> For those with a 3sgte, Whats is your exhaust setup?
post Sep 10, 2006 - 10:16 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
My car is jussssttt about done...i wanna get my exhuast done before i take it to the body shop. I wanna change the piping and the muffler. What are you guys running....thanks
Ryan
post Sep 10, 2006 - 10:23 PM
quicknstyle
Joined Oct 3, '02
From HOUSTON
QUOTE(Baddica95 @ Sep 10, 2006 - 8:16 PM) [snapback]478249[/snapback]
Ryan
i think most of the guys are running custom 3in pipes
post Sep 10, 2006 - 10:25 PM
full 3in, mandrel bent, with a magnaflow muff.
post Sep 10, 2006 - 10:36 PM
Insanity-74
Joined Jan 9, '05
From Under the car
XS downpipe with a 2.5" Mongoose system
3" system is a bit of overkill and is unnecesssary unless you plan to run huge power...2.5" will keep everything running sweet, and is alot less likely to allow boost creep.....its also cheaper.
post Sep 10, 2006 - 10:44 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
wheres a good place to pick up a muffler....
post Sep 10, 2006 - 10:51 PM
ebay
QUOTE(Insanity-74 @ Sep 10, 2006 - 11:36 PM) [snapback]478264[/snapback]
3in is not at all overkill for a turbo car. the bigger your exhaust, the faster your tubo will spool up and the more power youll make. but i do agree that a 2.5in will help with any boost creep issues, and would also be an ok choice.
post Sep 10, 2006 - 11:19 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
would the greddy sp cat back exhaust system be a good choice...or is that not recommended for turbos...im not sure the pipe size..
post Sep 10, 2006 - 11:51 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
im sorry, but what is boost creep exactly and what causes it?
post Sep 10, 2006 - 11:56 PM
cheeco
Joined Jun 15, '06
From NJ
2.5in custom stainless DP back, muffler and submuffler both magnaflows, stock DP.
post Sep 11, 2006 - 12:09 AM
beno
Joined Nov 22, '05
From New Zealand, Hamilton
boost creep is when the cars boost goes higher than the computer setting.
What can be done to stop boost creep with a 3" exhaust system? a bigger waste gate?
This post has been edited by beno: Sep 11, 2006 - 12:16 AM
post Sep 11, 2006 - 1:32 AM
Insanity-74
Joined Jan 9, '05
From Under the car
The waste gate is used to divert exhaust gases away from the turbo when the turbo has reached it pre set boost level, Boost creep is caused when the waste gate can no longer cope with bypassing the exhaust gases and they continue to go through the turbo, making it spin faster and faster, building up more and more boost.
Larger diameter exhausts make this situation worse as they allow more exhaust gases to flow.....a narrow diameter exhaust restricts the flow of exhaust gases helping prevent boost creep.
Hope that makes sence
post Sep 11, 2006 - 9:44 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
is there a certain boost level that this would be bad on? i plan to have mine set to 14-16psi daily
post Sep 11, 2006 - 10:25 AM
QUOTE(easternpiro1 @ Sep 11, 2006 - 10:44 AM) [snapback]478387[/snapback]
the basic idea is... youll set it at 16psi, but then as the rpms rise you might notice that you hit 18psi because the boost creeped up there.
post Sep 11, 2006 - 10:27 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
post Sep 11, 2006 - 11:12 AM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
QUOTE(Baddica95 @ Sep 11, 2006 - 12:19 AM) [snapback]478286[/snapback]
I have that on my swap, sp catback and 3" dp make 3sgte sound real nice and deep, but I'm not keeping it, as far as performance save up for full 2.5 or 3"
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Sep 11, 2006 - 11:15 AM
QUOTE(CilverSeliST205 @ Sep 11, 2006 - 12:12 PM) [snapback]478432[/snapback]
i also had the greddy sp on my swap for over a year. while it works fine, and the car is still quick, i noticed a big gain going to a full 3in exhaust.
post Sep 11, 2006 - 1:25 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
so i just have to find a muffler then with a 3 inch inner pipe and take it to a shop and say that i want a custom exhaust with 3" all the way....or something like that...I never had to deal with exhaust before.
post Sep 11, 2006 - 2:11 PM
QUOTE(Baddica95 @ Sep 11, 2006 - 2:25 PM) [snapback]478485[/snapback]
yeah, just call around to a few places and see what shop can do that type of work
post Sep 11, 2006 - 4:03 PM
Baddica95
Joined Mar 31, '04
From Milwaukee
alright..well lastly...whats a good muffler as far as sound wise...i want something with a nice deep tone to it...not too obnoxious...
post Sep 11, 2006 - 4:25 PM
teamchancery
Joined Jun 25, '06
From miami
QUOTE(lagos @ Sep 11, 2006 - 11:15 AM) [snapback]478433[/snapback]
what kind of gains does a full 3 inch exhaust give with no(gutted)cat
Lo-Fi Version Time is now: June 9th, 2026 - 11:10 PM
