Jan 7, 2007 - 8:34 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
ok, I'm already working on the issue I just want various opinions to work with in case I run out of ideas.
recently my car has been going through oil like crazy. here are some of the facts so far: - it doesn't seem to be leaking from any gaskets (at idle speed) checked valve cover, sender, and head gaskets - never see any puddles of oil on the ground after being parked - no blue smoke out the back. theres a little white smoke, slightly more than there used to be but not that bad at all and could just be from the cold and wet weather. and it smells normal - oil light comes on about every 2,000 miles or so now. before about 3 or 4 months ago it had never come on before, I would just change it every 3-5k miles regardless - extra info: started out using 10w-40 then switched to 5w-30 then 5w-30 synth now 10w-30 synth (over the course of about 3 years) here's whats happened and when in detail: [07.15.06] 159,400 mi - oil and filter changed, everything normal [08.20.06] 162,300 mi - oil and filter changed again, like normal [09.01.06] 163,165 mi - first time I'd ever seen the oil light come on. was low but still clear, 1qt added [09.16.06] 164,749 mi - oil and filter changed [10.14.06] 166,853 mi - oil light on again. very low but still clear, 1qt added [11.02.06] 168,262 mi - oil light on. switch to Mobil 1 full synth 5W-30, changed oil and filter [11.26.06] 170,000 mi - oil light on. added 1qt Shell 10W-40 synth blend, its all I could get and I had a long drive home [11.30.06] 170,748 mi - oil and filter changed. switch to 10W-30, still Mobil1 full synth [12.18.06] 172,370 mi - oil light on. change oil and filter [01.04.07] 173,800 mi - oil light on. found oil leaking from drain plug, tightened it and put it 3qt Mobil1. ran car for about an hour, no more leaking from plug [01.07.07] 173,900 mi - still no leak from drain plug. added engine oil tracer dye, will check it in a few days thats where I am now. throw out any ideas you might have and I'll either try it or tell you I've already tried. This post has been edited by hurley97: Mar 15, 2007 - 11:25 PM -------------------- |
hurley97 Burning Oil Jan 7, 2007 - 8:34 PM
97lestyousay Our cars really are twins. I am losing/using abou... Jan 7, 2007 - 11:46 PM
hurley97 damn. my car feels old now. I got it with about... Jan 8, 2007 - 12:27 AM
97lestyousay I just switched back to castrol gtx 5w-30 from mob... Jan 8, 2007 - 1:28 AM
hurley97 QUOTE(97lestyousay @ Jan 8, 2007 - 1... Jan 8, 2007 - 10:07 AM
hashmaster52 my car is at 142xxx miles and it also burns/leaks ... Jan 8, 2007 - 1:46 AM
56willysnut My sons car (147K) is curently burning oil at the ... Jan 8, 2007 - 8:06 AM
Bitter next oil change run 1/2 qt ATF through the engine ... Jan 8, 2007 - 9:56 AM
presure2 QUOTE(Bitter @ Jan 8, 2007 - 9:56 AM... Jan 9, 2007 - 4:56 PM
hurley97 QUOTE(presure2 @ Jan 9, 2007 - 4:56 ... Jan 9, 2007 - 10:46 PM
hurley97 QUOTE(hashmaster52 @ Jan 8, 2007 - 1... Jan 8, 2007 - 10:10 AM
JonCars17 I wish my car would get that much life on oil. My ... Jan 8, 2007 - 10:35 AM
LewFX i too have switched back from mobil 1 to castrol g... Jan 8, 2007 - 10:40 AM
bufferdan Wear...worn out rings. My 7afe with 190k uses alo... Jan 8, 2007 - 10:42 AM
Bitter what kind of milages are you guys at? im at 123K ... Jan 8, 2007 - 10:53 AM
hurley97 QUOTE(Bitter @ Jan 8, 2007 - 10:53 A... Jan 8, 2007 - 10:14 PM
king_wsk QUOTE(Bitter @ Jan 8, 2007 - 10:53 A... Jan 9, 2007 - 6:27 PM
LewFX try using an oil additive such as lucas or napa br... Jan 9, 2007 - 12:47 AM
wind im just comming up to 200,000km....
