> Burning Oil, from where?
post Jan 7, 2007 - 8:34 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
ok, I'm already working on the issue I just want various opinions to work with in case I run out of ideas.
recently my car has been going through oil like crazy. here are some of the facts so far:
- it doesn't seem to be leaking from any gaskets (at idle speed) checked valve cover, sender, and head gaskets
- never see any puddles of oil on the ground after being parked
- no blue smoke out the back. theres a little white smoke, slightly more than there used to be but not that bad at all and could just be from the cold and wet weather. and it smells normal
- oil light comes on about every 2,000 miles or so now. before about 3 or 4 months ago it had never come on before, I would just change it every 3-5k miles regardless
- extra info: started out using 10w-40 then switched to 5w-30 then 5w-30 synth now 10w-30 synth (over the course of about 3 years)
here's whats happened and when in detail:
[07.15.06] 159,400 mi - oil and filter changed, everything normal
[08.20.06] 162,300 mi - oil and filter changed again, like normal
[09.01.06] 163,165 mi - first time I'd ever seen the oil light come on. was low but still clear, 1qt added
[09.16.06] 164,749 mi - oil and filter changed
[10.14.06] 166,853 mi - oil light on again. very low but still clear, 1qt added
[11.02.06] 168,262 mi - oil light on. switch to Mobil 1 full synth 5W-30, changed oil and filter
[11.26.06] 170,000 mi - oil light on. added 1qt Shell 10W-40 synth blend, its all I could get and I had a long drive home
[11.30.06] 170,748 mi - oil and filter changed. switch to 10W-30, still Mobil1 full synth
[12.18.06] 172,370 mi - oil light on. change oil and filter
[01.04.07] 173,800 mi - oil light on. found oil leaking from drain plug, tightened it and put it 3qt Mobil1. ran car for about an hour, no more leaking from plug
[01.07.07] 173,900 mi - still no leak from drain plug. added engine oil tracer dye, will check it in a few days
thats where I am now. throw out any ideas you might have and I'll either try it or tell you I've already tried.
This post has been edited by hurley97: Mar 15, 2007 - 11:25 PM
I <3 Dustin---07/16/06
- hurley97   Burning Oil   Jan 7, 2007 - 8:34 PM
- - 97lestyousay   Our cars really are twins. I am losing/using abou...   Jan 7, 2007 - 11:46 PM
- - hurley97   damn. my car feels old now. I got it with about...   Jan 8, 2007 - 12:27 AM
- - 97lestyousay   I just switched back to castrol gtx 5w-30 from mob...   Jan 8, 2007 - 1:28 AM
|- - hurley97   QUOTE(97lestyousay @ Jan 8, 2007 - 1...   Jan 8, 2007 - 10:07 AM
- - hashmaster52   my car is at 142xxx miles and it also burns/leaks ...   Jan 8, 2007 - 1:46 AM
- - 56willysnut   My sons car (147K) is curently burning oil at the ...   Jan 8, 2007 - 8:06 AM
- - Bitter   next oil change run 1/2 qt ATF through the engine ...   Jan 8, 2007 - 9:56 AM
|- - presure2   QUOTE(Bitter @ Jan 8, 2007 - 9:56 AM...   Jan 9, 2007 - 4:56 PM
|- - hurley97   QUOTE(presure2 @ Jan 9, 2007 - 4:56 ...   Jan 9, 2007 - 10:46 PM
- - hurley97   QUOTE(hashmaster52 @ Jan 8, 2007 - 1...   Jan 8, 2007 - 10:10 AM
- - JonCars17   I wish my car would get that much life on oil. My ...   Jan 8, 2007 - 10:35 AM
- - LewFX   i too have switched back from mobil 1 to castrol g...   Jan 8, 2007 - 10:40 AM
- - bufferdan   Wear...worn out rings. My 7afe with 190k uses alo...   Jan 8, 2007 - 10:42 AM
- - Bitter   what kind of milages are you guys at? im at 123K ...   Jan 8, 2007 - 10:53 AM
|- - hurley97   QUOTE(Bitter @ Jan 8, 2007 - 10:53 A...   Jan 8, 2007 - 10:14 PM
|- - king_wsk   QUOTE(Bitter @ Jan 8, 2007 - 10:53 A...   Jan 9, 2007 - 6:27 PM
- - LewFX   try using an oil additive such as lucas or napa br...   Jan 9, 2007 - 12:47 AM
- - wind   im just comming up to 200,000km.... im using ~2 ...   Jan 9, 2007 - 2:10 PM
- - presure2   are your underplastics installed?   Jan 10, 2007 - 7:27 PM
|- - hurley97   QUOTE(presure2 @ Jan 10, 2007 - 7:27...   Jan 10, 2007 - 10:17 PM
