.
post Nov 15, 2005 - 4:51 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
QUOTE(Dr_Tweak @ Nov 15, 2005 - 11:31 AM) [snapback]355788[/snapback]
hey i can actually back this up and say it keeps the pipe cooler...! i should know...thats my engine bay! biggrin.gif
bboy
post Nov 16, 2005 - 3:12 AM
BLADDER_MASTER
Joined Dec 8, '04
QUOTE(scothaniel @ Nov 15, 2005 - 3:38 PM) [snapback]355920[/snapback]
So then if I cut the ACIS wire that goes to my ECU, the ACIS should still work?
post Nov 16, 2005 - 4:27 AM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
I have a spare ST205 side feed fuel rail and injectors if you're interested. I'm changing to top feed.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Nov 16, 2005 - 11:21 AM
scothaniel
Joined May 1, '03
From Michigan
Yes, the ACIS will still work, as long as its getting a vacuum signlal. From what I've read on the system, it looks like the ECU also forces the butterflies closed at a certain throttle position, which will be lost by disconnecting the VSV.
With the last 3SGE's I received, the canister on the back of the intake manifold was connected to the fuel pressure regulator, not the ACIS system - which doesn't match the diagrams I've seen. Is this the same with your motor?
BTW - nice description of the ACIS on the 7M:
http://www.geocities.com/mwsupra2003/acis.html
This post has been edited by scothaniel: Nov 16, 2005 - 11:22 AM
Scott
West Michigan
post Nov 20, 2005 - 6:49 AM
BLADDER_MASTER
Joined Dec 8, '04
QUOTE(scothaniel @ Nov 16, 2005 - 11:21 AM) [snapback]356270[/snapback]
I gotta do some research on this. I remember there was a diagram showing how the ACIS system works on the 3S-GE's but I lost it. mad.gif
post Nov 20, 2005 - 7:29 AM
uzthedentist
Joined Mar 21, '04
From united kingdom
http://www.junauto.co.jp/products/intake-p...k/index.html?en
jun make one
GT4 ST205 79 modifications and rising!!
spec list: http://sox-japoc.co.uk/forum/garage.php?mo..._vehicle&CID=10
post Nov 20, 2005 - 2:00 PM
afroman
Joined Feb 9, '03
how much would that even cost. it really doesnt matter much anymore my cousin totaled my blazer so i have to take care of that. i guess the swap dream fades father away.
-Aaron-
Lo-Fi Version Time is now: September 14th, 2026 - 1:11 AM
