Jun 18, 2006 - 7:22 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
i found a rim i like but it has an offset of 48mm if i use a 20mm spacer would that be a bad thing?
Jun 19, 2006 - 12:13 AM
QUOTE(urbandork @ Jun 19, 2006 - 12:22 AM) [snapback]446074[/snapback] i found a rim i like but it has an offset of 48mm if i use a 20mm spacer would that be a bad thing? according to the offset wheel guide a 7" rim should have a total offset of 26 so i figure that a 20mm spacer would be cool. Im just wondering if using that large of a spacer is smart idea btw the rims i like are here http://www.discounttiredirect.com/direct/f...5&rw=7&bp=5-100
Jun 19, 2006 - 9:55 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
You should be ok as long as you have enough thread left to bolt the wheels on, although 5 stud so should be fairly safe with losing some thread.
Jun 19, 2006 - 1:12 PM
anyon have any good suegestions for good companies to go with when looking to buy spacers?
Jun 19, 2006 - 1:37 PM
i would only trust H&R spacers.
Jun 19, 2006 - 3:05 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
QUOTE(lagos @ Jun 19, 2006 - 8:37 PM) [snapback]446313[/snapback] i would only trust H&R spacers. +1 Having 15mm in front and 20mm in the rear both from H&R. Excellent quality. -------------------- JDM Powerplant installed, BPU coming very soon!
Jun 20, 2006 - 12:48 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
QUOTE(vsideboy @ Jun 19, 2006 - 4:55 PM) [snapback]446243[/snapback] You should be ok as long as you have enough thread left to bolt the wheels on, although 5 stud so should be fairly safe with losing some thread. That's the problem... rear bolts are 28mm and front bolts 25mm -> You don't have chance use 20mm spacers without: a) change bolts to longer ones (but how?) b) use spacers with own bolts like those... I need figure out the same problem... -------------------- No more replicas... This is evolution... This is SS-four :)
![]() ________[Featured Celica of 6gc.net @ 2010]_________ |
Jun 20, 2006 - 9:12 AM
H&R DRS series come with new wheelbolt so you have longer bolts. Its the safest way to install the spacers.
Jun 21, 2006 - 3:10 PM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 19, '06 From Long Island, NY Currently Offline Reputation: 13 (100%) |
I also want spacers, they look pricey but these are the ones I will buy.
H&R DRS 15mm is $120 for the pair H&R DRS 20mm is $120 for the pair Should I use 15mm in the front and 20mm in the rear? -------------------- '92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold '99 Black Mitsubishi 3000GT VR-4 - Sold '04 E250 Work Van - Going soon '08 Grey Dodge Charger Work Car - Ordered |
Jun 21, 2006 - 3:24 PM
Dont know what kind of rims you have. Offset and width?!
| Lo-Fi Version | Time is now: May 17th, 2026 - 11:31 PM |
