> TWO Cats?, WHY!?!?
post Oct 16, 2006 - 10:23 PM
n1ckz0r
Joined Sep 1, '06
From Michigan
I took my car to the muffler shop for a quote on how much my stuff was going to run me to get isntalled, and I have 2 catylitic converters! WHY!!?!?! one is right under the manifold, between the downpipe and the manfiold (or looks this way) can anybody explain why this would be, and if this is restricting to airflow or not?
Replies (1 - 17)
post Oct 16, 2006 - 10:30 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
believe cali spec celicas have/had 2 cats.
Kawi Love
post Oct 16, 2006 - 10:47 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
I'm guessing you have a 94-95 because 96+ only have one cat because emissions are controlled better with the OBDII (I believe, thats the reason). as far as I know the extra cat doesn't hurt your airflow any more than the Celicas with only one cat.
I <3 Dustin---07/16/06
post Oct 16, 2006 - 10:49 PM
n1ckz0r
Joined Sep 1, '06
From Michigan
so with a performance cat, new header, entire exhaust expanded .25 of an inch, ditching the resonator, will i see any difference?
post Oct 16, 2006 - 10:52 PM
cat info
GT
94 fed has 1 cat
94 cali has 2
95 + has 2
ST
94-95 are all cali and have 2
96-97 have 1
do you have an ST or a GT ?
This post has been edited by Batman722: Oct 16, 2006 - 10:51 PM
post Oct 16, 2006 - 10:53 PM
n1ckz0r
Joined Sep 1, '06
From Michigan
7afe. St
post Oct 17, 2006 - 7:14 AM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
My '95 ST is not a CA car and had 2 converters.
I just checked my BGB, you're right. New bit of information I had not really cared to look into until now.
This post has been edited by S_C_M: Oct 17, 2006 - 4:31 PM
post Oct 17, 2006 - 7:17 AM
QUOTE(S_C_M @ Oct 17, 2006 - 8:14 AM) [snapback]492613[/snapback]
post Oct 18, 2006 - 4:51 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(n1ckz0r @ Oct 16, 2006 - 8:49 PM) [snapback]492515[/snapback]
you'd probably see a difference with any one of those.
yeah, my 94 GT cali spec has 2. I wonder which would give more performance and less emissions: to swap out the two OBDI converters for one OBDII converter, or two just use two OBDI converters?
post Oct 20, 2006 - 2:17 AM
lazzyboy121
Joined Feb 17, '04
From michigan
is teh cat located rigth after the exhaust manifold for a 94 gt?
94 celica GT
92 honda prelude si<h22 swap>
93 eagle talon TSI <4G63 powered>i wish it was AWD
90 mitsu eclipse GSX<4G63 powered>SOLD
LEXUS IS300< im looking for one!
post Oct 20, 2006 - 7:25 AM
QUOTE(lazzyboy121 @ Oct 20, 2006 - 3:17 AM) [snapback]494029[/snapback]
yes. and if you have a cali spec, there is another under the car.
post Oct 20, 2006 - 10:16 AM
n1ckz0r
Joined Sep 1, '06
From Michigan
taking both out and putting an ebay one in!
post Oct 20, 2006 - 3:19 PM
Slick
Joined Jan 10, '06
From Mozambique, Africa
Well, at least not yet.
post Oct 20, 2006 - 3:54 PM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
Yeah what happens if you just put in a universal cat in place of the two cats on a ST? (legal wise... can the cops check to see how many cats its supposed to have?)
This post has been edited by FreddyTheOthaMeat: Oct 20, 2006 - 3:54 PM
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
post Oct 20, 2006 - 4:38 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Yup, I've owned a 96 Camry and it had two, and my 96 Celica ST has the same setup. Essentially you could remove the one under the car, but the top one that is part of the manifold is gonna turn on your CEL if you don't reconnect everything that was on the old manifold. You won't get pulled over for anything and if you're CEL isn't on then you'll pass emissions. I did get pulled over in my Camry once for my exhaust being too loud though lol.
Camry had stock manifold with 2.5 inch exhaust (manifold back), high-flow magniflow cat under car, and magniflow muffler. laugh.gif
post Oct 21, 2006 - 12:59 PM
n1ckz0r
Joined Sep 1, '06
From Michigan
CEL?
post Oct 21, 2006 - 1:15 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Check Engine Light
post Oct 23, 2006 - 11:48 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i call the second cat (the smaller one) the Kitten haha cheezy joke
Lo-Fi Version Time is now: September 2nd, 2026 - 4:15 AM
