Oct 24, 2006 - 8:46 AM
Enthusiast ![]() ![]() Joined Nov 23, '05 From Charleston, WV Currently Offline Reputation: 1 (100%) |
One question. Do you need change ECU from automatic to manual after swap manual tranny in to the ST Celica? I did not do that. No problems with that, but when I try take off really fast, it will drop rpm and lose a power for a split second and I have to play with a clutch get it roll. I thing that is a ECU problem. What do you guys think????
Oct 24, 2006 - 11:22 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
when you let the clutch out the RPMs drop a few hundred and you have to compensate for it using the gas pedal. thats just what happens with manual transmissions.
maybe I'm just not reading your question right? -------------------- |
Oct 24, 2006 - 12:18 PM
I know that. It is something with the car. I just gonna change a ECU and will see.
Oct 24, 2006 - 12:22 PM
how did you wire your auto ECU? you didn't get a CEL?
I used a m/t ECU from a 96. different part number but works fine. -------------------- |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 12:55 PM |