im using ~2 ... Jan 9, 2007 - 2:10 PM
presure2 are your underplastics installed? Jan 10, 2007 - 7:27 PM
hurley97 QUOTE(presure2 @ Jan 10, 2007 - 7:27... Jan 10, 2007 - 10:17 PM
bufferdan I'll just keep putting oil in when it needs it... Jan 11, 2007 - 10:19 AM
phokur Incase we're counting here, mine does the same... Jan 11, 2007 - 8:58 PM
hurley97 the car still runs great. even one of the mechanic... Jan 11, 2007 - 11:22 PM
hurley97 did a compression test today. all four cylinders r... Jan 12, 2007 - 10:21 PM
97lestyousay It's not funny, I just have had mine come on ... Jan 13, 2007 - 1:15 AM
rayneezy23 my car burns oil and blows blue smoke when you fir... Jan 13, 2007 - 1:56 AM
Celica_Kid95st Is it hard to do valve seals? The kit is like ... Jan 13, 2007 - 2:15 AM
presure2 QUOTE(Celica_Kid95st @ Jan 13, 2007 - 2... Jan 13, 2007 - 10:01 AM
hurley97 QUOTE(97lestyousay @ Jan 13, 2007 - 1... Jan 13, 2007 - 9:20 AM
bhawk94 My car has close to 190,000 miles and uses about 1... Jan 13, 2007 - 10:08 AM
subpenny127 what does the ATF do for it? and is it really safe... Jan 14, 2007 - 2:51 AM
hurley97 QUOTE(subpenny127 @ Jan 14, 2007 - 2... Jan 16, 2007 - 1:00 PM
wickedcelica check the rings. mine was leaking past the rings b... Jan 16, 2007 - 1:36 PM
hurley97 so I'm pretty sure it's burning oil cause ... Mar 15, 2007 - 11:33 PM
soltrain If anyone's keeping track, I'm almost to 1... Mar 16, 2007 - 2:44 PM
alltracman78 A couple of other things can cause this.
Clogged ... Mar 17, 2007 - 4:38 PM
hurley97 my plugs looked fine last time I checked them (may... Mar 19, 2007 - 7:11 AM
Negative QUOTE(hurley97 @ Jan 8, 2007 - 3:10 ... Mar 19, 2007 - 9:09 AM
alltracman78 QUOTE(Negative @ Mar 19, 2007 - 9:09... Mar 19, 2007 - 2:19 PM
midengine3sgte when you do a compression test and it seems low tr... Mar 19, 2007 - 1:07 PM
hurley97 ok so I understand some basics but I don't kno... Mar 22, 2007 - 11:06 AM
alltracman78 In aluminum head engines there is a metal guide th... Mar 22, 2007 - 11:56 AM
hurley97 ok. so lets make sure I understand this right... w... Mar 22, 2007 - 9:15 PM
jason new head is like 200-220 from a company called ala... Mar 22, 2007 - 10:41 PM
hurley97 I'll be picking up another head so we can do t... Mar 26, 2007 - 4:14 PM
alltracman78 I'll try to remember to answer this tonite.
I... Mar 24, 2007 - 12:33 PM
alltracman78 I'll add an explanation later tonite, or if I ... Mar 24, 2007 - 7:26 PM
alltracman78 QUOTE(hurley97 @ Mar 22, 2007 - 9:15... Mar 25, 2007 - 12:19 PM
alltracman78 No problem.
I don't have any pics of replaci... Mar 28, 2007 - 2:24 PM
hurley97 I'm going to use Jeff's old 7A. same year,... Apr 25, 2007 - 9:41 AM
kevstir at about 90k (about 3 years ago) on my 3s-ge i not... Apr 25, 2007 - 10:37 AM
hurley97 thats what I use regularly, Castrol GTX High Milea... Apr 25, 2007 - 11:12 AM
lagos before you take the head apart, measure the valve ... Apr 25, 2007 - 11:40 AM
pittfirefighter just FYI, talking to toyota techs, it is NORMAL fo... Apr 26, 2007 - 11:49 AM
alltracman78 Yeah, ATF is LOADED with cleaners. If you ever reb... Apr 26, 2007 - 6:54 PM
Jeremiah For the record, I've got 242,000 miles on my b... Apr 26, 2007 - 5:02 PM
hurley97 QUOTE(lagos @ Apr 25, 2007 - 12:40 P... Apr 26, 2007 - 10:17 PM
Jeremiah QUOTE(hurley97 @ Apr 26, 2007 - 10:1... Apr 27, 2007 - 2:13 PM
lagos QUOTEok. I don't know what the in/out of spec ... Apr 26, 2007 - 11:14 PM
hurley97 QUOTE(lagos @ Apr 27, 2007 - 12:14 A... Apr 26, 2007 - 11:36 PM
lagos have somone drive behind you and look to see if th... Apr 26, 2007 - 11:57 PM
Batman722 she just had a new VC gasket put on. When she down... Apr 27, 2007 - 12:00 AM
lagos QUOTE(Batman722 @ Apr 27, 2007 - 1:0... Apr 27, 2007 - 11:23 AM
DrAg1n320 hey, just a thought for you guys who are loosing o... May 3, 2007 - 10:39 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 12th, 2026 - 12:17 AM |
