> Installing Fog Lights, Stock 96+ ones
post Apr 27, 2006 - 1:03 AM
JFrost9
Joined Aug 27, '05
From Texas
So my car is a 94 with a 98 bumper, which means i have the slots for the fog lights. Ive come across a set and I was just wondering if its possible to wire them up to my car. I could make a switch to go on the inside, just not sure how hard it would be to wire these up. Any help is appreciated... and these would come with the harness'es and all.
-Josh.
Replies (1 - 7)
post Apr 27, 2006 - 1:49 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE(JFrost9 @ Apr 27, 2006 - 8:03 AM) [snapback]427095[/snapback]
-Josh.
Depends on if you want to do it "by the books" or not wink.gif.
this is what you need "by the book":
and IMHO doesn't matter if you have any celica...
This post has been edited by malpaso: Apr 27, 2006 - 1:51 AM
post Apr 27, 2006 - 7:20 AM
it really isn't too hard at all. Just buy a relay (for about $6 at RadioShack) and use this
if you have any questions, let me know
post Apr 27, 2006 - 8:03 AM
fastcelica20
Joined Apr 4, '06
From Minnesota
hey batman im also installing fogs. so i can just buy any relays at radioshack right? so all i need is relay and the fogs and im good to go? i guess installing is just the problem cause i dont get the ground wires and such. ill get shock!
sorry to jacking the thread but im also in need of help. hope this helps you too
post Apr 27, 2006 - 9:30 AM
relay from radioshack
^^one of those. It is best to use an inline fuse from the battery to the relay, but not nessessary. You would need wire too wink.gif
just follow the diagram, everything will work fine.
post Apr 27, 2006 - 11:15 PM
JFrost9
Joined Aug 27, '05
From Texas
Thanks batman, i had seen that diagram before on here awhile back, i guess my only question is where to ground the wires, and then where to run all this wiring...where should i put it to make it easiest to get a switch in the cabin.
post Apr 27, 2006 - 11:25 PM
QUOTE(JFrost9 @ Apr 28, 2006 - 12:15 AM) [snapback]427413[/snapback]
Ground the wires directly to the chassis, there are plenty of grounding points in the bay. Just make sure it is a good connection with bare metal.
For running the wires through the firewall there are 2 good places IMO.
One is were your engine harness already goes through the firewall (pass side, next to your wiper motor, behind the glove box) and the other is the rubber boot surrounding the steering column (driver's side, behind the pedals). For the column boot, just poke a hole or slit through it and push them through.
post Apr 28, 2006 - 1:14 AM
hitcachi
Joined Jun 19, '05
From Nebraska
The 7AFE has so much more room to work behind the firewall then the 5SFE does. I just drilled a hole pretty much in the center of the firewall, ran wires and secured a gromet in there. Nice clean job. That was for installing my gauges, but damn, these fogs don't look to hard to hook up.
Lo-Fi Version Time is now: June 25th, 2026 - 12:03 AM
