> ABS Axles, how to tell?
post Apr 20, 2006 - 10:28 AM
bigal004321
Joined Jun 21, '05
From New york
How do you tell if 3sgte axles are ABS or not? On the inside of the engine bay there are relays for ABS, does that mean the axles are ABS?
Thanks for any help
Bigal
EDIT: IPB Image
ABS or not?
This post has been edited by bigal004321: Apr 22, 2006 - 2:01 PM
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
Replies (1 - 6)
post Apr 20, 2006 - 10:50 AM
Rjb23
Joined Feb 8, '04
From KY
If you dont have ABS it doesnt matter if you use ABS axles or not, but you can tell by looking at the ends of them they have notches in the part that the cv boot connects to all the way around the axle, it kinda looks like teeth on a gear.
Sorry I don't know really how to explain it.
post Apr 21, 2006 - 12:00 PM
bigal004321
Joined Jun 21, '05
From New york
if they have ABS relays does that mean that it has ABS axles?
Bigal
post Apr 21, 2006 - 5:40 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Look for the ABS unit the engine bay!
Also, there is a little toothed ring on the outer part of the axle just as it goes into the hub.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Apr 22, 2006 - 2:04 PM
bigal004321
Joined Jun 21, '05
From New york
BUMP for new pics...is it ABS? Cuz i have no idea..
Bigal
post Apr 22, 2006 - 2:09 PM
bigal004321
Joined Jun 21, '05
From New york
One more pic!!IPB Image
See it does have ABS relays,,, so i am unsure of whether the axles woudl also be ABS..
Thanks for the help!
Bigal
post Apr 24, 2006 - 6:36 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(bigal004321 @ Apr 22, 2006 - 12:09 PM) [snapback]424843[/snapback]
Bigal
Look in the engine bay, man... come on! There will be an ABS unit with a bunch of brake lines to and from it. (if its an MR2, the ABS unit should be in the front trunk somewhere, I think)
You can't tell anything from any of the pictures you posted. The part of the axle with the 'toothed' section slides inside the hub and is hidden. An extra sensor bolts on the hub (two wires go to it) that you can also look for, but it wasn't clear from the pictures whether that sensor was there or not. The fuse box cover has the same printing on it whether there is ABS or not - you need to match it to an actual picture of what is actually in the fuse box.
-Charlie
Lo-Fi Version Time is now: August 9th, 2026 - 9:56 AM
