Nov 15, 2006 - 11:19 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
um.. i just had a question...
so if u're collecting parts for a diy turbo kit.. but you don't have everything to put it together yet... how do you test a used turbo to make sure it's in good shape and runs? like.. u can check for shaft play... but not sure what else.... just that some people have like a startup warranty or a 30-90day warranty... or there's just really no way? since i somehow doubt any shop has the resources lying around to just bolt it up and fire it up for a test run -------------------- |
Nov 16, 2006 - 1:22 AM
Enthusiast ![]() Joined Sep 30, '06 From Knox Vegas, Tennessee Currently Offline Reputation: 0 (0%) |
The question is...If you're buying a DIY turbo kit..Why would you buy a used turbo? Splurge my friend.
Nov 16, 2006 - 10:13 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
BTW - Im told some shaft play is normal and my turbo only has like 3K miles on it and it does have some.
Nov 16, 2006 - 12:02 PM
Enthusiast ![]() ![]() Joined May 8, '06 From Irvine Currently Offline Reputation: 0 (0%) |
as long as the turbine doesnt touch the housing your good
Nov 16, 2006 - 12:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
since its used it might be a good idea to get it rebuilt anyway
Nov 16, 2006 - 3:17 PM
That is rebuilt. We used it for no more than 3K miles on my friends MR2T until his new turbo came in. That's it.
Nov 16, 2006 - 3:49 PM
Enthusiast ![]() Joined Mar 18, '06 From Brisbane - Australia Currently Offline Reputation: 0 (0%) |
QUOTE(Negative @ Nov 17, 2006 - 6:17 AM) [snapback]502948[/snapback] That is rebuilt. We used it for no more than 3K miles on my friends MR2T until his new turbo came in. That's it. Rebuilt is always a good idea. I purchased a used turbo that was supposedly recently rebuilt . Took it to a shop to check it out prior to installing. Turns out it needed a whole new housing due to cracks on the inside. At least if it is rebuilt, you have a warranty and guarantee that it will work. |
Nov 16, 2006 - 5:25 PM
your best bet is to start with a known when it comes to the turbo.
buy a good core, and have it rebuilt by a reputable shop. -------------------- Former Team 5SFTE pro member ;)
Nov 16, 2006 - 6:56 PM
QUOTE(presure2 @ Nov 16, 2006 - 10:25 PM) [snapback]503000[/snapback] your best bet is to start with a known when it comes to the turbo. buy a good core, and have it rebuilt by a reputable shop. I did. Pressure2 - do you think the 3K miles on a good running MR2T would have hurt my turbo to the point where I should have it rebuilt again? I trust your word above all other but damn another$500 to get it rebuilt again? I was just trying to help a friend - do you think I f*cked myself in the end? -------------------- ![]() |
Nov 16, 2006 - 8:08 PM
QUOTE(Negative @ Nov 16, 2006 - 6:56 PM) [snapback]503032[/snapback] QUOTE(presure2 @ Nov 16, 2006 - 10:25 PM) [snapback]503000[/snapback] your best bet is to start with a known when it comes to the turbo. buy a good core, and have it rebuilt by a reputable shop. I did. Pressure2 - do you think the 3K miles on a good running MR2T would have hurt my turbo to the point where I should have it rebuilt again? I trust your word above all other but damn another$500 to get it rebuilt again? I was just trying to help a friend - do you think I f*cked myself in the end? you should be fine -------------------- Former Team 5SFTE pro member ;)
Nov 20, 2006 - 12:28 PM
how easy are the turbine and compressor wheels supposed to spin? so smooth that one spin with ur finger it goes like 1+ full turns (like a handheld fan or something?) or it doesn't even go 1 full turn when spun with ur finger but when you turn it with ur finger still on it, it's goes around smooth?
This post has been edited by elvasoshexai: Nov 20, 2006 - 1:42 PM -------------------- |
Nov 20, 2006 - 2:02 PM
well, im not to sure. but i think that depends on how heavy the turbine is to build up inertia to keep spinning. also the bearings perform the best when nice and warm, with a steady supply of clean oil lubing them. by turning the turbine slowly and wiggly it a bit you can feel for shaft splay, other than that im clueless on checking a turbo off the engine.
Nov 20, 2006 - 2:41 PM
ok... i guess that was kinda stupid wondering if such a heavy wheel spins as easily as a paper thin plasic wheel...
eh.. i hope it's ok... i just bought a ct20b... i didn't notice any shaftplay when wiggling it... and the wheels seemed to spin fine when turning it. any proper way to store this? it's just in a box in my garage right now... seller said to check and keep the bearings lubed with engine oil? -------------------- |
| Lo-Fi Version | Time is now: July 30th, 2026 - 7:15 PM |