- - bufferdan   I'll just keep putting oil in when it needs it...   Jan 11, 2007 - 10:19 AM
- - phokur   Incase we're counting here, mine does the same...   Jan 11, 2007 - 8:58 PM
- - hurley97   the car still runs great. even one of the mechanic...   Jan 11, 2007 - 11:22 PM
- - hurley97   did a compression test today. all four cylinders r...   Jan 12, 2007 - 10:21 PM
- - 97lestyousay   It's not funny, I just have had mine come on ...   Jan 13, 2007 - 1:15 AM
- - rayneezy23   my car burns oil and blows blue smoke when you fir...   Jan 13, 2007 - 1:56 AM
- - Celica_Kid95st   Is it hard to do valve seals? The kit is like ...   Jan 13, 2007 - 2:15 AM
|- - presure2   QUOTE(Celica_Kid95st @ Jan 13, 2007 - 2...   Jan 13, 2007 - 10:01 AM
- - hurley97   QUOTE(97lestyousay @ Jan 13, 2007 - 1...   Jan 13, 2007 - 9:20 AM
- - bhawk94   My car has close to 190,000 miles and uses about 1...   Jan 13, 2007 - 10:08 AM
- - subpenny127   what does the ATF do for it? and is it really safe...   Jan 14, 2007 - 2:51 AM
|- - hurley97   QUOTE(subpenny127 @ Jan 14, 2007 - 2...   Jan 16, 2007 - 1:00 PM
- - wickedcelica   check the rings. mine was leaking past the rings b...   Jan 16, 2007 - 1:36 PM
- - hurley97   so I'm pretty sure it's burning oil cause ...   Mar 15, 2007 - 11:33 PM
- - soltrain   If anyone's keeping track, I'm almost to 1...   Mar 16, 2007 - 2:44 PM
- - alltracman78   A couple of other things can cause this. Clogged ...   Mar 17, 2007 - 4:38 PM
- - hurley97   my plugs looked fine last time I checked them (may...   Mar 19, 2007 - 7:11 AM
- - Negative   QUOTE(hurley97 @ Jan 8, 2007 - 3:10 ...   Mar 19, 2007 - 9:09 AM
|- - alltracman78   QUOTE(Negative @ Mar 19, 2007 - 9:09...   Mar 19, 2007 - 2:19 PM
- - midengine3sgte   when you do a compression test and it seems low tr...   Mar 19, 2007 - 1:07 PM
- - hurley97   ok so I understand some basics but I don't kno...   Mar 22, 2007 - 11:06 AM
- - alltracman78   In aluminum head engines there is a metal guide th...   Mar 22, 2007 - 11:56 AM
- - hurley97   ok. so lets make sure I understand this right... w...   Mar 22, 2007 - 9:15 PM
- - jason   new head is like 200-220 from a company called ala...   Mar 22, 2007 - 10:41 PM
|- - hurley97   I'll be picking up another head so we can do t...   Mar 26, 2007 - 4:14 PM
- - alltracman78   I'll try to remember to answer this tonite. I...   Mar 24, 2007 - 12:33 PM
- - alltracman78   I'll add an explanation later tonite, or if I ...   Mar 24, 2007 - 7:26 PM
- - alltracman78   QUOTE(hurley97 @ Mar 22, 2007 - 9:15...   Mar 25, 2007 - 12:19 PM
- - alltracman78   No problem. I don't have any pics of replaci...   Mar 28, 2007 - 2:24 PM
- - hurley97   I'm going to use Jeff's old 7A. same year,...   Apr 25, 2007 - 9:41 AM
- - kevstir   at about 90k (about 3 years ago) on my 3s-ge i not...   Apr 25, 2007 - 10:37 AM
- - hurley97   thats what I use regularly, Castrol GTX High Milea...   Apr 25, 2007 - 11:12 AM
- - lagos   before you take the head apart, measure the valve ...   Apr 25, 2007 - 11:40 AM
- - pittfirefighter   just FYI, talking to toyota techs, it is NORMAL fo...   Apr 26, 2007 - 11:49 AM
|- - alltracman78   Yeah, ATF is LOADED with cleaners. If you ever reb...   Apr 26, 2007 - 6:54 PM
- - Jeremiah   For the record, I've got 242,000 miles on my b...   Apr 26, 2007 - 5:02 PM
- - hurley97   QUOTE(lagos @ Apr 25, 2007 - 12:40 P...   Apr 26, 2007 - 10:17 PM
|- - Jeremiah   QUOTE(hurley97 @ Apr 26, 2007 - 10:1...   Apr 27, 2007 - 2:13 PM
- - lagos   QUOTEok. I don't know what the in/out of spec ...   Apr 26, 2007 - 11:14 PM
|- - hurley97   QUOTE(lagos @ Apr 27, 2007 - 12:14 A...   Apr 26, 2007 - 11:36 PM
- - lagos   have somone drive behind you and look to see if th...   Apr 26, 2007 - 11:57 PM
- - Batman722   she just had a new VC gasket put on. When she down...   Apr 27, 2007 - 12:00 AM
- - lagos   QUOTE(Batman722 @ Apr 27, 2007 - 1:0...   Apr 27, 2007 - 11:23 AM
- - DrAg1n320   hey, just a thought for you guys who are loosing o...   May 3, 2007 - 10:39 PM
Lo-Fi Version Time is now: August 11th, 2026 - 6:22 PM
