> engine oil
post Jul 12, 2006 - 9:16 PM
hoopr50
Joined Dec 18, '05
From pittsburgh
i was wonderin if anyone else has had problems w/ the stock engine in a st burrning oil after it hit 143,000 miles??
post Jul 12, 2006 - 9:31 PM
yup. almost common with a higher mileage 7a
post Jul 12, 2006 - 9:40 PM
look around your motor for any leaks. just because its loosing oil, dosnt alwasy mean its burning it. could be just a rubber gasket thats cheap and easy to fix.
post Jul 12, 2006 - 11:05 PM
Niskyspy
Joined Jan 21, '05
From NY
I have the same damn thing, no leaks anywhere on the engine but oil keeps dissapearing. The only thing I think it goes to is every mornting I start the car I get some white some coming out.
<<AKA THA RUSSIAN>>
post Jul 13, 2006 - 9:16 AM
pure_dx
Joined Dec 28, '05
From USA
normal with that mileage, just keep adding oil and topping it off if you have no leaks, if you need to, you can try replacing your valve seals
post Jul 13, 2006 - 9:30 AM
vincent_doggy
Joined May 25, '06
From Hong Kong
I have a 3sge engine, same problem I encounter b4 I change the rubber/plastic gasket.
B4 I change, when I change the spark plugs, some of the spark plugs wet and stick with engine oil.
Cheap to change and it's a must with that mileage.
post Jul 13, 2006 - 9:59 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
i always carry a qt or two of oil and just check it every once in a while. stick some in if its wayy low. i usually make it the 3,000 miles for oil changes before it goes low anyway so its usually not too much of a problem
I <3 Dustin---07/16/06
post Jul 16, 2006 - 2:52 PM
kriz45
Joined Jun 17, '06
From bellevue washington
i had the same problem but the i put some castrol engine restore (i think thats the name) and i havent had another problem. i got it at shucks i think but im sure auto zone has it and stuff
Lo-Fi Version Time is now: July 10th, 2026 - 9:23 AM
