> which iridium sparks for 7AFE?, need advice...
post Apr 19, 2006 - 3:43 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
DENSO Iridium Power
or
NGK IRIDUIM IX
Please write reason of your poll... thanks
p.s.: or do you think it's useless to use iridium sparks to 7AFE?
This post has been edited by malpaso: Apr 19, 2006 - 3:45 AM
post Apr 19, 2006 - 5:35 AM
QUOTE(malpaso @ Apr 19, 2006 - 4:43 AM) [snapback]423385[/snapback]
DENSO Iridium Power
or
NGK IRIDUIM IX
they'll last longer, and work better then 99.9999 % of the aftermarket parts out there.
post Apr 19, 2006 - 6:19 AM
o0black0o
Joined Jul 14, '05
From Spring, Texas
Doesn't Toyota Use NGK Plugs tho? So there really is not difference?
I got NGK's on mine. Work great, felts the power and gas mileage the second they got put on.
This post has been edited by o0black0o: Apr 19, 2006 - 6:20 AM
post Apr 19, 2006 - 8:22 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
None, Don't waste your money on something that will not make you gain any HP.
Just get some cheap Plugs, it will do just as good as stock.
post Apr 19, 2006 - 8:33 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Toyota uses Denso which is the same company as NGK - NGK is just the name they use for the performance brand. Either one will be the same but irridium does make a slight difference. No HP gain just smoother idle and slightly better throttle response.
Why do we hae 2 threads for this?
post Apr 19, 2006 - 8:42 AM
malpaso
Joined Feb 3, '06
QUOTE(Negative @ Apr 19, 2006 - 3:33 PM) [snapback]423447[/snapback]
Because we talk just about 7AFE here, not more powerful 3somethin or 5something engines wink.gif biggrin.gif
Lo-Fi Version Time is now: August 11th, 2026 - 5:56 PM
